| Author | Topic: Deducing Model Year of Yamaha Engine From Its Serial Number |
| Rio San Juan |
Hi all, I'm looking at a totally basterdised Whaler 13. The hull was built in 1964 and the interior is from an [c.1980] 13-footer. I'm having a hard time deciphering the year of the [Yamaha] engine, model number 40ELF, serial number 6h4l417275. Thanks |
| Rodger |
Yamaha made a 40ELF in 1989 so that would be my guess. |
| Rio San Juan |
Thanks Roger, searches I've run on 40 Elf all point to 89 as well. Quite possibly I jotted down a wrong number or letter when I took the serial number. |
How are you deducing the model year from the serial number? Tell us the method. |
| TransAm |
You can call Yamaha customer service and they can decode your engine serial number and convert it to year and model type. Yamaha has been happy to help in this regard. |
| number9 |
Yamaha used the last letter of the model to designate year. "F" = 1989. Prior to 1991 it was a reverse alphabetical order that skipped some letters. More recent years, 1991=P through 2005=D in normal character order. |
| TransAm |
It is widely known how to deduce the model year from the model number. The question posed in this thread is how to deduce model year from the serial number. |
A chart containing information on how to decode the model number of a Yamaha outboard motor is shown at |
| Rio San Juan |
Yamaha 40 elf 6H4L= Model number? JimH, I looked at the chart in the link that you posted prior to posting here and couldn't seem to come up with an answer. |
| Tohsgib |
Jim's is more detailed but accurate as well. Yamaha Model Designation Imbedded in the model number is the horsepower and year of the engine. The first numbers are the engine hp. |
| TransAm |
Yamaha serial numbers are generally arranged by an initial 3 alpha-numeric characters followed by 7 numeric characters. The first 3 characters are usually sequenced numeric-alpha-numeric. The last 7 characters all numeric. I do not know this to be the case in ALL serial numbers. In your case, I would first research 6h4-l417275 as a possible serial number. Your model number 40 ELF is decoded by the chart jim has provided as a 1989 40 HP, manual tilt w/electric start in 20" shaft. |
| Rio San Juan |
Doooh !!!(sound of hand slapping forehead)40ELF is way to easy! I was going into the chart using only 6H4L 417275, hence my confusion. Thanks all! |
| number9 |
TransAm, FYI, "Topic: Deducing Model Year of Yamaha Engine From Its Serial Number" may not have been the original "Subject" but the edited version, as I recall the original subject line was a bit less formal? Just adding to Rodger's answer with some explanation as the others followed with. Bill |
| skred |
Interesting: my 40 hp model is "40LTRNC" It's supposed to be a 2004, and looks like it - but what's the "C" designate? |
| skred |
Ooops - never mind... Just means "C Series".. |
| number9 |
skred, The "C" indicates a 2004, no idea what the "N" would be. Bill |
| Tohsgib |
Skred...in 2002 they started back with "A" again so your C is 2004. |
| number9 |
Here's a link to a more complete list of year codes for Yamaha in MS Word. http://personal.inet.fi/yritys/anymec/US&CANADA%20IDENTIFICATION.doc Bill |
| number9 |
Found a couple of other handy links. Not the most current or easiest to navigate but much info. Bill 2006 Yamaha Reference Guide - Click on page number for detail. Evinrude Johnson Quick Parts and Accessories Reference Guide - |
| number9 |
skred, Does your 40LTRNC have trim and tilt? Realize most do but trying to figure out that "N". Bill |
| number9 |
Found a reference for the 6H4L. The "L" indicates shaft length. The "6H4" is the Prefix Model Code indicating year the model or series was first built. http://continuouswave.com/whaler/reference/yamahaModelGuide.html |
| skred |
Number9, Yes mine has Trim & Tilt - as the model number indicates. I thought the N was the 2004 year designator. It makes sense that the C is the designator since mine is a 2004. TRLNC then becomes: Trim & Tilt, Remote, Long Shaft, ?(N)?, 2004... That N is a puzzlement... |
The 6H4 prefix in the serial number indicates 1983. (That is according to a chart I was working on some time ago; I actually forgot about that chart. I don't think it is linked anywhere on the website. I assume the search engine found it for you.) A 1983 engine seems more likely for a the engine on a 1964 boat that is "totally basterdised." [Bastardized?] |
| number9 |
Jim, Not correct. The "6H4" is the Prefix Model Code indicating year the model or series was first built/introduced not the year of the engine. In other words no significant changes since being introduced in 1983. It's still a 1989. Bill |
| Rio San Juan |
'83 or '89 the bastardized beauty is now mine! http://www5.snapfish.com/slideshow/AlbumID=502418028/ PictureID=15182818028/a=965141028_965141028/otsc=SHR/otsi=SPIClink/ COBRAND_NAME=snapfish/ |
