  Is my motor done for?
Author Topic:   Is my motor done for?
MCano posted 05-31-2003 02:34 PM ET (US)   Profile for MCano   Send Email to MCano
Hello All,
A few months back I posted a question concerning causes that triggered the overheating alarm on my 1989 Yamaha 200. I received a lot of assistance as to possible causes and remedies to the problem, including a defective water pump and thermostat as the primary culprits. My nephew replaced the water pump and thermostats for me. Last weekend we started up the engine on its trailer. Unfortunately, the telltale water stream was still weak. The stream strengthened slightly when I gave the engine more fuel. However, after a few seconds, the telltale stream stopped altogether. We shut down the motor, and my heart dropped. It seems that a blockage has occurred somewhere in water-cooling system. I have to admit that it appears that my worst fear has happened, that corrosion has finally taken its toll on the motor. I also have to admit that I was not prudent in flushing out the motor after every use; the boat was used only in the ocean. The boat has also been moored in a slip for the 14.5 years that I have owned her, except for haul outs to apply new bottom paint and other out-of-the-water maintenance work.
We are making arrangement to take the boat to a Yamaha mechanic. Does anyone have a suggestion(s) as to what can be done, or should be done, to determine the cause of the blockage? Even more important, is there anything that can be done to clear the waterways; if it is determined that corrosion is the problem. I知 not aware of products or methods to remove blockages or clear blocked waterways. I知 sure the mechanic will also look into the possibility that my nephew did not install the pump or thermostats correctly. My nephew is familiar with boats and outboard motors; he owned a Montauk and replaced the pump and thermostats on his boat. He also had a Yamaha Maintenance Manual to guide him. However, my nephew is not a seasoned mechanic, at least he does not make a living as a mechanic.
If the worst-case scenario comes to pass, and the waterways cannot be cleared. What are my options? I certainly cannot afford to buy a new motor at this time. I believe a new four-stroke Yamaha runs around $16-17 K. I知 not familiar with outboard motor cooling systems. I guess, depending if we can determine where the blockage is located (in the heads or block), that I can replace the affected part of the engine. However, due to the age of the engine, replacement parts may not be available.
Well, I think I have written enough. I await your comments with a heavy heart LOL.
Regards,
Mario
GeneNJ posted 05-31-2003 03:25 PM ET (US)     Profile for GeneNJ  Send Email to GeneNJ
Have you checked the head gaskets? You may not have a blockage in the cooling system, rather a leeking combustion chamber may be forcing the water out of the system. A warped head can cause the same problem. Perform a compression check before giving up.
ducktwin posted 05-31-2003 04:17 PM ET (US)     Profile for ducktwin  Send Email to ducktwin
Mcano,
A friend of mine went throught the same excersize that you are with nearly the same vintage and identical horsepower Yamaha. His is on an Outrage moored at Long Beach, CA.
On tear down it was found that his cylinder walls had corroded through into the exhaust chambers. That powerhead was finished.
He ended up having the powerhead replaced and it was about $4,500.00 parts and labor. Not bad for California.
It's been fine for two years now.
Steve Leone posted 06-01-2003 04:10 PM ET (US)     Profile for Steve Leone  Send Email to Steve Leone
There are a couple of options for clearing a blocked cooling system. There is a product called "Salt-Away" that really works. Check out thier web-site. If your outboard is equiped with a tell-tall or waterpump indicator (pisser) with a removable nipple head (which I believe it is) you might want to try my Outboard Motor Backflushing device. You can purchase it through Ebay. The Backflusher has unplugged and flushed out many a clogged cooling system. Check it out. The auction ends today and I will re-post it on Thursday if you miss it. Steve
eaglet1122 posted 06-01-2003 04:31 PM ET (US)     Profile for eaglet1122  Send Email to eaglet1122
Hi, I had the same problem and tryed all the given advice above. What it all boiled down to was a .78 cent part. My impeller was bad and caused the engine to overheat. I did all that was told by my friends who were good with outboards. What I found out was where the tubing that runs from the intake on the foot thru the water pump was ok untill it reaches the head. There there is a rubber gromet that seals the tube to the head. What had happened was that the gromet had particial meltes and restricted flow. When the engine cooled the gromet opened slightly alowing a little water when first started up. As the engine reaced normal temps it caused the gromet to constrict and shout of water folw to the head. Once I replaced this all troubles went away. I hope that my lesson may help you. Stan
andygere posted 06-01-2003 05:53 PM ET (US)     Profile for andygere  Send Email to andygere
Mario,
Since the telltale was working for a few minutes, then stopped, I suspect a bit of debris, salt crystals etc. may have become lodged somewhere in the cooling system or even the telltale tube. Do you still get good water flow out the exhaust? To determine if it's just the tell tale, pull the tubing off where it goes into the powerhead, and see if you can blow air through it. If not, it may just be a clog in the telltale tubing. Some weedeater string is useful to clear this type of clog.
