  Trailer for Outrage 25
Author Topic:   Trailer for Outrage 25
LarrySherman posted 02-01-2001 12:16 PM ET (US)   Profile for LarrySherman   Send Email to LarrySherman
Trying to get a quote for a trailer for my boat, 1980 Outrage 25. Can anyone (lhg?) tell me the weight of this boat? Also, does anyone have knowledge about the quality od american Trailers?
Thanks
dfmcintyre posted 02-01-2001 09:26 PM ET (US)     Profile for dfmcintyre  Send Email to dfmcintyre
Larry -
Book lists #3300 for the Outrage, #3500 for the Outrage Cuddy. A good friend has a #5000lb rated trailer for his 25 with twins.
Never heard good, bad or otherwise about American. I ordered an Eagle, and am happy with it.
Don
Orca posted 03-08-2001 02:37 AM ET (US)     Profile for Orca  Send Email to Orca
Float On--6000lbs
Peter posted 03-08-2001 07:40 AM ET (US)     Profile for Peter  Send Email to Peter
Larry,
I think the dry weight of the standard Outrage 25 hull was advertised as 3300 in the 1989 catalog. I assume the weight had not changed from 1980 to 1989. You should add about 900lbs for fuel (140 gallons x ~6.5lbs/gallon) and another 450 to 900lbs for one or two outboards. Thus, your prospective trailer should be selected to support OVER 5000 lbs. Keel roller bunk style trailer is very important. I believe that LHG uses a Continental trailer which is made in Florida. See www.continentaltrailers.com. I think your best result is to call them becaue they didn't respond to my web quote request. See also, www.continuouswave.com/whaler/reference/trailering/
lhg posted 03-08-2001 02:25 PM ET (US)     Profile for lhg
Don: I think your friend's trailer is too light at 5000#. I use a 6000lb rated trailer, with tandem P205 75 R14 radials, and the rig loads it pretty close to the limit with a full tank of gas. (but I only tow VERY short distances with full tank)
Boat w/ full transom & bracket 3500
twin V-6 + batteries 1000
full tank gas and oil tanks 1000
Mills, arch, misc gear 300
Figures are approximate, and generous, but I would next time go with tandem 15" wheels, bringing capacity up to 8500#. Cost w/Continental is minimal, something like $250 more.
Larry, I can highly recommend Continental's galvanized V frame, keel roller model, but you will have to drive to FL to pick one up.
Jacksonville or Pensacola would be good choices, as they only have dealers in the state. One of the other people here has done that, and thought it was worth the trip. You would want model #CTWV24 @ 6000# (14" wheels, and the model I have) or model #CTW24 @ 8500# (15" wheels). Also order dual axle SS disc brakes, and the guide-ons. This will probably cost you about $3500 total.
Another option is to get an aluminium trailer, and have them add the cross members for the double keel rollers. You will have to go up to a larger length size, because you won't have the railroad tie bunks extending 3 or 4' of the end. Your transom should be at the end of the aluminium frame and rear cross member. Down side on these is that because of the shape of the aluminium beams, most appear to have little room for adjusting wheels for weight balance. You could end up with too much tongue weight. In bunk configuration this is not a problem, but with keel rollers it could be. Check on that if you're going to go with aluminium.
I have been very happy with mine, although I have spent a few dollars upgrading it with a lot of poly rollers, SS shafts, etc. After 11 years, it has no rust spots at all. The galvanizing has held up very well. The entire steel channel sction frame is one-piece welded before galvanizing, and that makes a huge difference. Tubular frame galvanized trailers have to be bolted together, and you get rust where the tubes are cut and holes are drilled, and inside the tubes where you can't see it, all hidden failure opportunities. And the frame is nowhere near as rigid, with more u-bolts to rust. My 25 launches and retrieves as easy as the 18. (and MUCH easier than jimh's 20 Revenge on a bunk float on!!!)
Just ask Jim!
For others interested, some recent ball park prices for a keel roller trailer from Continental are, in standard configuration:
for a Montauk $800
For a 13/15 $600
18 Outrage $1100 2800lb (single)
20/22 Outrage/Revenge $1500 (tandem)
25 Outrage $2100 (tandem)
Add extra for SS disc brakes, guide ons, etc.
My recommendation is to stay away from drum brakes. They even rust out in the atmosphere during periods of no use in the midwest! I think they're worthless on a boat trailer around a salt environment after a couple of years, unless you're an auto mechanic. The new SS models are easy to see what you've got and easy to keep serviced.
Like outboard engines, Florida seems to have the best pricing, on ANY KIND of trailer, I've seen in the country. It's evidently a very highly competitive boating market. A Good rule of thumb is buy your boating needs in FL and sell them elsewhere!
hauptjm posted 03-08-2001 03:18 PM ET (US)     Profile for hauptjm
Continental Trailers:
http://www.continentaltrailers.com
Orca posted 03-09-2001 02:01 AM ET (US)     Profile for Orca  Send Email to Orca
RE: Float On and off-Jim, What difficulties do you have with the trailer? I'm so impressed with mine,the comment caught my curiosity.
