ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: The Whaler GAM or General Area Brunswick Hardware Quality
Author | Topic: Brunswick Hardware Quality |
SC Joe |
posted 02-20-2010 10:53 PM ET (US)
After paying a premium a year and half ago for my new 170 Montauk, I've become completely disappointed in the quality of Brunswick supplied hardware on my Whaler. A few weeks ago I found the paint bubbling up on my Mercury 90 FourStroke (that has 71 hours on it). The paint is soft and bubbling up as if the metal has started to corrode underneath the paint, right above where the lower unit attaches to the exhaust housing. Several spots are doing this on the exhaust housing, the biggest being about a 1" x 3" area. In another area, the paint on the steering arm attachment has completely peeled off, revealing a rusty and corroding piece of metal. After having my local Boston Whaler dealer send digital pictures of this to Mercury, Mercury has denied any warranty claim as they describe it as "normal cosmetic corrosion" and that this is mentioned (somewhere) in my owner's manual, as if this makes it okay. It is strange that after only 71 hours I never had any "normal cosmetic corrosion" on other engine brands I have owned like Yamaha and Evinrude while operating it in the exact same manner, in the same location. Add to this the intermittent poor running and missing of the engine (which the local Boston Whaler and Mercury dealer cannot find the fault), and I have lost all faith in both the engine and Mercury marine. Along with the engine paint and performance problems, Whaler bundles seemingly the lowest quality trailer possible with the boat. For the amount of money this size boat cost, the Karavan galvanized trailer is unacceptable: Leaf springs and odd sized tires (that required replacing this month). For the amount this package cost, no less than an aluminum framed, torsion axle trailer should have been standard equipment. At this point I'm not sure what to do with this thing. I spent what I feel is a lot of money (for a small boat) as I intended to keep it for quite a while, but at this rate, it may not last very long. |
deepwater |
posted 02-21-2010 07:10 AM ET (US)
We do tend to go boating in a rather harsh environment. Try a stiff brush and some primer before painting. I have a 4.5-HP Mercury motor that only has some paint scuffed off the skeg. That motor was bought in 1985. My Johnson 88spl (new with the Whaler) started losing paint 30 days after I got it wet. I just brush it and spray some silicone on it and drive on. |
GreatBayNH |
posted 02-21-2010 09:05 AM ET (US)
RE: "the paint on the steering arm attachment has completely peeled off, revealing a rusty and corroding piece of metal." My steering arm attachement did that too. I have a Yamaha-Mercury FourStroke EFI 90hp that came with my new 2006 Montauk 170. The rest of the engine looks brand new so I'm not too worried about a little rusty and corroding piece of metal (where is meets the steering arm). It can be easily touched up if I had the time and energy. There was however a nick in the paint on the engine at delivery and I had the dealer take care of it on the spot. RE: Karavan galvanized trailer and odd sized tires: If you mean your tires were not the same size on either side (odd pairing) I'd would have gone after the dealer that sold you the trailer. If you mean that the size of the tires are "odd" then I claim ignorance since this is my first boat and trailer and don't know what makes one trailer tire odd from another. I admit my trailer needs are not that great as I don't trailer the boat too far. I mean I have, just not often enough to give the trailer a real work out. RE: Mercury Engine: I was lucky enough to get the last year Mercury was putting Yamaha power heads in their "Mercury" FourStroke EFI 90HP engines for the Montauk 170. I'm told the engine is more Yamaha than Mercury. I have had no problems with the engine which is covered until 2011. I know there were issues with the carbed version of my engine but have yet to find posts on this web site complaining of the EFI version. As you probably have the all Mercury version of the engine I can not comment on your issues except to say, "I'm sorry". |
Hal Watkins |
posted 02-21-2010 09:27 AM ET (US)
I also have a 170 Montauk, a 2006 model year purchased new in 2007. We have over 300 hours on it--not to shabby for a [Minnesota] boat. My only real complaint is how quickly I go thru trailer tires. Around 5,000 miles I am down to near slicks on the outer half of both tires. Karavan sez, "within expected range". I carry most of the gear in the truck and try to haul minimal gas as well. Engine runs rough? Do you store it outside in the rain? As far as the engine, it has been flawless. I wipe it down with a mix of vinegar and water to remove water spots and wax it once a year. I have plenty of lower unit and hull scars from northern lakes boating but they are all cosmetic. I didn't invest in my Whaler to set and look at it; we tow it to dozens of destinations a year and boat every day we can. Good luck to us all, we are truly blessed. |
pglein |
posted 02-21-2010 10:01 AM ET (US)
I have a 1985 150 hp Johnson that has seen primarily saltwater use over it's entire 25 years. It has ZERO "normal cosmetic corrosion". |
pglein |
posted 02-21-2010 10:02 AM ET (US)
That said, this is easy to fix. Scrape off the paint, clean it up with a wire brush (or a grinding wheel) and repaint it with Mercury touch-up paint. |
tedious |
posted 02-21-2010 11:31 AM ET (US)
I'd be interested in what the Whaler marketing team would think of this (the original) post. Here's a customer with a very poor impression of Whaler's quality, who has taken time to post about his disappointment in a public forum. And the complaints have nothing to do with the boat itself, but rather with the motor and trailer which are packaged with the boat. To me, this clearly shows the downside to the "captive" packaging of motors and trailers with Whalers - Whaler ends up owning the reputation of the whole package. Tim |