I experienced a similar problem on my 15 hp kicker, and it turned out that a small piece of the rubber gromet from the water pump housing had broken off and gotten lodged at the intake side of the power head. The shop that had installed the waterpump reused the old grommet, and pinched it when they reinstalled the lower unit. I fished the blockage out with a bit of stiff wire, said a few choice curse words about my former outboard repair shop, replaced the 75 cent grommet and now she pumps likle a champ. I hope yours turns out to be a minor problem as well.
RMS posted 06-03-2003 09:36 AM ET (US)     Profile for RMS  Send Email to RMS
I wouldn't judge cooling issues when running on a garden hose, too many variables. Put the boat in the water and give it a real test. When the overheat alarm went off, did the engine slow down automatically, as it should? Were you definately overhearing, or was the alarm the only indication? As others have stated, there's a good chance it isn't anything major. Keep us informed. Bob
Salmon Tub posted 06-03-2003 11:14 AM ET (US)     Profile for Salmon Tub  Send Email to Salmon Tub
Start backwards. I had the same problem once, it turned out to be the hose that goes from the telltale to the block. That was easy. Easy to check to. Pull that hose and make sure it is clean.
By the way, even though the telltale does not pee, is there water coming out from the lower unit? that is where the bulk of the water will exit during running. You can tell if it feels warm.
Also, pull the lower unit and use an air hose to blow air into the water pick-up tube. Is there back-pressure? Pull the thermostat and see if you can feel the air there. Just a few suggestions.
MCano posted 06-05-2003 10:36 PM ET (US)     Profile for MCano  Send Email to MCano
Hello All,
Thanks for the advice. We did check the tube between the block and the outlet orifice. The hose checked out OK. We were also getting good water flow from the exhaust hub. I have not yet heard from my nephew, we are having problems finding a mechanic that will be able to look at the engine. The waiting time right now is 3-4 weeks. In the interim, my nephew and I may fool around with the motor some more, taking into consideration all of your suggestions.
Thanks again,
Mario
andygere posted 06-06-2003 02:05 AM ET (US)     Profile for andygere  Send Email to andygere
Mario,
Are you using a dual feed set of earmuffs? I found that on my Mercury 200, the round single feed muffs are really not adequate. The suggestion to put the boat in the water for a test is a good one. You could just start her up while still on the trailer to see if the telltale stream shows up.
Good flow from the exhaust is a good sign. Is the water warm (indicating it has circulated through the powerhead)? One last thing, my uncle who is a mechanic has a saying: "It's always the last thing you fixed"....you may want to recheck the water pump and thermostat installation (is the impeller on the keyway, are the thermostats right side up, etc.).
Bigshot posted 06-06-2003 10:49 AM ET (US)     Profile for Bigshot  Send Email to Bigshot
Get a laser temp gun from someone and check the temp. Just because the peehole is not functioning does not mean she is hot.
MCano posted 06-11-2003 01:02 AM ET (US)     Profile for MCano  Send Email to MCano
Problem Solved. However, I do not have the details of the repair. The really good news is that my motor is not done-for, and the fix only cost me $118.00. I rarely get out of a West Marine Store for less than that. I'll post the details later.
Regards,
Mario
Bertramp posted 06-11-2003 06:58 PM ET (US)     Profile for Bertramp  Send Email to Bertramp
I just love a happy ending !! :-)
ducktwin posted 06-11-2003 11:54 PM ET (US)     Profile for ducktwin  Send Email to ducktwin
Glad to hear your engine wasn't done for.
MCano posted 06-18-2003 02:35 AM ET (US)     Profile for MCano  Send Email to MCano
Good news-Bad news.
