ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: The Whaler GAM or General Area Are these ships not top heavy?
Author | Topic: Are these ships not top heavy? |
Whalerdog |
posted 10-31-2009 09:18 PM ET (US)
[A very logn cut-and-paste of an article about a new cruise ship OASIS OF THE SEAS was posted here, with the inclusion of various texts that were part of links on the page from where it was lifted, including tantalizing headlines like "Coroner: six bodies found at home," and other such nonsense. Please, if you can't write your own article, don't cut and past someone else's, and for God's sake, try not to post whacky little texts to headline stories of dead bodies. The point was, I surmise, to invoke discussion about very large ships whose superstructure rises to lofty heights, such as was reported about OASIS OF THE SEAS, said to reach "20 stories" above its waterline--jimh] |
Outrage2795 |
posted 10-31-2009 10:04 PM ET (US)
Sorry for the thread drift, but if you want see a top heavy mess then check this out... http://www.woodenboat.com/forum/showthread.php?t=99253 Kinda of like a slow motion train wreck. |
SJUAE |
posted 11-01-2009 05:38 AM ET (US)
I'm always amazed at what is possible to be shiped This company dockwise moves some stuff like this 59500 tonne semi-submersible, the overhangs are at least 40ft and the whole vessel is sunk to offload the semi-submersible cargo http://www2.dockwise.com/projects/node/432 Regards |
boatdryver |
posted 11-01-2009 09:23 AM ET (US)
These modern cruise ships have got to be more "topheavy" (I forget the correct term used in marine architecture) than, say, a fully loaded supertanker or even the cruise ships of yesteryear like QE2. I know they rely heavily on stabilization systems. In the past these stabilization systems were huge retractable gyro controlled and hydraulically powered fins which stuck out at an angle from the curve of the hull. We had a smaller version of these on our somewhat "topheavy" Hatteras 58 cruising boat and they reduced roll about 80% but did not eliminate it. Of course this type of system is useless unless the vessel has boat speed through the water. The speed required is a function of how large the fins are and how "tall" the vessel is. These cruise ships have several sets of very huge fins. I'd like to know more about the stabilization systems on the latest cruise ships like the one you are referring to. Have they come up with systems that don't require forward motion? Also what are the operational limits as to sea state? Are they mandated to avoid forecast wave height of a certain magnitude? What would happen if one of these ugly monsters lost all ability to power ahead and got caught in the troughs of some rogue waves in a storm? Maybe there is a marine architect on this site who can help discuss this interesting question JimL |
elaelap |
posted 11-01-2009 09:28 AM ET (US)
"...these ugly monsters..." You sure got that right, Jim. UHHGGGG-LEEEEEEE! Tony |
Hilinercc |
posted 11-01-2009 09:52 AM ET (US)
The "Top Heavy" term you are refering to is the called the logitudinal center of bouyancy. Although these ships appear to look top heavy, the effect is counteracted by weight of the machinery and tankage mounted low in the ship, in addition, ballast tanks are also incorporated into the design to ensure stability. (I do this for a living, so this is not opinion, its fact)
These tanks are fuel, black water (sewage), gray water (bath and sink)and seawater ballast tanks, and run the entire length of the hull. The volume of these tanks, in conjunction with the machinery spaces provide enough longintudinal stability to offset the structure above the main deck. In addition, fluid transfer systems are installed to direct fluids of each of these tanks to maintain stability as these fluids are generated (waste water) and consumed (fuel, freshwater) to maintain the required stablilty. These are all factored in through stability calculations and verified with tank testing models to ensure vessel will not "turn turtle" even before the first piece of steel is cut. |
Whalerdog |
posted 11-01-2009 12:08 PM ET (US)
Thanks for the answers! Mind boggling feat to build. Surprised it was built in Finland |
boatdryver |
posted 11-01-2009 01:27 PM ET (US)
Thanks, Hiliner, for your post. Can you comment on whether the "safety envelope" (again, sorry for the lay term) of these new cruise ships is different from other vessels, such as a tanker or bulk carrier when those are loaded? JimL |
Jerry Townsend |
posted 11-01-2009 04:39 PM ET (US)
Hiliner - Some time ago, I saw a photo of one of the larger cruise vessels - and thought that the bottom was quite flat - while the carriers seem to seem to have more deadrise. Your comments please. Thanks --- Jerry/Idaho |
Kencvit |
posted 11-01-2009 04:50 PM ET (US)
Here`s a link the the site of this cruise ship. There is a complete video gallery addressing many aspects of the ship, including the topic here...stability.They have a model in the tank and even after a major hull breach( think of the USS Cole) the ship is fine. I`ve never been on a cruise ship before. It arrives in Florida in November for its maiden trip. It would take a seven day cruise just to walk around this ship. One of the video`s comments thats not long enough to visit all the restaurants on board. |