posted 02-21-2010 11:32 AM ET (US)
I am quite surprised to hear of the problems on Joe's Mercury outboard motor with corrosion and flaking off of the paint. Mercury Marine makes special emphasis in their promotion of their outboard motors for their resistance to corrosion by way of the special metal alloys used and the special paint techniques employed, and they offer special protection to the purchaser by a unique corrosion warranty statement. The metal alloys, the paint process, and the corrosion warranty have previously been lauded as examples of the superiority of Mercury Marine outboard motors and as a way to distinguish them from other brands with regard to freedom from corrosion and protection by warranty from costs to remedy corrosion. I am surprised that a Mercury Marine outboard motor has problems with corrosion of the metal, flaking of the paint, and dismissal under the corrosion warranty of a remedy for those problems from Mercury Marine. |
contender |
posted 02-21-2010 11:45 AM ET (US)
Why do you think Harley Davision purchase their company back.... |
TRAFFICLAWYER |
posted 02-21-2010 12:47 PM ET (US)
Salt water environment?? My 255 Whaler uses stainless steel screws as fasteners to hold the windshield down. This causes corrosion between the two disimilar metals and a bubbled look on the windshield frames exterior and interior, I have never complained to Whaler about this. They don't give a &^%$. My next boat will be a SeaVee with Yamaha power. |
L H G |
posted 02-21-2010 02:32 PM ET (US)
Like JimH, I too am surprised to hear of corrosion problems on a relatively new Mercury. They do have the best corrosion protection in the business, and the ONLY corrosion guarantee. In the tropical (heat, humidity and strong sun) Salt conditions where I do my winter boating, most of the corroded engines I see are early Yamaha, old OMC's and black Suzukis. I have 5 old Mercury engines, all with considerable salt water use, all with Mercury's EDP paint system: 2 1985's, 1 1988 and 2 1997's. They look practically brand new, no corrosion at all. Maybe Joe's engine was painted by a guy having a bad day, or suffered some later touch up work, which can fail much more easily. And of course, we don't know how Joe takes care of his rig. As for the Caravan trailer under these 170's, I wouldn't have one either. It's about the cheapest trailer you can find. Not long ago I was talking to the owner of Continental trailers in Miami, who makes the keel roller trailers that I buy. He told me BW contacted him about supplying Whaler's galvanized trailers, but they told him his pricing was too high. |
fishinchips |
posted 02-21-2010 03:10 PM ET (US)
The corrosion problems isn't limited to merc's. I have a 2007 evinrude etec where the paint did bubble and flake off. Even had a small crack in the mid housing. Took photos of it, sent it to my dealer and he forwarded to evinrude. Evinrude took care of everything. Which I am very pleased. Ken |
SC Joe |
posted 02-21-2010 07:24 PM ET (US)
I can assure you, my "rig" is taken care of better than most peoples automobiles. The boat is washed and dried and the engine is flushed religiously after every outing, and it the boat/motor/trailer is stored in an enclosed garage. In fact, the BW dealer comments how particular I am with the boat, and how clean it always is. The odd sized trailer tires aren't different from side to side, they are an "odd" size, at ST185/80-13 they are difficult to find. Most trailer tire manufacturers do not even carry them as an option. I have recently replaced the bias ply tires with radials (that I had to special order due to the size). I'm convinced the "odd" size is a product of trying to put too much boat weight on too small of a trailer. Most other trailers in that weight capacity range use 14" tires that handle more weight, but require larger capacity axles, fenders and associated equipment. Add to that it is galvanized and has high maintenance leaf springs, and it's not difficult to point out that Brunswick was attempting to cut costs, not provide a quality trailer at a premium boat/trailer cost. I too am obviously let down with the corrosion issues, particularly after the care I give the engine. My 4 Yamaha's (and 1 Evinrude) in the past have never had any corrosion issues; since one out of the six has, I feel it must be the particular engine and not the care they received, nor the environment they are operated in. The intermittent missing the engine has often is marked with a Smartcraft error that is readable on my Northstar Explorer 660 GPS unit. It typically takes 20-30 seconds of rough running before the alarm occurs. It begins to run on 3 of the 4 cylinders, as if it has a "dead hole". The BW dealer says the Smartcraft error points to a bad coil, but after replacing the affected coil, it still occurs. In fact, I have moved the coils around expecting the problem to follow the coil, but it does not--it is always on #3 cylinder. My local BW dealer saw the stored Smartcraft error, but has not been able to duplicate it. After about an hour of running today (the first time this year) I could tell at about 2500 rpm the engine was starting to miss, but it did not do it long enough to provoke an audible alarm. As I said, it is intermittent, and I am unable to purposely reproduce it. Just as another poster stated in this thread, my next boat (which may happen very soon) will NOT be a Whaler NOR any Mercury product. |
SC Joe |
posted 02-21-2010 07:26 PM ET (US)
quote: In your opinion, is this typical or to be expected on a motor that (now) has 72 hours, has never been stored outside, and has always been flushed with tap water (regardless of having been used in slat or fresh water)? |
SC Joe |
posted 02-21-2010 07:34 PM ET (US)
quote: The first scenario isn't my issue, it is Mercury's..and if that is the case, they have failed to respond to it in an acceptable manner. I purchased the boat (and engine) new, and it has never been "touched up"..as far as I know. It certainly appears to be the paint from the factory.
