ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: The Whaler GAM or General Area Handheld GPS
Author | Topic: Handheld GPS |
MikeK |
posted 03-14-2002 07:38 AM ET (US)
I need to buy a handheld portable GPS. Any comments for any model that is reliable, simple to use, priced reasonable?? |
gvisko |
posted 03-14-2002 07:42 AM ET (US)
i have the garmin 76 it is a wass unit and real easy to use cost about $ 220.00 get the 12 volt power cord because batterys dont last very long gvisko |
tabasco |
posted 03-14-2002 07:43 AM ET (US)
GARMIN........GARMIN............GARMIN |
Whaletosh |
posted 03-14-2002 08:42 AM ET (US)
I agree Garmin is the leader of the pack, especially in small hand held units. If you want a mapping unit there are several etrex legend units with buy it now prices of less than $200. I bought one yesterday for $172 plus $6.50 shipping. This is a new unit, still in the blister pack. the etrx legend is small, has lots of mounting options. It also works with all of Garmins Mapsource CD-ROMS, including the Bluechart. Because of the small screen it won't display some of the information of the Bluechart CD-ROM. It is also WAAS capable.
P.S. to all. check out the new Garmin Rino GPS units. A GPS unit and a FRS radio in one small package. One even includes a base map and can accept data form Mapscorce CDs. Both can transmit your positoin to another unit. Definately geared towards hikers, campers, hunters, bikers etc., but still neat gadgets. |
whalerron |
posted 03-14-2002 09:42 AM ET (US)
Reliable? Easy to use? Reasonably priced? I would think that any GPS is going to be reliable. I don't feel that brand plays into reliability anymore. I feel that Garmins are intuitively the easiest to use. This is true for all of their models. Garmin has spent a lot of money on the human-machine interface and it shows. If you read through past posts here, you will see that Garmin stands 100% behind their products. Personally, I like the Garmin GPS12. It can be had for under $150 and if you don't need mapping, it contains all of the functionality I could imagine using. The Etrex units are nice too and they can be had for around $100. With these, you get all the basic functionality too. When looking at the GPS units, you should consider how waterproof they are. My whaler is completely open and for that reason I wanted a GPS that met the "submersible" waterproof standards. The GPS12 meets this criteria. - ron |
triblet |
posted 03-14-2002 10:15 AM ET (US)
The eTrex screen is awfully small to read in a moving boat. I think if I were getting a handheld for aboat I'd get a Garmin 176. Nice big screen, supports maps (which make it MUCH easier to use), but kinda big and clunky for backpacking. I have an eTrex Vista that I use for hiking I'd sell the 175 (with chart chips for Northern If you go with a mapping eTrex, the Legend has Chuck |
Jerry Townsend |
posted 03-14-2002 10:46 AM ET (US)
Mike - You have already heard the name Garmin, pretty much the standard of handheld GPS units. I currently use the Garmin 48, a handheld unit designed for marine applications, a removable antenna, a built in map of major cities - and some other stuff that I don't really use - and which sells for around $200 (West Marine). It works fine in the boat or when I am hunting.
The majority of the handheld handheld units use AAA batteries. A better power source is the NiMH cells - much better (no memory problems and much longer life) than the Nicads. ----- Jerry/Idaho |
Chris J |
posted 03-14-2002 12:04 PM ET (US)
There is another GPS manufacturer, by the way... I have a Magellan 320 and it is OK. Garmin is the undisputed leader in handheld GPS, all right, but the current Magellan units aren't bad and are pretty attractivly priced. If you plan to use the unit on a boat you should take waterproofing into account, also weight. There are a few GPS units that are waterproof and will float if dropped overboard; I'm fairly sure the Magellan 315 qualifies. (But I've never tried it with my 320.) |
Whaletosh |
posted 03-14-2002 12:40 PM ET (US)
Yep, the screen is small on the Etrex, as most (but not all) hanhelds also have this "drawback". A fixed mount unit has a distinct advantage of not relying internal batteries. LCD panels generally consume more power the bigger they are. At least the screen on the Etrex is fairly high resolution. I debated for several hours before I decided that the screen on the Etrex being almost as large as the screen on a 12Map would be fine for me. Especially since I use it more for heading ans speed info than for cartography. I'll take iMac blue over Windows beige anyday :) |
where2 |
posted 03-14-2002 12:44 PM ET (US)
www.gpsdiscount.com GPSMAP76 with NiMH batteries and Marine Mount for $350. WAAS, BlueChart/Mapsource compatible, waterproof. Has 8Mb for map storage. Want More Storage? GPSMAP76S 24Mb storage, bigger price tag. When's the last time you wished you'd bought less storage space on your hard drive, or less Ram for your computer? Get the largest capacity memory you can budget! |
triblet |
