ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: The Whaler GAM or General Area Trailer for Montauk 17' ?? Which one guys?
Author | Topic: Trailer for Montauk 17' ?? Which one guys? |
John from Madison CT |
posted 09-29-2001 09:53 PM ET (US)
Greetings, I'm hot on the trail of a used Montauk. It's been way to many years since I've had one and I'm finally close to closing a deal. Anyway, it looks like I'll have to buy a trailer for this one. I don't know what to ask for in a Montauk trailer and a couple of places I called where telling me I needed this or that, some said rollers, some bunks. You tell me guys. What kind of load capacity and bunks or rollers. I don't need the best, but what is functional. The boat I'm looking at is an '89 with an '89 Yamaha 90hp Outboard. It's a very very clean boat and spotless motor with all the neat features I want. (i.e. Bow rails, Whaler cooler seat in front with back pads and rod holders, etc. etc.) They're asking $7500 for the rig. I think it's a decent deal. What do you guys think?? Thank for your help. John |
whalernut |
posted 09-30-2001 08:50 AM ET (US)
Sounds like a good deal on a clean Montauk!! As far as trailers go, Loadrite trailers are made in Easten PA. They make a trailer exclusivly for the Montauk! It`s not on their website, but they do make it on request, a combo of Bunks and the all important Keel rollers. I believe they are about $1500. Go to their site and punch up dealer search. If they dealer sais Loadrite doesn`t make one for you`re Whaler, they just don`t know it, I had this problem until the dealer talked to a Loadrite Rep. Good luck-Jack Graner. |
JBCornwell |
posted 09-30-2001 09:58 AM ET (US)
I'm not familiar with Loadrite, but I agree that you need keel rollers as well as bunks or bottom rollers. Red sky at night. . . |
whalernut |
posted 09-30-2001 10:01 AM ET (US)
I don`t think Loadrite sells as far as Texas, but I could be wrong?? They are of the Shorelander quality! Regards-Jack Graner. |
Dick |
posted 09-30-2001 10:19 AM ET (US)
I've got a galvanized Shorelander under my Montauk, very good quality trailer. Mine is a full bunk trailer, I'm one of those that doesn't believe in keel rollers. Either way you can't go wrong with Shorelander. Dick |
andygere |
posted 09-30-2001 12:46 PM ET (US)
I have a galvanized keel roller Shoreline under my '79 Montauk, and I really like this style of trailer. One big advantage of rollers over bunks is the ability to slide the boat off the trailer onto blocks for bottom painting, cleaning or repairs. I just did it last week, and it was a piece of cake. I think it would be difficult if not impossible with a bunk style trailer. Just something to think about. |
Kim |
posted 09-30-2001 07:46 PM ET (US)
my vote is shorlander but no rollers. no need for them , skids are fine. I've seen roller put dents in hills befor on jet boats . I'm very happy with my shorlander galvy. kim. |
posted 09-30-2001 08:09 PM ET (US)
One more question guys....do you know what weight trailer I should get? What's the weight of a Montauk with a V4 OMC outboard? Thanks again for your help in advance. John |
whalernut |
posted 09-30-2001 08:39 PM ET (US)
I believe the minimum trailer capacity needed would be about 1500 lbs., but would think to be better with a trailer rated for about 1800-2000 lbs., you never know, stuff adds up!! Good luck-Jack Graner. |
LarrySherman |
posted 09-30-2001 10:03 PM ET (US)
John, See the bug bit you good! Glad to see it. We'll have to meet up next summer! |
RWM |
posted 09-30-2001 10:12 PM ET (US)
I bought a Loadrite for my 1979 Montauk this summer. It is all hot dipped galvanized with plastic fenders and sealed tailights. It came as a bunk trailer for a Montauk but I had them add poly keel rollers and an extra center brace with keel roller. Three keel rollers contact the boat plus two 2"x6"x8' bunks. I also got 14 inch tires. The model number is 17-2200 90V. The standard capacity is 2200 lbs, but with the extras it's now 2700 lbs. I am very happy with it. Easy off and on and tows well. Cost was $1690. I think there are many trailers out there that would work fine, and I do believe for a whaler the keel rollers are the way to go...Bob M. |
posted 10-01-2001 07:23 AM ET (US)
Larry, Yep, your to blame my friend !! <G> I found a 22' Outrage Cuddy with a 225 Yamaha, it's an '88 package. Their asking 15K with trailer. Hmmmmm, what do you think? John |
Kim |
posted 10-01-2001 08:29 AM ET (US)