The last sentence, in bold, is the big difference. |
norm |
posted 02-21-2010 09:14 PM ET (US)
When one buys a product that supposedly has a great reputation for quality and service and there is a problem of improper parts, poor build quality, manufacturing mistakes or whatever the buyer expects it to be made right. If the mfg doesn't make it right, then they lose a customer. Other folks hear of the buyers problems and judge him or her credible in their tale and seriously pause in purchasing that or those products they'd normally buy simply on reputation. I have a pristine 82 Whaler, don't really think I'd buy a 2010 replacement. |
lizard |
posted 02-21-2010 10:25 PM ET (US)
I have four late 70's to late 80's Johnson outboards, ranging from 4 hp to 90 hp. Three of the four have been used exclusively in salt water. The swivel arm on the 90 hp rusted badly before I bought it. I found a used one and it was in mint condition, so I replaced it. This is the only rust I have found on these 20-30+ year old motors. The paint on three of the four is original. I was cleaning up the back patio today and thought to myself- will the engines of today hold up to the same test of time? Those old Johnsons are rock solid and dependable. The situation with SC Joe's Mercury, as described, is completely unacceptable. The dealer should have ensured a satisfactory outcome with Brunswick. He would have lost my business, permanently. |
fishinchips |
posted 02-21-2010 11:09 PM ET (US)
scjoe: have you tried replacing #3 spark plug and also the spark plug wire? Just a chance that they could be bad. Ken |
WT |
posted 02-21-2010 11:33 PM ET (US)
SC Joe: If you suspect a fuel starvation problem but can't find it, check the liner inside your fuel lines. My liner had collapsed inside my fuel lines, thus constricting the fuel flow. Remove your hose to your fuel tank and take a look. Warren |
SC Joe |
posted 02-21-2010 11:34 PM ET (US)
Lizard: I don't know Mercury's internal dealings with their dealers, but the dealer tells me that the claim is/was denied, therefore, they are unable to do anything with it under warranty. fishinchips: The ignition coil (also called a pencil coil) is a one piece unit that is also the spark plug "wire". There are 4 individual coils, that each attach to their respective spark plug. There is no "wire", in as much as an older engine has a spark plug wires. I'm calling Mercury tomorrow, but I do not expect any better resolution than what the dealer received. |
SC Joe |
posted 02-21-2010 11:39 PM ET (US)
quote: I do not suspect a fuel starvation issue. The warning that the Smartcraft system gives is "EST 3 Short. Fault with signal from ECM to ignition driver module." I brought this same condition up last year when it occurred here: http://continuouswave.com/ubb/Forum6/HTML/002394.html |
WT |
posted 02-21-2010 11:45 PM ET (US)
I had a motor cut-off problem that was resolved by replacing the ignition switch and wiring harness. I did not isolate the problem but it is now gone. Good luck, Warren |
posted 02-21-2010 11:46 PM ET (US)
Joe's electrical diagnostic technique in which he moved the spark coil which he suspected as being defective from one position to another to see if the engine diagnostic system would detect the problem also moving to the new position was a very good method. Since the engine diagnostic system always detects a problem with the coil in the number-three position, no matter what coil is used there, the defect is unlikely to be in the coil. I think anyone with any sort of experience with electrical circuit problem solving would have been able to figure that out, and certainly a highly trained and certified (by Mercury) Mercury outboard technician should have been able to deduce that, too. I am very surprised the service technician did not investigate further into the problem to find the real defect. Perhaps when you reach a higher level representative at Mercury Marine customer service they will be able to offer a better remedy to the problem on your Mercury FOURSTROKE or Veradito outboard motor. I know your intention was not to solicit advice on how to diagnose the problem and make repairs, but, if you will forgive me, I will suggest you check the spark plug in the number three position as a possible source of the problem. Also check the engine electronics that provide the primary power to the spark coil at that position. And, finally, check the connector and any cable or wiring between the coil and the electronics. A problem in any of those circuit elements could produce an intermittent spark problem, too. |
L H G |
posted 02-22-2010 12:22 PM ET (US)
Like Trafficlawyer has indicated, I would be interested in what new boat brand Joe is planning to purchase, and what brand of engine comes factory installed on it. Hopefully it will be reliably Japanese (like Toyota!). Boston Whaler fans here would like to know. Now that he has done a great job of trashing his own 170 Montauk, the Mercury engine that came with it, and the trailer Boston Whaler furnishes, all soon to be for sale, who here would want to buy that boat for anything less than a give-away? He seems to have created his own perfect "white elephant", and it's probably not worth much with that 4-stroke Merc that doesn't run reliably. He should have upgraded to the 2-stroke 90 E-tec he was considering a while back, the last time he trashed the Merc. Then the package would have been worth more, in spite of the boat's cheap hardware and lousy trailer. Probably best to just trade it in to the new Dealer. The sooner he gets rid of it, the less people here will have to continue to listen how bad the Whaler and the Mercury really are. |
SC Joe |
posted 02-22-2010 01:02 PM ET (US)
LHG--I haven't decided yet, what if any replacement I will get. If I do get rid of it, I'll probably go back to what I know to be a quality, well built combination--Grady White with Yamaha power and an aluminum trailer. I have had that combo in the past and never been let down. And yes, I have found my Toyota vehicles to MUCH more reliable than either of the two Fords I have owned (1 was actually enough). As for worrying if anyone on here will be buying my BW, that's never really been a concern, has it? Seems like most folks here are much more content with 20 year old hulls than anything new, which in and of itself, had I researched on here should have told me something before purchasing it. And before I trade or sell it, I'll have to get it fixed, which seems to contain a growing list of things almost daily. Jimh-I had replaced the #3 spark plug and coil last July when this problem first crept up, as well as replacing them all last week as a seasonal thing. Maintenance, or even the reluctance to throw a contained amount of money at the problem, hasn't been an issue. As the local BW dealer couldn't look at it last year over the July 4th holiday, I even purchased the replacement coil myself (that they somewhat understandably would not refund me). I spoke to Mercury this morning and they reiterated what the dealer had said--corrosion, in and of itself, is not covered under warranty. It is not covered until the corrosion actually makes the affected part fail. They did say they would look at the pictures of bubbling paint again and "rethink" whether this should be covered. I'm not holding my breath for a decision change. |
