posted 05-28-2002 05:12 PM ET (US)
Greg,Starting in 1985 the 22' Revenge (as well as the 25' Revenge) changed to the Revenge Walk-Through model. As you note the windshield changed to allow the opening center section as well as became wider allowing more room at the helm.
The bow pulpit is not necessarily standard equipment. There are a few Walk-Through models without it.
The 22' Revenge was built for outboards, either single or twin. There is also a Whaler Drive model which has a bracket and higher horsepower ratings. I believe there are some inboard/outboard models as well. There are even Gil bracket and SeaDrive versions with full transoms.
If the boat you are looking at is the older Revenge model, I suspect it is a 1984 model. The HIN (Hull Identification Number) on the transom will tell you what month and year it was built as well as the model year of that boat.
