posted 06-12-2002 01:13 AM ET (US)
DC,Thanks for sending me that brochure. You are correct about the use of the term “Whaler Drive” with the 23WA. But it is Reebok using a familiar name to describe their own new boat. The bracket was made by Salt Shaker Marine. It is fundamentally different than the Whaler Drive built by Boston Whaler.
A Whaler Drive is built like a Whaler hull. Two skins are molded and joined, then filled with foam producing a single voluminous shape.
The shape of this Whaler drive is essentially an extension of the hull’s shape. It only sits about 2” higher than the bottom of the hull and thus provides extra running surface for the boat. But it also preempts the installation of conventional trim tabs.
The volume of the Whaler Drive also provides extra buoyancy to help support the extra weight of large twins while at rest or at displacement speeds. The down side of all this is that the extra running surface contributes extra drag as well.
On the other hand, the Salt Shaker bracket is much closer to what we think of as a motor bracket. It runs clear of the water’s surface and does not contribute any drag while the boat is on plane. This may allow a faster top speed. I think lhg would agree with this.
There’s also room under there for trim tabs, which may be needed since there isn’t that extra running surface.
I’m not sure but the Salt Shaker bracket may weight less than the Whaler Drive too.
The Whaler drive is solid with no voids inside unless added later. The only things running inside of them are the enormous mounting bolts attaching it to the hull.The Salt Shaker bracket is much more mechanically integrated into the hull with passages running into the hull below the waterline for hoses & cables.
I believe all the Van Lancker designed Whalers built during Reebok’s ownership got these Salt Shaker Marine brackets if they got anything. The Whaler Drive was still made for the Classic hulls at least until the end of the 1980’s . Some Classic hulls like the 25WA and the 27WA were also fitted with Salt Shaker brackets in the 1990’s
To tell the difference between the two, look at two things:
1) The shape of the corner. The Whaler drive will be rounded, the Salt Shaker bracket is more square.
2) The Whaler Drive fills almost all the space behind the transom. The Salt Shaker bracket leaves room for trim tabs.