TRAFFICLAWYER |
posted 02-22-2010 03:12 PM ET (US)
If Merc is still willing to mull it over that's a positive sign that you may get the relief you are due. As to your comment" Seems like most folks here are much more content with 20 year old hulls than anything new, which in and of itself, had I researched on here should have told me something before purchasing it." That is a quite accurate statement, virtually none of these posters has bought a new Whaler in the last 10 years and provide nothing but lip service to Whalers coffers while chest thumping about 15-35 year old 15'-17 footers. |
johnhenry |
posted 02-22-2010 03:59 PM ET (US)
I love my 170. I think it is a great boat. I would rather be in a 170 than an older 17 in moderate seas or chop. I Don't love the veradito-yet. I have no reasons not to like it except for 1. growing up believing that Evinrude/Johnson engines were more reliable than Mercs, but not as fast. 2. The size of the engine(huge).3 The problem with the harness grommet at the front of the engine coming loose(now fixed). As far as reliability and performance-no complaints other than you don't want to run it out of fuel-no primer bulb, takes a while to feed the gas. I decided on new, mainly to keep my maintenance time to a minimum. I had already restored an old whaler and wanted to use the boat more and work on it less. I looked at other boats and realize I could have paid less. I could have had a different trailer, and different motors, but I wanted a new whaler. Do I like the lack of choices, no, of course not, but overall it is a good package, and a great boat. Have I had any warranty or defect problems-a few, but nothing that wasn't taken care of with the minimum amount of fuss. I ask, if you would not buy a new 170, but wanted a new 17ft CC what would you buy that was comparable? What would you buy that you knew the company was going to be in business in a few years? What would you buy that you knew was going to be one of the safest boats to be in times of trouble? The answers are that there isn't anything new out there that has been PROVEN any better. |
2manyboats |
posted 02-22-2010 04:04 PM ET (US)
We have 2 whalers that are 37 years old, one that is 34 and the baby is only 33. One day I may get me one that's only 20. |
dnh |
posted 02-22-2010 04:26 PM ET (US)
Joe, I am in Mt. Pleasant as well. I am currently having my Yamaha F250 painted white to match my gelcoat on my 1995 Outrage 21 (and to differentiate it from another guy in Mt. Pleasant who bought my same boat, removed the blue stickers and replaced with red, and then put a Yamaha F225 on it). It is being done on James Island. They will be using the same process Intrepid boatworks does in Florida. Intrepids often come with color matched engines, etc. They use an Imron paint. I know you want Mercury to cover it, but it is not expensive to get it done. |
dmeswi |
posted 02-22-2010 05:28 PM ET (US)
I think Deepwater has the right idea and mindset about this matter. I have a 40 hp Mercury on my 130 Sport. After about 4 years I noticed some bubbling of the paint on the lower unit. I figured since I had about 300 hours of salt water usage there was probably some corrosion under there. I put a stiff wire brush wheel on my drill and buffed up the area, spray painted with two coats of black primer and then two coats of Mercury black paint. Now a year and 100 hours more later, looks like new. My motor was out of warranty after 1 year, so I had no option to go back to the dealer. Anyway, it only took about 30 minutes of my time to brush and spray the thing. Dennis |
SC Joe |
posted 02-22-2010 06:50 PM ET (US)
Mercury phoned me back and re-stated that they would not be replacing or repainting anything, but I could have the dealer repaint it, but I would have to pay for it. They also admitted that the steering attachment was probably chipped at the factory while rigging the engine, but that they would not be covering that repair either. I found it ironic that she then stated that if there was anything else Mercury product support could do for me, to please call them back. In summation..Mercury sucks. Their warranty also sucks..and I paid for 2 extra years of it This was the first and last one I'll ever own. |
sapple |
I am surprised to hear this. The Merc 90 fourstroke that came with my 2007 Montauk looks and runs great after two seasons and about 260 hours, including occasional salt water use. |
SC Joe |
posted 02-22-2010 06:53 PM ET (US)
quote: It sounds like Mercury needs to visit Yamaha and learn how to prep their engines for paint. No Yamaha I have ever owned (and used in exactly the same locations and manner) had any issues with the paint. I am beginning to wonder what my warranty really covers? |
SC Joe |
posted 02-22-2010 06:55 PM ET (US)
quote: If I keep the boat, I may email you to see who they are. Apparently, none of the paint is covered after it leaves the dealership, so there's no worry about voiding the warranty by repainting it. I wonder if they can blame painting the engine for a miss on number 3 cylinder? |
posted 02-22-2010 08:14 PM ET (US)
Joe--Thanks for the additional information about your efforts to resolve the poor running characteristics of your new Mercury Marine 90-HP FOURSTROKE EFI outboard motor. I am quite surprised that you have been suffering with poor performance from your Mercury FOURSTROKE engine since last July. Eight months is a long time to wait for a remedy for a problem on a new outboard motor. It is also unfortunate that you had to spend your own time and money working on resolving the defect in your new Mercury Marine 90-HP EFI FOURSTROKE motor. As far as I can tell, a defect like this should be covered under the warranty and the remedy should have been provided at no expense and in a timely manner. Waiting eight months for a remedy which has still not been provided is very patient. Even though Mercury customer service seems to have been unwilling to provide you with any remedy for the poor paint job on your Mercury Marine outboard motor, may I ask if they were able to offer any remedy to the poor running characteristics and on-going problems with cylinder three? I hope they do not adopt the same stance with this problem as they did with the corrosion. |
SC Joe |
posted 02-22-2010 09:27 PM ET (US)
Jimh-They have not been able to find the problem as they are unable to reproduce it. They saw the Smartcraft errors, but after putting 5 hours of run time (which I suspect the majority of which was idle time on a pair of muffs) said they were not able to make it reoccur. The miss happens intermittently and not under any specific set of circumstances. The engine is usually operating at or above 120 degrees, somewhere near 2200-3000 rpm. I noticed it occur last at 71 degree F ambient air, and 37 degree F fresh water. After about 30 minutes of running, it occurred for about 5 seconds, then did not do it again the rest of the day which was about another hour of run time. In the past (at least 3 times) it has lasted long enough duration to spur the guardian mode to kick in, when it begins to miss badly and will not go above about 2500 rpm. |
L H G |
posted 02-22-2010 09:48 PM ET (US)
