Topic: poly liner product comparison?
Cpt Quint |
posted 04-18-2003 12:59 PM ET (US)
Im "truck bed lining" my deck. Im going with a product I can roll on. Im going with one part so no mix. www.ultratuff.net or www.nonslipcoating.com? Both fit all above and claim to be polyurethane coatings. Ultratuff is water soluable and Durabak is xylene soluable. Ultratuff claims reusable once container sealed but Durabak says must use all. Obviuosly there is something different here. Can any pros out there look at these two similar products to determine the differences and recommend the better option for a working outdoor surface from a durability standpoint. One note is the ultratuff can and have customized the classic original whaler blue interior.
rb
posted 04-18-2003 01:53 PM ET (US)
Cpt, I'm no pro but I did do my entire interior with medium blue durabak. I think I posted the results under another thread you started. I would'nt say it is xylene soluable, but you can soak your brushes and do cleanups if it dos'nt set up to long. Your correct in that once you open a can you have about 3 or so hours to use it all up depending on the humidity. Once set the stuff is about as durable as cement. The medium blue is a lot lighter then Whaler blue but I really like the way it turned out. |
