ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: The Whaler GAM or General Area Bracket on '85 18' OR
Author | Topic: Bracket on '85 18' OR |
ECUSeaPA |
posted 01-02-2002 11:19 AM ET (US)
Has anyone had any experience with putting a bracket on an 18' OR. I'm concerned about changing the "center of gravity" and casuing the motor to be prone to being 'swamped'. I love the extra room of the bracket / closed transom. Any thoughts? Thanks in advance. |
Peter |
posted 01-02-2002 02:03 PM ET (US)
See continuouswave.com/whaler/cetacea/cetaceaPage24.html |
hauptjm |
Here are some pictures and commentary regarding brackets. The first link is the Cetacea section, showing the use of a “full” Armstrong Bracket, and the other link is to the Bracket Sub-Section of the Reference Section, jimh has created as a database for his loyal followers. Note, in the second link towards the end, that if you were to use a much shorter “set-back” bracket like the one shown here, you could not possibly have a better example of craftsmanship and detail like lhg’s.
http://continuouswave.com/whaler/reference/engineBrackets.html I think you'll see that adding a bracket will not produce any negative effects. In fact, if you do it correctly, you'll be very pleased with the results. |
ECUSeaPA |
posted 01-21-2002 09:55 PM ET (US)
Any other opinions?? I really like the room of the bracket and I'm doing some glass work anyway. |