Joe - If you'd like to sell that dog Merc 90, I'll give you a grand for it right now. As you know, that's all it's worth. I'll get it down to *MY* Verado trained Merc mechanics in Ft Lauderdale, and they'll have it fixed under warranty in about a day. I'll spend about $20 for Mercury primer and touch-up paint and fix that problem myself. I am looking for a nice 90 Merc 4-stroke for one of my Whalers, and this seems to be the ideal opportunity for me. You should consider my offer. It's a great deal for you, and you won't have to continue to use the Internet as a lever to shame Mercury into action, a common technique these days around here. Then you could sell the boat without power, and a buyer could put on a nice 90 horse Japanese engine of their choice that will run much better, and be more reliable. Everybody wins. |
SC Joe |
posted 02-22-2010 10:07 PM ET (US)
LHG-It's odd that YOUR Verado certified mechanic could fix the engine, when my local dealer is also Verado certified and on the Mercury list of preferred dealers. I also find it strange that you so easily dismiss that the paint is literally falling off an engine that is < 2 years old with only 72 hours on it, and Mercury's solution to poor paint prep is found in a can of spray paint (that I spray on). If that were a Yamaha or Evinrude, would you be so cavalier with a corrosion defect? |
L H G |
posted 02-22-2010 10:13 PM ET (US)
Well, it's a deal then? I'll take my chances with the old dog. I have a pair of brand new Mers also, on another Whaler, with the exact same mids and gear cases yours has. I'll let you know if the paint peels off in 72 hours. So far, at 20 hours, no problem. But if it does, which I guess this is what I should now expect, I'll fix it myself, since that's the deal I made with Mercury when I bought the engine (no corrosion guarantee on paint). I won't try to nickel and dime them on the web. |
SC Joe |
posted 02-22-2010 10:19 PM ET (US)
"Nickel and dime them on the web"? Once again..you and I are at opposite ends of the spectrum when it comes to the definition of words like "warranty" or "quality" or "dependable". And again, I also wonder what you opinion would be if this were a Yamaha or Evinrude. I suspect you would see things completely different through your Mercury tinted glasses. |
L H G |
posted 02-22-2010 10:37 PM ET (US)
As JimH likes to say, don't try to derail a thread by trying to introduce other brands into it. This is a discussion dedicated to running down Boston Whaler and Mercury, and using web exposure for personal satisfaction. We particularly don't want to bring Evinrude into it. Incidentally, your mechanic needs to go back to school. EFI 4-stroke overhead cam engines exist my the millions today, and fixing them is no big deal under the 5 year warranty. Sounds like a "black box" problem to me, easy to diagnose by someone who knows what they're doing. Why not try Veradoclub.com. Someone over there may be of help. |
posted 02-22-2010 10:38 PM ET (US)
Joe--Finding an intermittent electrical problem can be a difficult process. I chased an intermittent problem in a 15-year-old OMC engine for parts of two seasons. It was quite similar to your problem; an intermittent cylinder spark shut off. Of course, on a 15-year-old engine there was no supervisory controller to record the problem into its memory to be useful for later diagnosis. Like you, I worked the problem by starting with the least expensive components and replacing them in order of cost. I put in a new spark plug, new coil, and thoroughly checked, cleaned, and restored all electrical connections in the circuit. The problem persisted. Finally I had to replace the expensive component, a $350 engine spark controller assembly (called in OMC jargon a "Power Pack"). Fortunately, that did the trick. After replacing the Power Pack the engine never misfired again, and it ran beautifully. Of course, my 15-year-old OMC engine was long out of its warranty, so all repairs and component costs were on me. Your situation is quite different, with a new Mercury Marine engine still under warranty. It seems to me--and no I am not a certified Mercury mechanic and no I am not employed by Larry as "his" Mercury mechanic--as someone who has diagnosed and repaired a lot of things that run on electricity and have more than 5-volts inside them, that what ought to happen is for Mercury Marine to undertake the risk and expense and give you a new gizmo--I don't know what they call it in their FOURSTROKE engines these days--that controls the primary coil voltage to cylinder three. This is only fair, in my view. Its their engine that does not run properly, so they ought to take the risk (and cost burden) of installing the expensive replacement part to see if that is the problem. Thanks for more details about the problem and the circumstances. I would say that it sounds like it is related to heat. In that regard, running the engine at idle ought to build up heat. But if the problem only manifests at higher engine speeds, you will never see it if you only run at idle, no matter how long. ASIDE to Larry--I don't think there is anything unusual about this discussion. The Brunswick corporation makes the purchase of a Mercury Marine outboard motor a mandatory tie-in purchase with a Boston Whaler boat. Since the primary focus of these discussions are about Boston Whaler boats, it seems inevitable that there will be discussion about the Mercury motors that come with them. It would be unrealistic to think that everything ever said in these discussions would be completely and totally positive and enthusiastic about the mandatory tie-in sale of the Mercury Marine motor. Even if there were 99.9-percent satisfied customers, there will still be a couple of owners who are having a problem. I don't think it is fair to characterize the nature of this website as being some sort of exclusive hang-out for people trying to leverage Mercury Marine for a special deal. In this case, I really don't see that there is anything special being asked for, anyways. If a new motor has flaking paint and is corroding, and its running characteristics are poor, I don't see why the owner can't discuss the situation, especially when the remedy has been withheld for eight months. Maybe the solution is for Joe to get together with Larry. Larry can paint the corrosion on the motor, and get his mechanic to fix the problem in ten minutes. If that were offered to me, I would take the deal. |
L H G |
posted 02-22-2010 11:05 PM ET (US)
The problem here is not Boston Whaler or Mercury Marine. Joe didn't buy from them. It is an incompetent Boston Whaler DEALERSHIP who has failed to learn the Japanese version of SERVICE to a customer. The boat was bought from this DEALERSHIP with the Mercury motor jammed down Joe's throat, and engine he says he didn't even want. They are the ones who have the contractual obligation to make good on this engine and boat hardware. They are the ones who need to take care of him, and evidently won't? Maybe BW should get rid of them? My offer of $1000 for this old engine is still good. It would be a great deal for both of us. Incidentally, who is this non-performing Dealership? Informed people may want to know, to stay away from them. We need to keep this thread alive. I wonder how many boat sales this dealership's bad service will end up costing Boston Whaler in the long run? |
