posted 04-16-2002 02:15 PM ET (US)
I posted a request for input on a new trailer for an old 13 a few weeks back and Dick was nice enough to offer some assistance. I had called Shorelandr and they couldn't tell me the right trailer for a classic 13. I tried EZloader (dicks suggestion) and loadrite as well but noone could help tell me for sure which would work for a 13 nor would they shorten the tongue. Anyway, I got a trailer and it works great. Hauled it 500 miles at 75 MPH, so far and no problems! I had some special requests. I wanted the 1,250 # class as I haul stuff inside the boat going to my camp. Stock trailers were 18 feet and it had to fit in my garage (custom short tongue), I wanted to upgrade to 5.30 x 12 load range C tires off the bat.
After trying all three manufacturers, I held my breath and went to my local (non-Whaler) boat dealer and thru their pull w/ Shorelandr' Pennsylvania fabrication facility, I was able to get what I wanted. Very happy with it. Thought you would want to know the specs as purchased...
Shorelandr SLB-14-TM Galvanized
Custom tongue (shortened 2')
Upgraded to 5.30 x 12 load range "C" tires
Bearing buddies (think they are standard equip)
The dealer set it up all screwy so I put it up on jack stands and realigned the bunks. Proper set up as follows:
(1)Bunks parallel and 24 1/2", Outside-to-Outside, which allows the bunks to align easily inside the "fins" at the stern of the 13. Plenty of stability as there is a tie-down ancor point on the outside rail of the trailer, by the tail lights (tiedowns from there to the lifting eyes)
(2) bunks at least 5 1/2" above the trailer. (allows sponsons to clear when launching)
(3) leave the "bunk canting" bolts loose till the boat is on the trailer so bunks conform to the "v"shape of the hull, then get under and tighten.
(4) Even with the tongue shortened, the back hatch of our FourRunner (Honey-pie's suburban housewife assault vehicle) clears winch stand by at least a foot.
These specs should be posted to Reference section. Will suggest to JimH.
