posted 05-03-2002 12:25 PM ET (US)
HULL:
The primary concern on any older Whaler is the integrity of the hull structure. Look for any damage, any repairs, any signs of water intrusion. Hulls with bottom paint can conceal flaws. Check drain tubes --there are many of them-- for condition. These have a habit of rotting out and not being noticed. If the drain tube has rotted there may be water in the hull.If hull has good integrity and no signs of water intrusion, check for original condition, that is, no ham-bone modifications and no missing components (like hatch covers or cockpit panels).
Wooden components should be there. Even if in rough shape they can often be restored. At worst they can be used as patterns to make new.
For me, the more original and untouched the boat the better, unless you are looking at a boat owned by a real craftsman who also happened to be a great designer. Many home-brew additions are not quite factory quality in design and construction.
ENGINE: 250-HP is plenty of power, actually slightly over rating (240-HP). The usual engine concerns apply: lower unit integrity, compression check, general appearance.
ACCESSORIES: often overlooked is the value (or lack of value) of accessories. Hydraulic steering is a big plus. A good trailer a huge plus. Usable canvas a plus. Look for Mills canvas--it always has a silk label sewn in. Fishfinders and radios from 1981 have negative value. You have to remove them and fill the holes they leave behind.
