  22 revenge with whaler drive vs 25 revenge
Author Topic:   22 revenge with whaler drive vs 25 revenge
Maine whaler posted 08-27-2001 08:01 AM ET (US)   Profile for Maine whaler   Send Email to Maine whaler
My search for the best island hopper for Maine waters carries on. What are the differences in ride and handling between these two boats? They should bwe about the same size, right?
Peter posted 08-27-2001 09:15 AM ET (US)     Profile for Peter  Send Email to Peter
Cockpit size is a little smaller in the 22 Revenge with WD. The beam of the 25 Revenge/Outrage is 8' and the beam of the 22 Revenge/Outrage is 7' 5". The 22 with WD weighs several hundred pounds less than the 25. Cabin size is the same.
Ray posted 08-27-2001 09:44 PM ET (US)     Profile for Ray  Send Email to Ray
Maine Whaler,
Get the 25. You will not be disappointed!
Ray
lhg posted 08-28-2001 12:50 AM ET (US)     Profile for lhg
There is more difference in size between the two hulls than is often realized. The 25 weighs about 1300 lbs more, or about 65% more. That is your best indication of the larger size. Requires about 50% more HP also.
Maine whaler posted 08-29-2001 09:14 PM ET (US)     Profile for Maine whaler  Send Email to Maine whaler
Where could I get the specifications on the 25 foot model Revenge walkthrough? How hard is it to trailer?
Ed Stone posted 08-29-2001 09:42 PM ET (US)     Profile for Ed Stone  Send Email to Ed Stone
Revenge 25 W-T O.B.
Length 24' 7"
Beam 8'
draft 16"
weight 4000
Max.weight 3035
Swamped cap.9000
persons cap. 12
Max. hp. 300
engine length 25"single 20"dual
fuel 140 gal.
Good luck!
Ed Stone
lhg posted 08-29-2001 09:55 PM ET (US)     Profile for lhg
With a properly set up trailer, and I emphasize this, meaning good keel roller system and brakes (getting hard to find these days), it's as easy to trailer as an 18 Outrage. With a poorly set up and rigged trailer, almost impossible. You'll hate it, and spend most of your time cursing when at the launching ramp. I simply couldn't imagine handling a boat that big on a bunk trailer.(besides, you'll warp the hull sides) You'll need a vehicle with a 7000lb tow rating, probably a weight distributing
hitch, but should be able to tow it safely at 60-65MPH. In 12 years, mine's been at least 80,000 miles over the road, including a trip to the coast of Maine! No sweat at all, except for the 7 MPG I get towing, down from a normal 22MPG! Steeper hills slow me down to about 45mph with my 190HP Chevy 350 engine.
