  Up or Down While Trailering?
Author Topic:   Up or Down While Trailering?
Eagleman posted 06-12-2002 11:15 PM ET (US)   Profile for Eagleman   Send Email to Eagleman
New boat has twin 200 Merc's whats the correct position to have then in while trailering? This is the first set of Merc's. previously always had Johnson or Evinrude's.
Thank you
Dick posted 06-12-2002 11:50 PM ET (US)     Profile for Dick  Send Email to Dick
It's the same with all brands of motors.
If they won't hit the road trailer with them down. If they can hit the road trailer with them up.
bsmotril posted 06-13-2002 09:25 AM ET (US)     Profile for bsmotril  Send Email to bsmotril
The bracket on the motor is not designed to take a load while trailering. It is there to prevent the hydraulics from leaking down while the boat is parked. The motors likely will hit in the down position. I have twins on my Conquest and rigged up a couple of transom savers that work well. I bought a pair of the adjustable transom savers that cradle the lower unit on one end, and have a "U" shaped casting on the other end that typically goes over the rear most center roller on the trailer. I bought a couple of rubber "V" bow blocks that are used for a trailer bow chock. It will monunt between the "U" bracket on the transom saver. Drill a hole through the "U" and use a long bolt to hold it in place. That "V" block now rests an the bottom rear trailer crossmember and the transom savers cradle the engines which are tilted up about 40 degrees from vertical for road clearance. I've trailered my boat this way since '98 about 1000 miles/yr over some nasty roads with no problems or signs of stress cracks anywhere. I also use good ston rear tiedown straps so the boat does not move relative to the trailer. A picture of the transom saver I used (unmodified) is @
http://www.bartswatersports.com/catalog.asp?P=5711
The Bow block that fits inside the lower "U" bracket is:
http://www.boatus-store.com/browse/item.asp?CFSR=1&IID=18707
BillS
lhg posted 06-13-2002 06:11 PM ET (US)     Profile for lhg
Since we have the same boat, trailer & engines, see Cetacea Page 11, 4th picture, for my engine trailering position. This is the spot where the power trim first rests the engines on the "trim" running rods (with the big ball bearing on the end), when coming down from the unsupported "tilt" positions. You can tell when you're in this mode by the change in trim speed, and the sound. In this position, the engine is as high up as possible, but still firmly supported.
David Pendleton posted 06-13-2002 07:53 PM ET (US)     Profile for David Pendleton  Send Email to David Pendleton
And for you I/O folks, trailer with the drive UP and use trailering clips on the rams.
Dave
