Peter
posted 06-24-2003 09:47 AM ET (US)
Jim,Prop size very much depends upon the final gear ratio. For example, in my response to you in the other thread using the prop calculator, the calculator predicted a 14" pitch was the appropriate prop based on the gear ratio of 2.08:1(2.08 flywheel revolutions will produce 1 propeller revolution) . My Johnson 48 SPL (a 2-stroke 50hp motor) has a gear ratio of about 2.4:1 and therefore requires a taller pitch. In my case, I use an 11 3/4 by 17" pitch propeller. For these two motors running at the same crankcase speed, the Honda with the 2.08:1 ratio will have a faster prop shaft speed than the Johnson with the 2.4:1 ratio. Accordingly, the Honda needs a shorter prop and the Johnson a taller prop to achieve the predicted top speed of about 37 mph (use Clark's top speed predicting formula as explained in the Reference section) assuming both motors produce the same prop shaft horsepower output. |
