  Inspection Plates
Author Topic:   Inspection Plates
Neil posted 04-28-2002 12:00 AM ET (US)   Profile for Neil   Send Email to Neil
I have a 1990 27 ft. Whaler that has a cracked pry-out deck plate. I went to both West Marine and Boat U.S., but they don't carry the size I need (it seems to measure about 7 5/8"s). Any body know where I can buy them? Thanks in advance.
Neil posted 04-28-2002 12:02 AM ET (US)     Profile for Neil  Send Email to Neil
sorry about the double post. I don't know why it did that.
White Bear posted 04-28-2002 10:43 AM ET (US)     Profile for White Bear  Send Email to White Bear
I had the same problem several years ago while replacing the inspection plates in my Blackfin. Easiest solution was to get plates with a slightly larger escutcheon and reduce the diameter on a square wheel. The screw holes should be identical. If I'm not mistaken I wound up using the Bowmar brand which is now owned by Pompanette.
