  Dive ladder on a 27 Whaler
Author Topic:   Dive ladder on a 27 Whaler
Neil posted 04-03-2002 12:56 PM ET (US)   Profile for Neil   Send Email to Neil
Recently purchased a 1990 27 ft. Whaler. The engines are mounted on a Whaler Drive bracket. I would like to mount a dive ladder on the boat, but the engine bracket is a sealed unit. I affraid if I cut a whole in it to put in backing washers, I would risk water intrusion (even after it is resealed with a plate). Any suggestions on an alternative way to go about putting a dive ladder on the boat would be appreciated.
peteinsf posted 06-18-2002 12:08 PM ET (US)     Profile for peteinsf
Neil,
If it is a real whaler drive donít cut it open, there is no wood backing in the drive unit. The previous owner of my boat mounted a kicker bracket on the drive. The bolt holes cracked and the drive ended up with water in it...
Pete
Captain Brian posted 09-25-2009 12:11 PM ET (US)     Profile for Captain Brian  Send Email to Captain Brian
How did you remove the water. I have the same problem on a Whaler 27. Please send any pictures to gomango@sbcglobal.net Thank you.
Whaler27 posted 09-26-2009 03:29 AM ET (US)     Profile for Whaler27  Send Email to Whaler27
On my brothers 1991 27' Walk around with Whaler drive the previous owner mounted a kicker bracket.
We had to remove it, cut large hole in deck, dig all of the foam out of that area, install new foam, patch holes, reproduce non-skid...
Slippery Eel posted 09-28-2009 10:27 AM ET (US)     Profile for Slippery Eel  Send Email to Slippery Eel
I am using a West Marine 4 step ladder with the 11" hoops. I slide it under the hand hold railings on the gunwales and it works perfectly.
