  chinewalking on dauntless 13
Author Topic:   chinewalking on dauntless 13
credditt posted 04-25-2001 11:37 PM ET (US)   Profile for credditt   Send Email to credditt
I have a 95 Dauntless 13 with a 3 cylinder 50 HP Evinrude. The dealer also installed a 15 gallon fuel cell under the rear casting deck. Because of too much stern weight (I assume) the boat chine walks very badly at high speeds. I have put shims under the engine mounts to adjust the angle, and have doel fins. Any other suggestions?
Whaletosh posted 04-27-2001 06:37 AM ET (US)     Profile for Whaletosh
I had a similar setup. I had problems with porposing. adjusting the trim and slowing down was the only thing that helped.
Sean
Yesac13 posted 05-04-2005 12:52 AM ET (US)     Profile for Yesac13  Send Email to Yesac13
I have a 1995 Dauntless 13 with a 40 hp 2004 Evinrude ETEC outboard. It was rather stern heavy so I added about 60 pounds worth of sand in plastic bags. It evened out quite nicely. This may help in your case. That 3 cylinder Evinrude is very heavy so you may need more than 60 pounds. The Dauntless 13 has alot of bouyancy in the bow so do not worry about it being bown down. It is only about 2/3 inch lower in the bow at rest now. One other way to help the boat run better is to bring somebody along with you for the ride. Have him or her sit in the bow. Good luck.
