posted 02-04-2001 09:52 PM ET (US)
I added a platform to handle a Motorguide foot controlled troll motor on my 1968 13'
Whaler several years ago and it worked great. I also added a pedestal seat to the side of the front hatch. I reinforced the mounting on the hatch by using steel
plates on the outside and in the inside of the hatch. The seat and pedestal could be removed anytime I wanted it removed.The boat prior to my ownership was involved in a fire that destroyed the interior deck and wood parts. I restored the entire boat and incorporated the troll motor into the restoration. I had to carpet the interior when I completed the restoration to cover up all of the repairs. It turned out great.
I am currently restoring the entire boat again. The first time I did this was in 1976. I am doing this together with my 11 year old son. This is will be his boat.
This time I am also running all of the electrical wire through a very small conduit that will be glassed to the side and the floor to handle the electrical hook up.
The only problem I had in the first arrangement was handling the extra battery placement. I did not want to use the motor battery. I did that at first and I would run the battery down than I would have to pull start the engine.
I hope this will help you and if anybody else has any additional comments would be
appreciated.