when I said no rolles. keel rollers yes ! but not rollers that cradle the boat like a E-Z LOADER trailer. sorry . kim. |
Bigshot |
posted 10-01-2001 11:11 AM ET (US)
I like alum bunk trailers myself. They are lighter than steel and look prettier too. Mine is a tow Master that is rated for up to 3500llbs or so. Cast was about 41700 with the torsion axle and Stainless bolt kit. |
Peter |
posted 10-01-2001 12:03 PM ET (US)
John, To give you an idea, there's an 88 22' Outrage cuddy in Branford with twin 130 Yamahas, no trailer advertised for 16k. So it definately seems to be in the ball park. Watch out generally for corrosion on the V6 Yamahas of that era. They are fairly well known to have shift rod corrosion problems. It's an expensive repair to replace the shift rod. A buddy had to do it on his '89 Yamaha 225 Excel on a '89 Grady recently. |
JFM |
posted 10-01-2001 01:36 PM ET (US)
My 2000 montauk came with a Sorelande double bunk on each side. Dealer says thats what Whaler now recomends.Regards, Jay |
dauntlass 18 |
posted 10-01-2001 06:46 PM ET (US)
Load Rite has a 800# 1 800 562 3783 they told me they make exact fit trailers for Boston Whaler boats.I have a Load Rite trailer for my Whaler it has been trouble free so far app. 2500 mi use .Just make sure dealer adjusts bunks and keel rollers to fit hull properly |
simonmeridew |
posted 10-01-2001 08:45 PM ET (US)
I have a '99 LoadRite for my Montauk. Keel rollers and bunks for lateral stability. The boat sits nice and low on the trailer, with about an inch or so to spare between the fenders, but every time I load the boat on, it automatically goes to the center of the keel rollers, whether I drive it on, or winch it up. Never had to slide it back off and reload. Really nice situation. Two things though: the boat sit's so low you need to tilt the motor when you trailer the boat, when the motor's down, the skeg doesn't clear the ground by much. And the second thing. The taillights got rusty inside so the lights stopped working this Fall. Not so great for a two year old trailer. I may be looking at replacement LED lights this long cold winter. simonmeridew |
LarrySherman |
posted 10-01-2001 09:59 PM ET (US)
Get the Cuddy! Get a compression test, run the motor, and get THE CUDDY! Your kids will appriciate the room, and so will you! |
triblet |
posted 10-01-2001 11:59 PM ET (US)
> I believe the minimum trailer capacity > needed would be about 1500 lbs., but would > think to be better with a trailer rated > for about 1800-2000 lbs., you never know, > stuff adds up!! Good luck-Jack Graner. Trailers are rated GROSS, including the It's a Shoreland'r (the correct spelling) Chuck |
posted 10-02-2001 12:41 AM ET (US)
Chuck's advice is good advice--don't skimp on the trailer. Many dealer-delivered boats come on marginal trailers because they are trying to hold the package price-point down (or keep profits up). With a trailerable boat, the ease that you can haul the boat on the trailer, launch it, and recover it will all have great impact on how much you use the boat and how much you enjoy using it. One advantage to trailers using keel rollers is they don't have to be buried underwater to recover the boat. This often makes the difference between where the winch handle is versus where the water is. I know on my trailer, which was originally a "float-on" style trailer, it is impossible to get the boat on the trailer without having to put on my waders and get into the water. Guys with all keel roller trailers seem to be able to stand on dry land and winch their boats up; I am two feet into the water cranking mine. Also look for quality tires and wheels. The Goodyear Marathon Special Trailer Radial is a popular top-of-the-line tire. Also consider the size of the wheels. Larger tires (14-inch) mean better performance at highway towing speeds. Avoid little 12-inch wheels/tires, unless you only need to tow a mile or two. A Montauk trailer might be right on the borderline for trailer brakes. I would judge that depending on the towing vehicle. If you plan to tow with a marginal vehicle, brakes might make sense. Make sure you get a suitable winch. If you get keel rollers (which I recommend) you should upgrade to the STOLTZ brand poly rollers. Watch out for imitations; there are some other no-brand yellow poly rollers being sold these days. One problem with these is they are a different size than the Stoltz. If you have to replace