posted 03-14-2002 02:29 PM ET (US)
LCDs consume almost no power. It's the processor that consumes the power. Now there's more processing required the more pixels the LCD has, but it's the LCD's physical size that counts (at least as long as you don't turn on the backlight). But batteries are generally a non-issue because Chuck |
kingfish |
posted 03-14-2002 02:53 PM ET (US)
Just picked up a new Garmin GPSMap 76 for $295.00 on Ebay (I've seen them advertised for $308.00), as a back up to my Garmin 235 Chartplotter/Sounder. My first hand-held - this one is waterproof *and* it floats, besides the technical goodies. I'll keep y'all posted once I get it and figure out how to turn it on. kingfish |
sklein |
posted 03-15-2002 11:24 AM ET (US)
I agree with the previous comments about the Garmin 48. I've had one for about 3 years now. It's based on the 12, but is geared for the marine market. Includes city data, and nautical markers (lighthouses, channel buoys, etc.) The folding antenna has outperformed other units I've compared to. The antenna is also removable and an external antenna can be used. This really improves reception if you need it. Even though it's been around a while now, I highly recommend it. Or, possibly there is an even newer unit based on the 48? Steve |
triblet |
posted 03-15-2002 11:36 AM ET (US)
On the 48, you don't need an external antenna, just a piece of the right coax (dunno which) with the right connectors (BNC IIRC) to relocate the removeable antenna. Chuck |
sklein |
posted 03-15-2002 05:47 PM ET (US)
Relocating the same antenna only improves performance if the handheld is not out in the open. The optional external antennas that Garmin has available, however, will improve the reception. |
Barry |
posted 03-15-2002 07:40 PM ET (US)
I purchased a Garmin GPSMap 76 off of eBay for $290 about 2 months ago. It came with a data cable so I immediately downloaded the latest OS to my PC and then uploaded that to the GPS. Very easy. So far the unit has worked very well in the car and on foot (the boat is still in storage). The included base map with major US roads has proved very useful when driving around. Since I was going through the AA's, I purchased a "Digital Camera Power Pack" from Radio Shack for $23 that included a compact 13-hour Ni-Cd/Ni-MH charger and 4 AA Ni-MH batteries. Later when I realized that while running in battery saver mode that WAAS was disabled, I purchased a Garmin Cigarette Lighter Adapter off of eBay for about $12. Now I just need to add a socket to the Montauk. The unit seems very durable. It has survived being dropped down a flight of stairs. I was surprised that I dropped it because the unit has a rubber coating and a very "sticky" feel. In fact once I set it on top of the minivan, forgot I put it there, and then drove to a nearby park to go hiking. It was still right where I left it when I got there. I did look at the Magellen Meridan units before I purchased. They had several advantages including more memory, slightly larger screen, and lower cost. The Garmin has better screen resolution (180x240) compared to the Magellan (120x160), appeared to support more mapping software (I couldn't find any marine maps for the Magellan), and supports an external antenna. For review of these models and others check out this site www.gpsinformation.net . Good luck, |
Pat Smith |
posted 03-15-2002 07:57 PM ET (US)
take a look at www.thegpsstore.com.They have good links to compare units.-Pat |
triblet |
posted 03-15-2002 11:23 PM ET (US)
Radio Shack chargers vary from decent to abysmal depending on who they are buying from this week. A number of their "smart" chargers have been "dumbkopfs". They charge at a high rate for a fixed amount of time. This will cook a battery that's not pretty well discharged, and undercharge one that a higher rating than the charger was designed for. Radio Shack chargers vary from decent to abysmal depending on who they are buying from this week. A number of their "smart" chargers have been "dumbkopfs". They charge at a high rate for a fixed amount of time. This will cook a battery that's not pretty well discharged, and undercharge one that has higher rating than the charger was designed for. There are two trick four AA chargers. The I have two Maha C204Fs, and (in the mail) Chuck |
fly by night |
posted 03-16-2002 12:15 PM ET (US)
I have a Garmin GPS12 and bracket along with rechargeble Rayovac NiMH batteries and charger I bought at K-Mart. I also use the rechargable batteries in my digital camera to take pictures of the fish I don't catch. I use The Garmin Mapsource software to download GPS track info to my PC after a day of fishing or boating. |
MikeK |
posted 03-17-2002 07:19 AM ET (US)
Well, I ordered a Garmin 76 last night from Cabella's. I'm getting a vehicle mount, 12 volt power cord, case and the unit (without mapping) for $264.00. I don't think I would use the mapping, maybe I'm wrong. Thanks for all the great comments and tips, figuring this thing out should keep me pacified till the North Pole melts.... |
