ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: The Whaler GAM or General Area Swim Platform for Montauk
Author | Topic: Swim Platform for Montauk |
compounder |
posted 02-17-2001 09:15 AM ET (US)
As if I haven't spent enough on the Whaler this winter, I am now considering the addition of a re-boarding platform. I have seen a few around here with a teak platform. Are these original equipment from Whaler? Still available? Anyone know what they cost? Are top-quality after market items available? I want a bolt-on for the Montauk, not some "universal-fit" item. |
triblet |
posted 02-17-2001 08:32 PM ET (US)
The current BW swimstep for the Montauk is Starboard or the equivalent with stainless tubes for support. At least for current boats, it's a bolt on. Dunno if yours (which, as I remember isn't new) has the wood (or whaler wood) behind the fibreglas. Worst case, a hocky puck of epoxy could be inserted behind the glas. It bolts onto the port side. I have one, If you really had your heart set on to Chuck |
Chesapeake |
posted 02-18-2001 09:08 AM ET (US)
Joe: Let me know how it works out if you end up installing one. My fishing boat has become a family boat over the last 3 years (2 kids) and my wife would love the convenience. One question: can it be mounted starboard? I have a kicker bracket on my port side. Bob |
triblet |
posted 02-19-2001 10:21 AM ET (US)
You'll have to check the wood chart for your year. On my '98, the post side has reinforcing for the swimstep, starboard side has reinforcing for a kicker, but MAYBE the kicker reinforcing would work for the swimstep. Mmm, and the other consideration is how the Chuck |
chad |
posted 02-19-2001 02:43 PM ET (US)
My wood locating diagram (dated 9/24/75) shows a 7" x 7" x 1/14" plywood on both sides of transom. It looks to be high on the transom, where the eyes are located. Chad |
Dick |
posted 02-19-2001 05:40 PM ET (US)
I believe you will find that the front edge of the swim platform is formed to match the port side of the transom so it will not fit the starboard side. Dick |
Chesapeake |
posted 02-19-2001 06:42 PM ET (US)
Hi Dick! Is just the Marine Starboard shaped to match the port side or does this phenomenon effect the bracket(s). If the Starboard is the only problem, I guess I could re-machine a piece accordingly or use teak as suggested above. What do you think? Does anyone have a picture of the mounting for this platform? (cetacea??) Thanks, Bob |
triblet |
posted 02-19-2001 08:00 PM ET (US)
On the wood diagram for my '98 (which is dated 8/5/94), port and starboard transom wood is different. Starboard side has a piece of 1 1/4" plywoord, from the top of the motor cutout up. Port side has that, and two pieces lower down that are clearly there for the the swimstep. The plastic is cut to match the curvature The tubes are bent for the curvature. They There's a picture, though from the wrong Chuck |
RWM |
posted 02-20-2001 01:09 PM ET (US)
I've been thinking about adding a swim platform to my '79 Montaulk while redoing it this spring. But..the wood locating diagram shows only a 7"x10" section on the upper part of the transom with wood behind it. So it looks like I won't be able to add the platform since there is no wood lower down to bolt too. By the way, West Marine has a teak platform at a decent price...Bob M. |
hauptjm |
posted 02-20-2001 01:27 PM ET (US)
Another alternative to the conventional swim platform where the step swings down from the protruding platform, now comes from Armstrong. A very well made "bracket" mounts to the transom (can be as small as two packs of cigarettes stacked). The ladder swings into position, with a safety lock. If the ladder falls over, it floats. And if you forget in the down position, it has a trigger to let it pop up and out of the water. Great device. Check out the site below for a picture. Scroll down, they have it mounted to one of their brackets, but it can be directly mounted to a transom. |
Chesapeake |
posted 02-20-2001 05:41 PM ET (US)
Chuck and Jim: Thanks for your responses. Chuck: The web-site is impressive as is your dive whaler. Did you fabricate your tank / fin holders, etc. I am not a diver (yet), but am really impressed by the apparent workmanship and details of the accessories. Jim: The Armstrong website, in particular, the platforms look very serious. Is there a scaled down version or an ability to just mount the ladder? Take care gents! Bob |
triblet |
posted 02-20-2001 06:03 PM ET (US)
If there's no wood, you can put a 2"+ hockey puck of expoxy behind the fibreglas. I had to do this after a 250 pound diver went up my ladder WITH tanks and weights in. The tank racks are partially bought, BTW, I HATE the Pelican basket style tank Chuck |
hauptjm |
posted 02-21-2001 09:05 AM ET (US)
Bob: Yes. It's basically the same slotted little bracket you see in the photo, just not mounted on the engine bracket. I saw these first demonstrated on the cable show ShipShape TV. They put a fairly stout person on it to demonstrate the strength. This is a really well engineered piece of equipment. |
kelb |
posted 02-22-2001 10:51 PM ET (US)
A swim platform sounds dangerous if you mean for skiing or tubing. My kids and friend's board at a swim latter which mounts (hooks) to the side of boat between the hand rails of my montauk. The swim latter is, I believe, a BW option, accordian syle fold with a Mill's storage bag. Only bad is storage when the boat is loaded. kelb |
triblet |
posted 02-23-2001 09:59 AM ET (US)
What's dangerous about it? The BW swim platform doesn't have a any There's a picture at [url]http://www.garlic.com/~triblet/whaler/[\url], though that shows a three step Chuck |
Bullbay |
posted 02-23-2001 10:53 AM ET (US)
I use a three step aluminum and plastic ladder which has a rope top with a hook. I simply hook the rope around the rail base and secure with the hook. It is compact enough that I am able to store it out of the way in the transom drain. I am 62 and cannot get up on my son's teak platform with the one step. I have no problem with my three step ladder. |
kelb |
posted 02-23-2001 09:58 PM ET (US)
I just meant that when the kids are in and out of the boat so often, I prefer to have them away from the prop. When entering from the side, the whaler handrail assist them in getting in. Kelb |
triblet |
posted 02-23-2001 10:34 PM ET (US)
So shut the engine down. It should be whenever possible with a swimmer in the water anyway. Neutral isn't good enough, IMHO. Chuck |
Bullbay |
posted 02-26-2001 10:09 AM ET (US)
My prior post said I had a three step ladder. I was in the boat yesterday and recounted. It is a two step ladder and an overweight 62 year old can get out of the water with no problem. |