them it could be hard to match them up. If you are going to be in salt water, get all stainless steel hardware as much as possible, including the axles for the rollers. Except for a few national brands, trailers often tend to be a locally supplied item because it is hard to ship them at reasonable costs. Generally the only way to make economical delivery of a trailer is to have three or more of them stacked up and towed to a drop point. Having a single trailer delivered is pretty expensive, thus many local sources are used for trailers instead of 'brand" name ones. You might have a great trailer fabricator in your area--check it out. And. of course, you have already read the lengthy multi-part article I wrote on trailers, right? http://continuouswave.com/whaler/reference/trailering/ --jimh |
posted 10-02-2001 07:38 AM ET (US)
To All, You guys are the BEST !! Thanks for all your help. I'm negotiating on an '89 Montauk with a '89 Yammie 90hp. The boat clearly has little use. No stess cracks or spider cracks, clean clean boat. I offered $6500 w/o trailer and am waiting for a response. The motor was maintained by a high priced marina in CT and the boat was owned by a NY'er who only used it during the summer and on weekends. I saw the complete 12 year repair/maintenance record of the motor. (Eckk ..these marina's charge a bundle.) Thanks again all for your advice. I'm looking at a trailer with bunks and keel rollers. John from Madison, CT |
Bullbay |
posted 10-03-2001 09:59 PM ET (US)
I have a 2000 Fastload aluminum float on trailer for my 89 Montauk with a 2000 Evinrude Ficht. The GVWR is 2800 lbs and the Net carrying capacity is 2400 lbs. I traded an old keel roller galvanized that I got with the boat last year for $1000 net in Mt Pleasant SC. The trailer man adjusted to the Montauk and it made a complete difference in enjoyment and ease of launching and loading. I have never gotten wet either launching or loading and I don't power load. I simply put trailer in water up the the plastic v in front which allows plenty of walk on room. The back wheels of my truck have never been in water with this method on any of the ramps that I have been on including fresh and salt water after reading Tribletts advise last year. |
ALAN G |
posted 10-06-2001 07:24 PM ET (US)
topic is well covered but whatever trailer you wind up with, here are some recommendations for use that I have found make a big difference. 1. Bearing Buddies or equivalent hub grease system is a must. 2. Put down a couple of walking boards on the trailer from as far forward as you can to the rear....I put mine on both sides of the keel rollers. 3. JimH recommended Stoltz rollers...ditto. To make these even better, I drilled a couple grease passages and added zerk fittings. The roller shafts are usually mild steel and drilling down the axis and then at right angles will give you a great lubrication point and your Whaler will slide into and out of the water real easy. Lots more could be written about trailering but don't forget to tighten your lug nuts! I almost lost a tire on the Connecticut Turnpike because I did not check this! |
alvispollard |
posted 10-12-2001 10:44 PM ET (US)
Long makes a galvanized trailer for an 18' boat. It has the roller for the weight and 4 bunks for stability. Small but adequate guide rollers. Fiberglass wheel wells. 14" tires make long trips easy. Can handle a 1000 lb larger boat. Very satisfied for past 7 years. Montauk fits perfect with this fully adjustable trailer. |
posted 10-13-2001 07:39 AM ET (US)
Guys, Muchas Gracias !! I've since bought the boat for $7K. I took a sea trial yesterday and the engine ran well, tached out at 5300RPMS (Spec was 5000 - 5500) and idled down at 600 RPMS very well. Plenty of fishing left up here in CT. Went with a friend yesterday and caught 2 Stripers (37" & 28") and a boat load of 10-12lb. Bluefish. John from Madison, CT |
boaterguy |
posted 10-13-2001 02:04 PM ET (US)
Was that the montauk at boats inc. That was a great deal! Did you get those stripers in the race? |
posted 10-13-2001 04:16 PM ET (US)
Boaterguy, Yes, the boat I just bought was the one from Boats Inc.. I managed to only get $500 off the asking price, but I believe it's a pretty good deal at $7000 w/o trailer. I'm buying the 2002 Load Rite from them too. (Probably could have found a better deal but it's easier letting them do the rigging/adjusting and loading from blocks.) Keep in touch. John |