Russ 13 |
posted 02-22-2010 11:17 PM ET (US)
I agree that the paint issue is lame. On a new engine the finish should last allot longer.. As to the engine misfire, I would try a different certified Mercury mechanic/dealership... The engine is under warranty & needs to be repaired correctly. With the high cost of outboards these days, you expect to have a nice running, good looking engine on your boat, reguardless of what brand it is. |
posted 02-23-2010 12:45 AM ET (US)
Larry says:
quote: I agree. Most of the complaint seems to center on the Mercury Marine outboard motor and problems with paint flaking, the resulting corrosion, poor engine running characteristics, and the general lack of response in providing a timely remedy. As I understand it, Joe spoke directly with the Mercury Marine customer service representative, and from them learned that there was no coverage for corrosion and paint flaking under the terms of the Mercury Marine corrosion warranty protection. Clearly this has nothing to do with the Boston Whaler boat. We all generally know or believe that problems like this that occur on a new Boston Whaler boat with the boat itself are typically remedied in an expedient manner by the Boston Whaler dealer with full support from the Boston Whaler factory. |
L H G |
posted 02-23-2010 05:16 PM ET (US)
Jim, you missed the point. When Boston Whaler sells a packaged, no loose engine choice boat, they (BW) are automatically assuming the liability for the engine also. The Boston Whaler dealership is charged with the ultimate responsibility for the "package" to the buyer. If the dealer has a problem with Mercury, it's his problem, not the buyer's. To make this guy happy, the dealer could certainly have had the paint touch up work done. Just good business, whether the guy is a nitpicker or otherwise. They should also get the engine running if they have the technical knowledge, and give Boston Whaler the bill. Then Boston Whaler can work it out with Mercury. The idea of letting a dealer skip out on his reponsibility for his sale, and hide behind the manufacturer, is a joke, but an often used tactic. I just had it pulled on me recently (an incident unrelated to BW or Mercury). I'd make a legal claim agsint the dealership for failure to honor promised warranties. The real problem today is that so many dealerships are on the edge of collapse, that they can't afford, or won't, take any risks on anything. That's a sure ticket to closing your doors eventually anyway. They can't afford to cheap-out like this and still survive. |
posted 02-24-2010 08:31 AM ET (US)
Larry--I agree it would have been smart for the dealer who sold this Mercury motor to Joe to have provided a remedy for the flaking paint and corrosion. As Joe said, he thought he was buying a premium brand product. However, I can see the dealer's point of view. The dealer and the manufacturer have a relationship. The dealer should not be expected to be providing free service to remedy problems in a product he sells that contains a defect in manufacturing. To remedy a problem that is a result of a defect in manufacture of the product should be the responsibility of the manufacturer, not the dealership that sells the product. This gets to the heart of this dispute. Let's review: There is corrosion and flaking paint on Joe's Mercury Marine outboard motor. Joe thinks this is abnormal, that is, it is not a result of normal wear and tear or what one would normally expect from a new motor with only a few months of use and only 71-hours of running time. In simple terms, there is a defect in the product. It is not properly painted to protect its metal components from corrosion. Joe sought a remedy for this defect. As noted, Joe bought this defective product from a retailer, so he sought a remedy from the retailer. The retailer apparently agreed with Joe: there was a defect in the product as it was manufactured. The retailer sought a remedy from the manufacturer. The manufacturer reviewed the corrosion and flaking paint on the motor and declared it was not a manufacturing defect that was covered by the warranty. The warranty sets out what conditions determine if a defect in manufacturing is to be covered by the warranty. Apparently the warranty on the Mercury Marine motor is written in such a way that it does not consider flaking paint and corrosion to constitute a manufacturing defect that is covered. The interpretation of the warranty was made by Mercury's customer service people. It was their call. They looked at this defect and decided it was not covered. If I understand Larry's position, what should have happened was the retailer should have bailed out Mercury and repaired the defect at his expense, without any reimbursement from Mercury. I don't know if I agree with that. It might make sense in terms of keeping a customer happy. I am certain that Joe would be happy to get this defect repaired at no cost to Joe. But I don't think it is proper to suggest that this defect be repaired by the dealer at no cost to Mercury. We have to look at who is responsible for the defect in the paint. Joe thinks the defect was in the original manufacture of the product. It was not properly painted. His means the remedy should come from the manufacturer. Could the defect have been caused by the dealer? Perhaps it could have. Perhaps the dealer's service people scratched the paint off this part of the engine by being careless. If that is the case, then the remedy should come from the dealer. But, as I understand it, the defect is not likely to have been caused by the dealer. The defect appears to be a defect in the original manufacture. Therefore the remedy ought to come from the manufacturer. I do not think that a manufacturer and a dealer can have a good relationship if the manufacturer expects the dealer to repair defects in the original manufacture of the products, and do it without any reimbursement. The normal relationship between a dealer and manufacturer is to have reimbursement to the dealer for work performed to remedy defects in the product during the warranty period. Whether or not it is reasonable to shift this burden to the dealer and put the cost toward customer goodwill is a matter of business policy in the dealership. A dealer might be able to do this once in a while, but as a general policy I do not think a dealer can continue to repair at his expense defects in the products he is selling that are due to defects in original manufacture. That does not lead to a good relationship between the manufacturer and dealer. |
L H G |
posted 02-24-2010 02:22 PM ET (US)
