posted 07-31-2008 05:58 PM ET (US)
I do not suggest rigidly anchoring abeam the beach unless the wind and current are directing the boat that way. That sort of situation will likely lead to one of the anchors dragging or high loading on the cleats/lines/whatever.Anchoring the boat "bow-out" is my suggestion with at least x2 depth for day stuff and x3-x4 for overnighting. Set the anchor deep enough and with enough line so that you can swing toward the beach and get off. And make sure you set the anchor too. You can use a sand spike to tie off a small line so that you can retrieve the boat (by pulling the stern to the beach).
When you set up for anchor you have to factor: tide, depth, current/wind, amount of rhode to put out, and what the beach is like (rocks, sand, mud).
This is what I suggest for anchors (ground tackle):
If the boat (sailboats included) can have all the important underwater components easily removed or trimmed up (outboards, rudders, etc.) then: ONE anchor.
If the boat has any shafting, props, rudders, or a keel that will get damaged then: TWO anchors.
For each anchor I go by the manufactures recommended size (or one up). If it I am going to use chain/rope rhode then the chain needs to be at least the weight of the anchor, and have 4-5 times the depth I'll ever anchor in.
Two other things I carry is a sand spike and small roller loop (for going around pilings and trees).
This is what I carry:
Montauk (17')
#1-Danforth - ~10' 5/16" chain, 100' 1/2" nylon
#2-Sand Spike
J/109 (36')
#1-Fortress (Aluminum) - ~20' 3/8" chain, 250' 3/8" dyneema
#2-None, racing boat and another anchor is too much weight, other wise a danforth
Bayline 4087 (43')
#1-Bruce - 250' 3/8" chain, 150' 1/2" nylon
#2-Danforth - 30' 3/8" chain, 250' 5/8" nylon
