posted 07-18-2003 11:32 PM ET (US)
Frontier, I still find 40 mph with a 150 hp hard to believe based on the tools our moderator has so generously provided here and data provided by others. Here's why I'm thinking that. Propeller calculator:
Yamaha 225
Using the propeller calculator and plugging in my 5200 rpm, 1.81 gear ratio for the 225 hp motor, 17" pitch and 6% slip yields 43.5 mph (about where I and Peetmin are). Same number but no slip yields 46.5 mph.
Yamaha 150
Using 40 mph, no slip, 1.86:1 gear ratio for the 150 hp motor and a 17" pitch yields a WOT rpm of 4720 (too low). With 6% slip, the rpms rise to 5022 (still a little on the low side and suggests a possible overpropped condition).
Performance predictor:
Revenge 22, Yamaha 225
In my case, using a total weight of 3750 lbs (2350 lbs for the hull, 500 lbs for the motor, 500 lbs for fuel (full tank 77 gallons), 100 lbs for two batteries, 100 lbs of miscellaneous equipment and 200 lbs of persons), 225 hp (a bit on the high side I believe for a Yamaha 225) and 180 as the hull factor yields a predicted top speed of about 44 mph. Again about where I and Peetmin are.
Revenge 22, Yamaha 150 + 9.9 4s kicker
In this case, I calculate a total weight of 3765 lbs (difference is 425lb for the 150 and 91 lbs for the 9.9 4s kicker versus 500 lbs for 225 hp motor). Using a total weight of 3765 lbs, 150hp and 180 as the hull factor predicts a top speed of 35.9 mph. Thus, to get 40 mph, either your motor is producing more than 150 hp, your total weight is less than 3100 lbs, a hull factor of 200 rather than 180 applies to your hull, or some of each of these deviations apply.
Outrage 22 Cuddy, Johnson 175
By my estimation, total weight is likely to be about 3550 lbs (2250 lbs for hull, 425 lbs for motor, 500 lbs for fuel, 100 lbs for two batteries, 100lbs of misc. equipment and 200 lbs of persons). Performance predictor using 175 hp and 180 as the hull factor predicts 40.2 mph. Mtbadfish reports 40 mph at WOT.
Frontier, I'd still like to know WOT and cruising rpms. Does your Revenge have bottom paint? How are you measuring your speed? Assuming the above demonstration of the prop calculator is accurately predicting your WOT rpm, I would move down to a 15" pitch to get your motor's rpms up to prevent lugging of the motor.