Jim, I completely disagree with your analysis and conclusions relative to my posts, to numerous to get into. But I know one thing, I wouldn't want to buy anything from YOUR dealership! You'd have no repeat business. The dealership is supposed to have a relationship with his customer, and is the vehicle throuogh which warranty service flows. The dealer has the ability and leverage to deal with his suppliers, not the customer. This operation seems to have little interest in their customers, since it might cost them a DIME, and at the same time is incompetent at recovering from their suppiers, BW and Mercury. They also don't even have competent service people. Sounds like a bottom feeder operation to me. If they believe they are getting stiffed by their suppliers, they should find new companies to represent, like Grady/Yamaha. With the thousands of these L4NA engines out there, and other Merc Verados, etc, on new Whalers, this seems to be the only corrosion issue I've seen on ANY new Mercury. I'd sue the the dealership in small claims court for breach of advertized warranty. The dealer can bring in Mercury and Boston Whaler if he thinks he's being wronged. Perhaps some knowledgeable business people or lawyers might contribute something here. I'm not going to contribute any longer to this fellow's use of the web to take his problems public. Other people have tried this with E-tecs, and quickly, and correctly, been shut down. It's a bad web model for CW. |
deepwater |
posted 02-24-2010 06:43 PM ET (US)
Joe,,I cant see replacing a boat because the motor is having problems,,Take it back to the dealer and do a swap ,,Once when working on a water leak I tried to sweat a copper joint,,The silver solder would not take on one end,,6" away the silver held,,I polished and fluxed and it would not suck in any silver,,I cut another section of pipe and both end sweated in perfect,,The one end that would not take silver looked like it was cast copper and not extruded,,I asked a plumber about it and he said ,,IT HAPPENS,,maybe thats what your motor is ,,A happening,, |
WT |
posted 02-24-2010 07:02 PM ET (US)
SC Joe's Whaler dealer is 900 miles away. Maybe the dealer 2 miles away felt slighted? For a savings of $4-5K I would probably buy from another dealer too. Maybe if saving $4-5K on a 170 Montauk, it was a demo boat or used? "That said, I bought an '08 170 Mtk boat in Mo. and had it shipped 900 miles..and it was still cheaper than buying it from the dealer 2 miles down the street by roughly $4-5K." http://continuouswave.com/ubb/Forum2/HTML/016829.html My Boston Whaler dealer has been great, they rebuilt/cleaned my carbureators in my 90 hp Mercaha twice. My dealer even got me a FREE upgrade to the 90 Veradito but I had to pay for installation. My dealer has treated me so good, that I tow my boat 90 miles to get it serviced there instead of 2-3 miles to an authorized Mercury shop. Warren |
L H G |
posted 02-24-2010 07:37 PM ET (US)
Ah yes. I was just thinking the same thing - That we only know ONE SIDE of the story! Thanks WT. |
SC Joe |
posted 02-24-2010 08:39 PM ET (US)
LHG--I figured I'd let you rant on and on before I added any details. And not surprisingly, you did. That is correct, the SELLING dealer is about 900 miles away. As stated, I saved about $4-5000 (even with shipping) buying the boat there. The dealer 2 miles away from me, however, is NOT the servicing dealer (they are part of the same dealership chain, however). The dealer 2 miles from me only SELLS whalers. I'm not sure WHY that should matter though. The servicing dealer is familiar with the engine and the boat (as previously having been PAID to do maintenance on it), and has been turned down by Mercury for reimbursement for the paint. Mercury turned down my appeal to cover the paint as well. I'm not sure how purchasing the boat locally (and subsequently paying $4-5K more) would have made any difference to Mercury's decision to NOT fix the engine under warranty.Does that somehow void my warranty? Just as an FY, the Northstar Explorer Smartcraft monitor I installed on the boat registered about 1.5 hours on the engine when I installed it. And that installation took place AFTER I had taken it out the first time for a time period that I did not monitor. If it were a "demo" and I wasn't told (and it certainly didn't appear to be one) it wasn't a "demo" for more than about 15 minutes. Again, even if it were a demo (and it wasn't) does that somehow void my warranty in a way I am not aware? Mercury did not inform me of that when they sold me 2 additional years of warranty coverage. I have always wondered about this "selling" vs "servicing" thought. I have never found ANY dealer that wouldn't take my money. I also have never found an authorized dealer that wouldn't perform warranty work--on ANY brand boat or engine they sold. That would be counter productive, wouldn't it? What would have happened if I purchased the boat HERE, and moved 900 miles away? Should I be expected to pull the boat 900 miles BACK to have warranty work performed? Of course not. I agree completely with everything Jimh has stated. The paint on the engine is NOT the selling OR servicing dealers' responsibility--it is Mercury Marine's. Mercury Marine sponsored the warranty (as well as took my money for 2 additional years of it), NOT the selling or the servicing dealer. I can't expect ANY dealer to perform (what should be warranty work) for free. And unlike LHG, I don't. I do, however, expect Mercury to stand behind their product, and they are not. |
posted 02-25-2010 09:53 AM ET (US)
If I were a retailer and selling a product with a warranty, I would soon find out which manufacturers I wanted to partner with. If I had a manufacturer who made defective products and expected me (as the dealer) to repair them at my cost without reimbursement, I would not be a partner with that manufacturer for long. I cannot understand L H G's logic in which the dealer is supposed to stand behind the product even when the manufacturer doesn't. Yes, I understand writing off the repair as goodwill to the customer, but that is an option. There is nothing in the sales agreement or the warranty that binds the dealer to pick up the slack when the manufacturer drops the ball. I am not sure we can bash the dealer for his failure to give the customer a freebie for goodwill, while at the same time make an argument that the manufacturer should be held harmless. The manufacturer put his coverage in writing--the warranty. Also, I have to agree completely with Joe: Mercury's denial of responsibility for the defect and failure to provide a remedy under the warranty should not be linked with where the boat was purchased. If Mercury does play favorites with certain dealers, they ought to disclose that. Maybe Mercury Marine should indicate the dealers where they do stand behind their products so customers will know which ones to patronize, if it really does happen that Mercury Marine works differently with different dealers. |
prj |
posted 02-25-2010 10:31 AM ET (US)
I'm in near complete agreement with Larry on this one, though I enjoy noting Jim's search engine optimization techniques of repeatedly linking Mercury and Defect in an almost redundant manner. This is simple guys. IF there is a manufacturing defect, and IF the warranty covers such manufacturing defects, THEN the defect is covered. Despite assertions by the owner, with obvious vested interest in the outcome, and Jim who hasn't seen the engine but also seems to have a vested interest in the outcome, I don't think its clear that paint bubbling over engine corrosion IS, in fact, a manufacturing defect. Who really knows what happened to the engine? A piece of gravel bouncing off the highway could have breached the protection and given corrosion a foothold. Not that I'm suggesting Joe does this, but should Mercury also be responsible for paint finishes on motors that are regularly trailered on course gravel roadbeds? Furthermore, as Larry stated, the dealer/servicer is THE conduit between the customer and the manufacturer. I can assure you that if the dealer wanted this problem to be covered by warranty, and the request was reasonable, it would have happened. If you don't have that minimal amount of faith in the dealer's ability to advocate for your benefit and on your behalf, you shouldn't patronize them. |
