posted 04-08-2002 08:25 PM ET (US)
If it's a 1970 21' it should weigh around 1950lbs with minimal equipment and a 150.I'm basing that weight on what my 1973 'Rage weighed coming out of the shop, after renovation. Mine is the newer model, with internal fuel, fiberglass console, and flat (not extruded or dump truck) sides.
Three items:
1 - It's a rougher riding hull then the later Outrages in that same approximate length. Upside is it runs in _very_ shallow waters.
2 - With that age hull, inspect the transom for dry rot. If any is found, either walk away from it, or be prepared to spend time/materials or about $3000 to have the transom professionally repaired.
3 - It a motor shaft that long, you'll have to install a motor bracket. You need the cavitation plate level with, if not up to 2" above the bottom of the transom. I used one by Cook, and have been happy with it. It's the manual lift one.
Good luck,
Don McIntyre