SJUAE |
posted 11-01-2009 08:52 PM ET (US)
Hilinercc I think you mean vertical centre of bouyancy and not longitudinal or even transverse centre of bouyancy. They all have an effect on the overall stability (pitch, roll heave etc etc) of the vessel but as we are talking top heavy it's the vertical thats the most important. As further the total mass CoG is below the displacement CoG at a given draft, the greater the stability, generally and excluding any additional bilge keels and external stabilisers. Although the total lightship mass and CoG may well be quite high when the total global ship mass and CoG is calculated which includes all the operating and ballast loading this can be considerably lower. I too do this for a living and I am resposible for these calculations although the dynamics are not done by me. As a point of interest many aircraft carriers and sub marines carry a considerable ammount (100's of tonnes) of concrete and/or lead ballast in thier keels to ensure there is a sufficent negative differential between the total mass CoG and the displacement CoG, this is what gives the righting bouyancy and stability. This is why in my example by Diockwise that is carring 59.500 Tonnes is offset by several 100,000 tones of mass below the waterline by ballast It looks wrong but it works Regards |
posted 11-01-2009 11:47 PM ET (US)
The metacentric height is also important. I also imagine certain righting tests were performed to verify the design of this new cruise ship. If the ship is going to be in service in the Caribbean Sea, its design is probably not tailored to the type of sea conditions you'd encounter on a transAtlantic passage in winter. The old liners had to run all year long, including in North Atlantic winter storms, and they were designed to handle the sea state that came with it. |
SJUAE |
posted 11-02-2009 01:01 AM ET (US)
Jim Correct the loading plan and design will be tailored for it's intended cruising ground All ships have an incluning experiment which enables you to verify the CoG. This is achieved by calculating the deadload mass and CoG plus a ballast plan. The LCG and TCG can then be back calculated from the draft marks. To get the VCG by adding a known weight (concrete/lead blocks)to the port then to staboard and recording the draft marks around the ship for each case the VCG CoG can be verified. Regards |
Hilinercc |
posted 11-02-2009 10:06 AM ET (US)
Steve: Steve, I stand corrected, I meant to say "Vertical Center of Buoyancy" vice Logitudinal. Capt. Jim, you are also correct in that there is a distinct difference between a "Cruise" ship (e.g. Carnival) vice a full sea-going vessel, a Liner, such as the QM II. As such, these hulls are designed differently for sea-states for which they are anticipated to operate in. The vessel being discussed here seems to me like she will be used in the cruise market, much like a Carnival ship. (Steve, please correct me here if I'm mistaken). Boat Dryver, vessels such as tankers and bulk carriers are designed much the same way most other large vessels are, based on their intended service. |
dnh |
posted 11-02-2009 02:04 PM ET (US)
Does this Zodiak look topheavy based on the passenger's center of bouyancy? http://continuouswave.com/whaler/images/suzukiDF60TwinCams.jpg |
jmarlo |
posted 11-02-2009 06:17 PM ET (US)
Given that there is obviously a lack of ballast to offset the verticle center of buoyancy, I would say that said vessel is "top heavy." Which is fine with me. Those buoyancy devices are what I like to have on my boat to shift around to maintain stability. |
SJUAE |
posted 11-02-2009 08:29 PM ET (US)
Hilinercc No problem :) dnh Yes the VCG is high but this is the compromise you pay for having decent radar defelectors on board :) ( Sorry in advance Jim) Regards |
Kencvit |
posted 11-02-2009 09:13 PM ET (US)
dnh, ....looks to be in perfect balance and proportion |
dnh |
posted 11-02-2009 09:43 PM ET (US)
What type PFDs are those anyway? I know they are not throwable but beyond that I cannot tell. |
boatdryver |
posted 11-02-2009 10:41 PM ET (US)
I believe those are the new type VII silicon based pfd's, pioneered in Southern California |
Bella con23 |
posted 11-02-2009 11:52 PM ET (US)
My son and I just did the calculations for the Oasis of the Sea fuel economy - Based on the rated 4500 gallons of #2 diesel fuel burn rate per hour at cruise (30mph?) that works out to 1 gallon of fuel every 45' of travel. By the way this Royal Caribbean cruise ship has an amazing combined 30,000 hp in the bow thrusters alone. |
David Pendleton |
posted 11-03-2009 12:16 AM ET (US)
quote: What are you blathering about? I don't see any Zodiac... |
Hoosier |
posted 11-04-2009 11:25 AM ET (US)
Sign of the Zodiac: Gemini, the Twins.... |
Tohsgib |
posted 11-04-2009 11:43 AM ET (US)
Why is he sponging down the engine? WRONG MIDSECTION BUDDY! |
Hoosier |
posted 11-05-2009 12:20 PM ET (US)
Interestingly the Royal Caribbean site doesn't have the ship's specs. Year Built 2009 To compare to the newest Nimitz Class carrier: USS George H. W. Bush Class and type: Nimitz-class aircraft carrier |