Good news: The cause of the non-existent tell-tail stream was solved. It turned out that an "O" ring somewhere along the path of the water intake system (at the lower end I believe) had caused the blockage. The stream now is as strong as an 21 year old after a six-pack of beers!
Bad news: After launching the boat, the alarm came on again about halfway (5 minutes) to my slip.
So, one problem solved, but the original one still lingers. I do remember that one readers suggestions as to the cause of the problem did not concern the cooling system, but rather problems in the fuel system. This reader suggested that I check the primer bulb. Apparently, if air works its way into the fuel system, the alarm is triggered, or something along those lines. This specific possibility was not an issue in that I had replaced the primer bulb. However, for a while now I have notices fuel odors near the rear sump. At first I thought it was the result of all of the work that we had been doing in the motor and fuel line area. I replaced the fuel lines a while back. However, when I looked closer, I noticed a fuel leak at a coupling where the fuel line passes through the wood sump haatch. I thought to myself, could this be the problem. After replacing the coupling, and determining that the fuel leak had been mitigated, I decided to start and run the engine to see if the alarm would activate. To my surprise, the alarm did not come on after about 10 minutes of running the motor slightly above idle. I then put the motor in gear for another 5 minutes, and the alarm still did not go off. Unfortunately, I did not have time to take the boat for a cruise, the real test. So, at this time I really do not know for sure if the alarm problem had actually been solved. I知 hoping to get some time to take the boat on a sea trial this weekend to see what happens. I知 also going to try and get hold of an infrared temperature gage or some low-tech temperature crayons to make sure the motor is not overheating before I take her for a spin.
One reader asked about me about the condition of the 2-cycle oil system. I checked the oil reservoir, and it is full. No one yet has mentioned the possibility of a faulty oil injector unit (I知 not sure of the proper terminology since I知 not that knowledgeable about motors) as a possible problem. I will look into that possibility as well.
I値l keep all of you informed.
Thanks for all of your impute,
Mario
MCano posted 07-05-2003 12:33 PM ET (US)     Profile for MCano  Send Email to MCano
Hello All,
I wanted to let everyone know that it appears that my alarm problem has been resolved. Following is a recap of my ordeal:
キAbout a year ago I posted my alarm problem on this web site.
キI received quite a few responses with various opinions as to the cause of the alarm-sounding problem, most of which centered around the cooling system.
キI eventually, with the help of my nephew, replaced the impellors and thermostats.
キWhen performing an out-of-water test the telltale stream was a dribble then eventually stopped altogether.
キI had a mechanic look at my motor and he found that an O-ring had deteriorated an had become an obstruction,
キI ran a test on the motor again, and the tell-tail-stream was strong.
キI launched the boat and half way to my slip, the alarm sounded @#$%&!@#@$^%$!!!!!!
キI went back and reviewed all of the opinions and suggestions that were offered to me on the alrm problem. A couple of suggestions concerned leakage in the fuel system, resulting in air infiltration that could trigger the alarm.
キI inspected all of the fuel lines and fittings of the fuel system, and I found a crack in one of the fittings below the cockpit deck.
キAfter replacing the fitting I ran the engine in my slip for 30 minutes without the sounding of the alarm. I did not have time to taker her on a sea trial until the following weekend,
キThe following weekend I ran the motor at the dock in neutral and in gear for another 30 minutes with no alarm. I finally took a one-hour harbor cruse without incident.
So, it appears that my alarm problem has been solved. It would be difficult to conclude that the leaking fuel line was the sole culprit for the sounding of the alarm because replacement of the impeller and thermostats were well over due. In addition, the leak at the fitting was hidden but obvious, so why did I not notice this condition earlier is a mystery. I did notice a considerable loss in fuel when I looked at my fuel gauge recently, but since the boat sat unused for nearly a year, I had no reason to look at the gage. None-the-less, I cannot ignore the fact that even after replacing the impeller, thermostats and O-ring that the alarm still sounded. So, I have concluded that the fuel leak was definitely a problem, but that the other engine components also were also likely contributors to the sounding of the alarm.
I think that one thing is for certain, that this site was very helpful in the resolution of my problem. If it were not for the two gentlemen who痴 fuel line diagnosis had not been mentioned, I would still be scratching my head. I suppose during this entire process would have been shortened if I had broken down and had taken my boat to a mechanic. But, that痴 water under the bridge now.
Anyway, thanks for all of you that had made suggestions.
Regards,
Mario
