posted 08-04-2003 10:03 PM ET (US)
[Changed TOPIC; was 22' Revenge Keel issue]You need to be very concerned over water in the interior of the Unibond hull. This is the worst problem with older Whalers.
Damage to any portion of the hull that is submerged that permits water to enter the Unibond hull can ruin a Whaler. Particularly important is damage that can allow water flowing a high speed to begin to destroy the bond between interior foam and the thin hull laminate shell.
If you have any damage to the gelcoat the reveals the interior laminate or foam of the hull, you should not delay in repairing it and making the hull water tight.
It is extremely difficult to remove water that has been entrapped in the interior hull foam. No one has reported much success with this. Various methods that have been tried include vacuum pumps and numerous drain holes.
I would haul the boat and repair any damage in a workmanlike manner.
Then I would conduct some tests to try to determine the extend of the water entrapped in the hull. With the boat on the trailer, crank the trailer tongue up high so any water will tend to flow to the stern.
Next I would do is to drill a 0.25 inch hole in the transom near the keel centerline and low. If water begins to flow out, you have an indication of water in the hull and in the wood of the transom.
Tap with a soft faced plastic hammer to find any soft areas.
Let the hull dry out as much as possible.
