Topic: 1995 OUTRAGE 21: Highway Towing with Toyota Sequoia
dnh |
posted 01-14-2009 02:02 PM ET (US)
I have a 1995 21 Outrage. I've towed it from SC to Ft. Lauderdale and back with an F150. I've also blown the transmission on an old Chevy Blazer towing a 18 Dauntless back to SC from Miami. I have further had the engine blow on a GMC Yukon at 180,000 miles which I drove very gingerly and towed nothing but a 15 Whaler with. So, I am very careful about it.This Sequoia is a 2004 with 71,000 miles, a 4.7-liter engine, and never towed anything. I do not want to hurt the transmission. It is rated for 6,500-lb towing. Has anyone actually towed a boat similar to the 21 Outrage with a similar model Sequoia for a long distance without any problems; Does anyone think this would be a problem? Please do not say, "there is no reason at all why this would be a problem. Your boat and trailer weigh several thousand pounds less thant he car's towing capacity" or "just get a transmission cooler and you will be fine." I am looking for real examples of people who have towed or reguarly have towed similar sized Whalers long distances with a Sequoia or similar SUV and think its ok or not ok. I've towed a lot of boats with a lot of vehicles, but I really don't want to ruin this truck for one trip. My options are to use this truck; potentially borrow the F150; or potentially borrow a 2500 series GMC pick up with a diesel engine. The last two options are a lot more difficult.
Feejer
posted 01-14-2009 02:26 PM ET (US)
I towed my 2004 Sea Hunt 202 with the same F150 with my 2005 Tundra. I think its the same motor as your's. Anyway the boat, motor & trailer had a weight of 3490 lbs when I took it to the scales in 04. The truck has a my truck has a 6500 lb limit. I never had any issues towing the boat. I knew it was back there but it towed fine. |
RJG
posted 01-14-2009 03:03 PM ET (US)
I have a 2006 Toyota Tundra Quad Cab that I use to tow a 23ft. Hydra-Sport WAC with a hardtop. I have pulled the boat to Tampa without any problem at all from Jacksonville. In fact the Toyota pulls the boat better than my friends F-150 with the 5.4 liter engine. I think you will be just fine. |
phatwhaler
posted 01-14-2009 06:03 PM ET (US)
I tow my 1996 20 Outrage with a 1999 Toyota Land Cruiser. It tows it fine without even breaking a sweat. My longest tow is from Tampa to Key West. I've done Tampa to Fort Pierce also. You should be fine. You definitely don't need a diesel pickup. Expect 9 mpg on the highway. FYI, I also have towed the same boat with a V8 Jeep Grand Cherokee and it does fine also. Gets about 10.5 mpg on the highway. keep your speed down and don't use overdrive. |
Buckda
posted 01-14-2009 06:08 PM ET (US)
dnh -Just a couple questions - when you blew the other transmissions, did you 1) change the transmission fluid at the recommended (severe duty) mileage and/or 2) change the transmission fluid when you bought the vehicle if used? The reason I ask is because I know of a lot of people who don't change their engine oil at the recommended intervals, let alone other fluids. The next question is "How fast" did you tow and "in what gear"? These are very important questions as well. You can/will burn out a very strong transmission in very short order by towing in overdrive. It is very important to keep the transmission in standard gear - not overdrive. Additionally, speeding - going faster than 60 MPH, can kill a transmission that would otherwise handle the tow just fine. Finally, a recommendation: $300 is not too much for peace of mind - you're at 71K miles now, the transmission is probably due at 100 or 150K miles - change it now, before the trip, and then change it again 30K miles from now, after the trip to get you back on the 100K schedule. For what it is worth, my F150 transmission is good for 150K miles when not towing. If you tow frequently they want you to change the fluid at 30K miles. 30K! That is a severe change in expected duty cycle for transmission fluid; and it tells me that the Ford Engineers have concerns about the fluid temperature and effects of that temperature when towing. ...and my truck is equipped with a transmission cooler and towing package... Good luck - hopefully someone else will chime in with actual, first hand reports of how this vehicle handles that boat. Dave |
dfmcintyre
posted 01-14-2009 08:12 PM ET (US)
Dave / and others - While the information you gave regarding staying out of overdrive is probably correct for Ford products, you can tow in o/d in certain GM products. Check your manual. My 2002 Yukon allows it, but also suggests that if that transmission is shifting often, dropping down to third gear is fine also. I recall reviewing my Suburban's manual (late 90's?) and that specifically stated not to tow in third, but leave it in o/d. One difference between the years that I noted is the addition of the tow/haul button on the end of the shift lever. Changes the shift points. Don |
PeteB88
posted 01-14-2009 11:03 PM ET (US)
I cannot believe towing a boat with these rigs would blow transmissions and engines. I'd be out of my mind. The Toyota shouldn't have a problem either. Dave's questions are critical - maintenance, how you drive/tow, how well you understand your gear box, engine, tachometer - towing experience. I have spent a lot of time on the highway since August going back and forth from old house to new house on a busy E-Way and 100 miles distance one way. Furthermore, I have incorporated "loops" to Detroit and back as well as other cities for work etc. Point is there are way too many foolish drivers who tow boats, trailers etc going in excess of 70 miles/hour, hot days, heavy traffic - we've all seen them. They are not only hard on their equipment they are freaking menaces to other drivers and completely unsafe. I learned how to drive when I was 10 y/o - drove in fields, parking lots all over - drove my