ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: The Whaler GAM or General Area Transom Support for Trailering
Author | Topic: Transom Support for Trailering |
irishcreamer |
posted 09-23-2008 04:54 PM ET (US)
I have an 1989 [unrecognized acronym] 18 with a 150-HP OptiMax. I need to trailer the boat some 2,000 miles and want to ensure the engine and transom are properly supported. I have asked around the local shops and there is a lack of consensus on what best to do. The leading suggestions are: --trailer with engine in down position Please help. Thank you. |
BlueMax |
posted 09-23-2008 05:04 PM ET (US)
In short: m-y wedge! Find the one right for you here and never wonder or worry again: |
sapple |
posted 09-23-2008 05:23 PM ET (US)
This topic has been discussed many times. If you do a search you will find a lot of information and passionate debate. When I looked into this I also found no consensus with strongly held opinions in every direction. Opinions range from yes, transom support is necessary, to it is not necessary, to it can actually do more harm than good. On two occasions (with two different boats) I asked my dealer and they felt that support devices were not necessary. They do, however, recommend against trimming the motor all the way down. They suggest trimming the motor up just enough to avoid a skeg strike. |
pglein |
posted 09-23-2008 06:50 PM ET (US)
When I bought my boat in Sacramento, CA, the seller had Transom-Savers installed on both engines. To be polite, I left them on when I pulled out of his driveway. But the first time I stopped, I removed them, and they haven't been on there since. I feel that they provide nothing of value on an engine with power trim and a built-in trailer lock, and only serve to make launching more difficult and risk potential damage to the lower unit when you hit bumps. |
elaelap |
posted 09-23-2008 08:55 PM ET (US)
No brainer for me, since all three of my personal (as opposed to partnership) Whalers have had new Yamaha four stroke motors of various sizes. The manuals for each motor advise using transom savers when towing, so I do--one of those adjustable aluminum bars where one end rests over the aft roller on the trailer and which has a rubber-padded crutch which the bottom unit of the motor rests in when tilted down maybe 45 degrees from horizontal. Doesn't take thirty seconds to take off or put on, using the trim/tilt switch on the motor itself. Tony |
Chuck Tribolet |
posted 09-24-2008 03:35 PM ET (US)
Read what the engine manufacturer puts in the engine owner's manual. Some trailers (mine) have the aft cross member WAY under the In general (YMMV) tipping the engine up moves the CG of the
Bella con23 |
posted 09-24-2008 03:51 PM ET (US)
I agree Chuck. In addition to that I run a rachet strap fron the skeg to the trailer to keep the outboard from bouncing. Joe |
Tohsgib |
posted 09-25-2008 11:03 AM ET (US)
It is called a transom saver, not an engine saver. If I had an inferior boat I would worry about the transom and possibly use one, with a Whaler I see no such need. If my engine did not have PTnT to hold it steady I might use one if I could not safely clear the ground with engine fully down. Other than that I see no need for them and MANY trailers(especially alum) do not allow them to be used anyways. |
