Topic: Outboard storage position
mikee332 |
posted 11-30-2002 06:56 PM ET (US)
What is the proper way to store engine for the winter, up or down? Thanks.
Outraged
posted 11-30-2002 07:03 PM ET (US)
I've always been told to store it in the down position,no load on the trim cylinders taht way, for the winter and keeps water from collecting in the prop hub area. |
BugsyG
posted 11-30-2002 07:12 PM ET (US)
I store my outboard down, and I didn't fog it because I store my boat in our heated barn. Its going to be ok. |
CaptCornchowder
posted 12-01-2002 10:34 AM ET (US)
Bugsy- Foging is not a preventative for cold as much as lubricating the cylinder and pistons during long periods of non use. I can't wait for spring. cc |
ducktwin
posted 12-01-2002 10:46 AM ET (US)
Mikee332, Best to store in the down position. outboards are designed to drain when vertical.
Also, the prop bullet will not fill up with water/moisture in the vertical position. You should fog it. Fogging is a rust preventative for the delicate needle bearings and rings. Temp. makes little or no difference. |
mikee332
posted 12-01-2002 01:35 PM ET (US)
Thanks for the replies, down it is! |
andygere
posted 12-02-2002 10:57 AM ET (US)
Bugsy, Fogging isn't to protect against freezing, it's to protect against rust on the cylinder walls. Heated barn or not, It's a good ideas to fog the motor if it will be idle for several months. |
