  Cutting Transducer Cable
Author Topic:   Cutting Transducer Cable
rkong posted 02-04-2003 09:33 PM ET (US)   Profile for rkong   Send Email to rkong
Has anyone done this while installing a fish finder? The reason I ask is that my new FF has a plug about 1 inch wide attached to the end of the cable. And pulling this through the tunnel has turned out to not be easy. I keep getting stuck. I'm wondering if I could just cut the cable and reattach it once I've pulled it through.
Thanks.
seasicknes posted 02-04-2003 09:44 PM ET (US)     Profile for seasicknes
Cutting the plug on the transducer cable is not recommendended.
triblet posted 02-04-2003 10:34 PM ET (US)     Profile for triblet  Send Email to triblet
It's a bad idea to cut the cable.
Taper things from fish to plug with electical
tape. A connical shale will be easier to
pull through than a blunt shape. But first
pull the fish out and push it back. Maybe it
will find a new hole.
Also, you can tell where in the tunnel it's
hanging up, and maybe you can figure out what
it's hanging on and wiggle that. Say the
gas hose on a Montauk comes into the tunnel
about half way.
bsmotril posted 02-04-2003 11:11 PM ET (US)     Profile for bsmotril  Send Email to bsmotril
While making the pull, have a couple of friends put tension on each end of the cables/hoses already in the tunnel. A lot of times, that will do the trick by pulling in their slack and leaving room at the top of the tunnel for the new cable to get through.
BillS
Jerry Townsend posted 02-04-2003 11:27 PM ET (US)     Profile for Jerry Townsend  Send Email to Jerry Townsend
DON'T cut any transducer cable (fish finders, GPS) as those systems require a strict impedance match to work properly. The antenna on a fixed mount VHF radio can be cut as desired as the antenna can/must be matched for acceptable/optimum performance. ---- Jerry/Idaho
triblet posted 02-04-2003 11:59 PM ET (US)     Profile for triblet  Send Email to triblet
I asked Garmin about cutting the cable to the
antenna on my GPSMAP 162, and they said no
problem functionally if it was done well, but
it would void the the warantee because they
had no way to guarantee the quality of the
work. Since I had about 20' of coax, and
needed about 4', I whacked it off and put one
of the good Shakespere CenterPin BNC connectors
on, and if anything, the signals are
stronger (less wire).
Cable length is much more important at the
longer wave lengths (lower frequencies). I
thought that was due to standing waves
(resonances) rather than impedance (but I
found analog EE real hard. Digital was easy.)
rkong posted 02-05-2003 12:33 PM ET (US)     Profile for rkong  Send Email to rkong
Thanks for the advice! I successfully got it through with lots of wiggling and moving the other wires.