dad's 1960 Slant 6 Dodge Panel Truck w/ 3 on the tree across the Mackinaw Bridge when I was 12, the old man riding shot gun sitting on his hemorhoid surgery cushion!!! I was lucky to refine my skills when i worked Parks and Rec and construction jobs driving trucks and equipment. Drivers must learn the limitations of their rigs - tow vehicles and whatever they pull. I go easy, rarely over 60 MPH when I tow whether pulling w/ car or occasionally w/ truck. My Camry 4 cylinder has 160,000, manual transmission, bought it used w/ about 90K, 1999, I pull the 13 and my utility trailer all the time - same clutch, no problems, no issues. I go slow and go easy on the gear box and clutch. I pay close attention to my brake pads and shoes. I have had extremely heavy loads on multiple trips w/ utility trailer all fall and still no problem, same gear box and the rest. double check your technique and driving habits. Good luck |
PeteB88
posted 01-14-2009 11:05 PM ET (US)
I meant to reference towing a relatively small boat... |
Slick 50
posted 01-15-2009 04:39 PM ET (US)
I agree with read your manual. Follow operating and maintenance procedures and there should not be a problem. You have stated that you have pulled many trailers with different vehicles, that would make me believe you are savvy about towing. I have a friend with a Tundra that has the same engine as your Sequoia. He has pulled outrageous loads through highway and city traffic numerous times with no problems. I do not know what his driving or maintenance habits are but no problems. I own an 07 Tundra that has pulled heavy loads long distances with absolutely no problem. |
dnh
posted 01-15-2009 08:49 PM ET (US)
Thank you all so much for your input on everything.It sounds like it ought not to be a problem. I've been towing boats since I used to tow my 15 Whaler with a 1985 Camry many years ago. I am also incredibly easy on the vehicles I own. For instance, the Yukon I owned still had original brakes at 170k miles. The old Blazer that blew had a lot of miles and a lot of problems before the towing. . . . I can't drive 60mph from SC to Ft. L. But, I can be careful with it. I really appreciate the tran oil recs and all. Have a great local mechanic who knows Yotas well. Going to pick up my "fun" car (1989 4Runner) from him tomorrow and will talk to him re Sequoia and transcooler / oil. In any event, looking forward to going there. Thanks again. |
scottfarm
posted 01-16-2009 10:31 AM ET (US)
(I can't drive 60 mph). You just can't help some people. |
elaelap
posted 01-16-2009 11:27 AM ET (US)
I've towed our three partnership banana-hull Revenges (two 19-footers, one 21) on heavy dual axle trailers up into the Sierra Nevada foothills without a problem with my 2005 Tacoma. The 4x4 truck with the tow package is rated at 6500 lbs capacity. It's got a four liter six cylinder motor with a claimed horsepower rating of 245, and the six speed manual transmission means no problems with auto trans overheating in that hilly terrain. When towing my personal classic 15 CC on its light, single axle trailer with that truck, I truly can't tell whether the boat is still behind me or not--my shift patterns are the same as when I'm not towing anything at all except on the steepest hills. Fuel economy does suffer however, dropping from 20+ mpg highway to around 13-15. Tony |
btb
posted 01-16-2009 12:47 PM ET (US)
I have a similar Sequoia with similar miles. I tow my 16 ft BW with it no problems. I also have flat-towed my jeep Wrangler with it. It seems to pull the jeep ok, but I am a bit concerned about the braking capacity, with no additional braking from the towed vehicle. |
hertzanationwide
posted 01-16-2009 02:30 PM ET (US)
dnh, I have towed my 1986 20' Revenge W/T with twin Yamaha outboards several times (95 miles one way) without incident. My Sequoia is an '03 with 78k on the clock. I do have the transmission cooler installed from the factory and I did have the fluids changed at 50k. The one thing I would change if I had the time is the rear springs/shocks to something with a little more height/stiffness. The truck pulled the boat along at 60 mph with no problem. |
dnh
posted 01-16-2009 08:39 PM ET (US)
ScottFarm:I appreciate your post. I have read it several times. I am still not sure how it contribues to my inquiry as to whether a 2001-2007 Sequoia can tow a 21 Outrage without risking damage to the engine / transmission. My actual quote was "I can't drive 60mph from SC to Ft. L. But, I can be careful with it." This is because people drive 80mph on 95 not 60mph. If you have some actual insight to contribute; I look forward to hearing it. Otherwise, thanks anyway for your attempt to inform me on how to operate towing vehicles. I expected a few semi-grumpy old men to post these things instead of actually trying to help me out. So far only one. I am sure a few of your friends will add to it sooon. Peace. |
scottfarm
posted 01-17-2009 08:23 AM ET (US)
I have learned from experience to take it easy towing by driving slower while towing just like several people mentioned here. If you had a temp qauge on your transmission you could see the difference 10 mph makes. I trashed a transmission on a mercury marquis trying to pull my montauk too fast in my younger days. I guess since I retired I'm just not in that much of a hurry. |
RonB
posted 01-17-2009 06:39 PM ET (US)
I have a 2004 Sequoia with 100K. I've towed my previous 2000 18 Outrage and my current 2007 Outrage 190 with this Sequoia. The Sequoia had no problems whatsoever. I did not take long distance trips but trips typically less than 100 miles with lots of mountains. Overdrive was left off, I did not speed, and kept an eye on all my gauges. I was a little paranoid at first, but the Sequoia did fine. The Sequoia will do fine. I also have a 2002 Tundra, same motor I belive albeit a little older, no problems. Pics in my profile.Rgds, Ron |
