| Author | Topic: Laptop/GPS mapping re-visited |
| Landlocked |
Perhaps a dumb idea and impossible to pull off but if it would work might be a cheap mapping alternative. Perhaps some of you computer tech types might have input to the following. We have talked in several threads about using a laptop with mapping software connected to our gps units while "whalering". The consensus has always been - computers and boats don't mix. If you were able to acquire a cheap used lap-top - say one in the 200 - 300 mhz range, would it be possible to somehow separate the screen from the cpu/base? if so, the brains could be installed inside the console and the small flat screen installed in some type of weather proof housing on the top of the console. Good mapping software can be obtained for ~$100. I would think an outdated laptop capable of running the software would be available for less than $200. With a little tinkering - you would have a color moving map for navigating. What do you think? Ll |
| kglinz |
I run Nobeltec software on laptop. I have "Daylight Display" flush mounted at the helm and the laptop stays in the cabin. The display is waterproof. I think the Maptech charts are fairly inexpensive and come with some viewing software. Nobeltec uses vector charts which are designed for computers and are really great. Check their web sight. Kemp Lindsey |
| skeepyjack |
That what I have on my 17' Newtauk, I got the old HP omnibook 800CT,(pentium 175Mhz) 10" color screen connected to Garmin handheld etrex legend (WAAS, 10 feet accuracy)for under $200. I also bought the Garmin Mapsource Blue-chart CD for $130 with all depth and contour of your region blue waters and rivers (mine it covers from north of SF bay down to Cabo Mexico). Garmin allowed to down load the charts into my etrex too, so I can use it as standalone handled or I can connected to my laptop and turned it to the color chart-plotter. Only draw back of my setup is the laptop screen glazing, therefore it's hard to view on the day light if you don't have a proper shade covering. If you hunt for the used laptop, looking for a matrix screen rather than LCD, CPU speed is not critical as long as Pentium. If you want more detail, trick and trade then email me. |
| triblet |
Hardest problem is keeping everything dry. And skeepyjacks ides only works if you have
| David Jenkins |
On long trips I take a laptop with Nobeltec Visual Series and DeLorme Road Atlas. I velcrow the computer where it is not likely to get wet. It is fragile, but so far I have not had any problems. The 15" active matrix color screen is wonderful. |
| Landlocked |
Thanks for your input. I use Topo USA and TOPO Tennessee all the time with a lap top and my Magellan GPS. Work great. Having the laptop onboard is a bit awkward and I contantly worry. I guess I'm looking for a way to keep the electronics under the console and just have the screen up-top. I wouldn't mind spending a couple hundred bucks on an old laptop If I could somehow disconect the screen from the base unit and run a cable to the CPU. KGlenz, Can you tell me more about the "Daylight Display"? Size, cost etc. Might serve my needs. I assume you just connect it to a port on the back of the laptop. Ll. |
| Landlocked |
Wow, found the site for "daylight display". Look nice but I would imagine they are a little rich for my blood. Ll. |
| kglinz |
http://bigbaytech.com/specialized.html Here's where I buy. They really have good equipment Kemp Lindsey |
| Landlocked |
Thanks Kemp. Nice, but Youza - That's about half what I paid for the boat. Don't think the captain will authorize, expecially with another 1st mate on the way. Definately on my list of wants though. Think I'll stick to tinkering with my orignial idea. Maby incorporate some sort of polarized shield to help with the bright light. Ll. |
| David Jenkins |
Please let us know how it turns out. |
