  HELP with ANY 1987 "Whaler 27" info
Author Topic:   HELP with ANY 1987 "Whaler 27" info
DrAlan posted 06-25-2002 09:43 AM ET (US)   Profile for DrAlan   Send Email to DrAlan
Purchased a used Whaler 27 (26'7") V birth, and can't find much info on design, specs, retrofits, etc., even from Whaler themselves. For instance, between the inner wall and outer hull, 6", has no foam or frame work but for a 1"x2" at the base, which has come loose. Thus the inner wall has separated from the floor (repair options?). And I would like to mount scuba tank racks, but to what?
Also, a source for replacement/repair parts, like I can't find the little reverse "scoop" (for creating a water flow under way to pull the water out of the bilge areas..) Whaler mounted in front of the drain holes (3) on the bottom of the boat? Any suggestions?
bigz posted 06-25-2002 11:55 AM ET (US)     Profile for bigz
The little 'scoops' as you refer are actually just ss clam shells available in a few sizes at most marine stores --- haven't a clue what your talking about the wall coming loose from the floor -- best be more specific before I can offer you suggestions.
26'7" less pulpit, 10'Beam, rated at 600 hp, 21" draft motors up, Whaler 27 dry weight 4520lbs, about 10,000lbs. total swamped cap. with people,gear and motors,and has a 10 persons cap.
