posted 02-02-2003 02:21 PM ET (US)
I just bought a moisture meter at Home Depot for about $8 - and it works very well!!The one I bought is made by "Hold All". It looks like a small, plastic, cigarette pack with two prongs sticking out of it. Each prong is about a quarter inch in diameter and about eight inches long. The prongs are separated by about three eighths of an inch. The sensor is near the end of the probe, so it can actually pass through a wet spot and tell you when you've found "dry" again.
I originally assumed that the meter worked by measuring condictivity of the medium between the probes (and would therefore need both probes to work properly) - so I checked it by inserting each prong, one at a time, into a glass of water. One prong reacted to the water and the other didn't, so I snipped off the prong that didn't seem to matter using my tin snips. (The extra prong is for measuring soil PH. (With both prongs attached it was much more difficult to push the sensors all the way into the foam, and it limited the angle of insertion in tight spots).
The meter works very well - and it gave me some very good news. Most of my foam appears to be dry. The wet spot I found appears to be quite localized - but that's the topic for another thread...
