posted 06-26-2003 12:56 PM ET (US)
Thanks for the info Morocco. Glad to see you are close by also. I will try the web site you suggest. Below you will find some remarks which I had received off another web site where a Bennett sales person gives his opinion. Any thoughts to this out there???
posted 06-25-03 05:54 PM
Now I am torn. I was all set on Bennett Tabs when I was informed from another boat owner about Lenco all electric tabs. I am told that the performance is just as good as the Bennett Tabs and reliability is much better as there is only one wire to go bad and not a whole hydraulic system. The unit cost is the same but installation is much easier. Can I get some feed back on this from anyone? How about from Tab Man, do you agree???
Posts: 4 | Registered: 06-24-03
Tabman
posted 06-25-03 10:32 PM
Outranger,
As you posted above I work for Bennett Marine and you of course should keep that in mind when asking my opinion. But since you asked:
The Lenco Trim Tabs do indeed install a little bit faster but both are easy to install. But the faster installation of the Lenco Trim Tabs comes at a price, longevity. Simply put they will not last as long. Compare the warranties. Lenco’s warranty is now three years. In the past it was three years, then for a couple of years the warranty was reduced to 1 year, then last year it was moved back to three years. Also in the last issue of Trailer Boat Magazine it was reported that Lenco will not honor their warranty if the Trim Tabs are left in the down position when the boat is in the water.
Bennett Trim Tabs warranty has been Five Years for the last 15 years or so, it used to be Three years. Also ask the members of any forum if we warranty our systems after the official 5 year warranty expires? We like to stand behind our equipment.
I am not sure why the Lenco Trim Tabs would be considered to be a less complicated sytem, they have three times as many seals to go bad and about 4 times the moving parts. I know that Bennett Trim Tabs will cost far less to own over the long haul. It is interesting to note the average age of systems I help get running again vs. the average age of failure in our competition as posted at the web sites.
But of course keep in mind that I work for Bennett. But that also means I have to do my home work and know my competitors systems inside and out.
I hope this helps,
Tom McGow
Bennett Marine
