  1995 24' Outrage
Author Topic:   1995 24' Outrage
jimb342 posted 03-09-2002 10:49 PM ET (US)   Profile for jimb342   Send Email to jimb342
getting ready to purchase and am looking for advice on performance and fuel use. 225 hp yamaha, 250 hours. told 23 mph cruise, 30mph max.?? Can you tow comfortably with a 1/2ton 1999 5.9 ltr Dodge Ram (no jokes about the german junk please)? Gotta love these boats. Thanks to any responses.
Jim
Dr Don posted 03-09-2002 11:20 PM ET (US)     Profile for Dr Don  Send Email to Dr Don
Boating Mag. lists the cruise speed at 4000 rpm at a speed of 28.5 mph and a top speed of 41.8. This is with a 225 Evinrude OceanPro. You will love this boat! Mine has twin 175's and is a 1996. I pull it with a 1989 1500 surbuban. It is a bit heavy to tow but it is flat where I live so it does a decent job.
Ed Stone posted 03-09-2002 11:41 PM ET (US)     Profile for Ed Stone  Send Email to Ed Stone
24ft. Outrage/23ft.10in.
beam 8ft6in,draft 17in,weight 3100lbs
swamped cap.8500lbs.,max.hp.400,
min.hp.200,fuel cap.195gals.
They are still making these hulls in
the commercial products division.
I pull a 23 outrage with the 5.9 liter
Ram with no problem.
phatwhaler posted 03-10-2002 12:41 PM ET (US)     Profile for phatwhaler  Send Email to phatwhaler
CG Sta Sand Key, 24Ft Justice
Twin 200 Opti
42Kts @5600 rpm.
I could even imagine how much of a pig that boat would be with only a 225. You need twin 150's minimum. I actually won't plane with 3 guys onboard and one engine tilted out of the water. Therefore I think the single 225 would be way low on power.
phatwaler out.
johnc250 posted 03-10-2002 06:39 PM ET (US)     Profile for johnc250  Send Email to johnc250
Do you guys know if there is a difference between the 1995 and 1997 24' Outrages?
Build Quality?
Dr Don posted 03-11-2002 08:36 PM ET (US)     Profile for Dr Don  Send Email to Dr Don
That 24 Justice must be a bit heavier than the rec. 24. I can plane with a 175 and run 28-31 mph at around 4500. This was with 3 people and one engine tilted up. Slow to plane but not that bad. As far as I know there was very little change in this boat from 1994-97. After the first year the transom door was standard.
phatwhaler posted 03-11-2002 09:58 PM ET (US)     Profile for phatwhaler  Send Email to phatwhaler
Actually, I'm not sure the CG 24 Justice is actually a CPD boat. It has a BWCLA1.... HIN number. Which according to somewhere on this site is a recreational HIN. Supposedly the CPD boat start with a CP... HIN. I will say that the boat is looking pretty rough after 4.5 years of CG use. The T-Top has been a nightmare. Broken welds numerous times. The rear tow bar screen broke in half and almost hit a crewman. I doubt any of this stuff would ever happen under normal recreational conditions though. This particular boat has led a very hard life. It's had about 4 or 5 sets of engines.
jimb342 posted 03-12-2002 07:21 PM ET (US)     Profile for jimb342  Send Email to jimb342
Thanks for all your replys.
