  CMC T+T on 13 Whaler
Author Topic:   CMC T+T on 13 Whaler
JimU posted 06-27-2001 03:34 PM ET (US)   Profile for JimU   Send Email to JimU
I recently acquired a 13 whaler with 40 Merc with no T+T. I have a CMC PT130 that I got with another boat. The electric motor on the T+T is shot. I was thinking of mounting the CMC unit on the Whaler but before I send it back to CMC for a rebuild I wondered if ther is any experience with that combination her in Whaler land. Any experience with performance or other comments would be appreciated. thanks JIM
Bigshot posted 06-27-2001 04:42 PM ET (US)     Profile for Bigshot  Send Email to Bigshot
Should be good. can jack the engine up another inch.
JimU posted 06-28-2001 08:26 AM ET (US)     Profile for JimU  Send Email to JimU
Any experience on before and after performance?
willyjoe1 posted 06-28-2001 09:33 PM ET (US)     Profile for willyjoe1  Send Email to willyjoe1
i don't have the same combination you want , but similar, i have a 40 hp yamaha with power t/t, it is mounted on the cmc 2 piece jackplate w/ 4"setback [20] lbs, cause about 2" stern down problem, bow up a lot, have to rise the seat 1 1/4" put tank and battery under, your cmc pt130 should be 32 lbs. with 5"setback, that mean your motor + pt130 will little more heavy than mine, you will have the same problem like mine, and you can call cmc about your pt 130 problem , they will till you how much and send you the replacement motor, hope this help,
william
Clark Roberts posted 06-29-2001 06:53 AM ET (US)     Profile for Clark Roberts  Send Email to Clark Roberts
Jim, I think you will like the set-up and will enjoy the t&t but may have to adjust some weight fwd.. don't know where your fuel and battery are located... go for it! And raise the engine as mentioned above! The CMC electrics seem to have motor brush problems... Happpy Whalin'... Clark
