  ID # on old 13' hull
Author Topic:   ID # on old 13' hull
Kelly posted 08-20-2001 09:16 AM ET (US)   Profile for Kelly   Send Email to Kelly
I have an old 13'(I think about '66). It has been painted. If it is still under the paint, where would the hull ID # be located?
thunderbay posted 08-20-2001 09:41 AM ET (US)     Profile for thunderbay  Send Email to thunderbay
My 69 13" whaler has it's id # below where the motor mounts to the transom. Thing is, its paint itself, so to much or to strong of a stripper and you might lose it. Cant say that 66 was the same, but thats where I would look first, good luck, shawn
acseatsri posted 08-20-2001 09:47 AM ET (US)     Profile for acseatsri  Send Email to acseatsri
Mine was just above the "step" in the middle of the transom where the motor mounts. Mine is a '66 also. Rather than stripper, try sanding using a random orbit sander with about 150 grit paper. That way you can control the cut. Regular paint stripper can soften the glass and gel coat. Alternative is to use Interlux 299E stripper, but if all you want to do is find serial number, it is quite pricey.