SC Joe |
posted 02-25-2010 03:16 PM ET (US)
The paint bubbling is not unbonding from the metal due to rock chips, etc and water getting up under the paint; it is just bubbling from what I would guess to be poor surface preparation prior to the paint job. At this point, ALL of the paint is intact--it is just bubbling up and "soft" (Not soft as in uncured, but soft as in the bubbles of paint have a texture that will move up and down when pressed). |
posted 02-25-2010 06:24 PM ET (US)
Regarding the relationship between a manufacturer and their dealers, and how much that relationship can influence the interpretation of what is covered under a warranty, I believe there is considerable room for interpretation and influence from the dealer in the communication to the manufacturer. A dealer with a long association with a manufacturer, a well-trained service department that has been sent to the factory schools for training and for advanced levels of training, and, of course, a high dollar volume of sales--that dealer will have more influence than a dealer who might be the polar opposite: short association with the brand, no factory trained service technicians, and low dollar volume in sales. And, naturally, a customer who bought an expensive product--and here I would say a new Boston Whaler 170 MONTAUK rig qualifies as expensive product--from a dealership will be much more likely to get consideration for preferred treatment than someone who comes in from the cold with a problem. In Joe's situation he is now working through a dealership from whom he did not purchase the product. This makes him less likely to qualify with the dealer for special treatment. And, again, this is why I can't understand why the dealer has his feet held to the fire in this discussion by the critics (like L H G) who say this is a dealer-caused problem. I do not think it is reasonable to expect the dealer, who may be well aware of having lost this sale to a competitor, to step up and offer preferential treatment to Joe and solve his problem at dealer expense. None of us have seen the problem, so no one of us is more qualified to determine if the problem is truly a defect. I have been going on Joe's assessment. He says he has a motor with a two manufacturing defects. (They're the poor paint and the intermittent spark.) At issue so far in the discussion, from what I have read, is not if these are defects--that's been assumed. At issue is who should provide the remedy for the defects. If it is desired to have a discussion about whether or not poor paint is a manufacturing defect or if intermittent spark failure is a manufacturing defect, we ought to start a new discussion. I tend to agree with Joe, however, and I don't think the paint ought to be failing on a motor within a year of ownership, nor do I think failing electrical components are normal in the first year of ownership. In the discussion so far I have been asked to assume the role of the dealer and explain my business model. I have done that. Now I will assume the role of Joe and explain my expectations. They're simple. I don't expect the paint to be failing on the motor, and I don't expect the motor ignition system to be failing. These are not particularly outlandish requirements. If you review the comments from Brunswick corporation's highest level of management, their CEO, you will find that a long standing theme has been to increase customer satisfaction with the marine products. When George Buckley was CEO of Brunswick he spent a lot of time explaining (with elaborate charts and graphs) to investors and stock brokers how Brunswick's strategy was to build vertically integrated products (like this boat where Brunswick assembles the boat, the motor, the trailer, and even the electronics and other accessories into a package). By moving the integration of all these products to the factory, Brunswick said it was going to increase customer satisfaction by reducing product defects. Brunswick was going to provide a single source for delivering the boating experience to the customer, and with reduced defects the customer was going to become more satisfied. And more satisfied customers were going to become repeat customers. Now those presentations from senior management were some great presentations, but here we are with a real customer who is not very satisfied in a real world way. This is exactly the situation that Brunswick senior management said it was going to prevent as a result of building and integrating multiple products into their boats. The customer would have a single source for a remedy if there was a problem: Brunswick. How can we fit Joe's experience into this business model for Brunswick? The simplest of problems--recall that L H G says he can remedy this with $10 of paint and labor--and our customer gets the run-around from the dealer, from Mercury Marine, and from fellow boaters! My advice to Joe is to raise this problem to the next level. Call Brunswick and explain to them that you are a customer who thought he was going to get a premium product and have a better experience because of improved quality through vertical integration of the product line. Then tell them your story, and see if they will do anything to help. |
L H G |
posted 02-25-2010 08:01 PM ET (US)
I would ask all readers to ignore my comments, since they based on incomplete and incorrect information and assumptions, and do not have any real relevance to the actual situation. A total waste of time on my part. This happens many times on the these boating web sites. Partial information, or people fishing for information upon which they have no intention of acting! Joe did not tell us he had the boat shipped in from 900 miles at a huge discount, and the local dealer he was using did not sell the rig. That changes everything. Considering the lack of disclosure, causing many of us to waste our time, I'm not buying the defect complaints either. Talk about a worthless discussion....but it has successfully succeeded in giving Mercury and Boston Whaler a black eye, the original intention in order to blackmail the companies into satisfaction, and which seems to be enjoyed by many. If anyone else wants to continue wasting THEIR time on adding comments or posting, be my guest. |
SC Joe |
posted 02-25-2010 08:55 PM ET (US)
LHG writes:
quote: lol..I guess it's a good thing I didn't buy the boat used. I guess the warranty would really be worthless. I had no idea that not paying full MSRP for a boat locally (wherever that may be) was an automatic dissolution of warranty. Who knew? |
TransAm |
posted 02-25-2010 09:06 PM ET (US)
I also believe the fact that the dealer in question was passed over for another in the original purchase of this boat is a significant factor. It would stand to reason that the dealer is aware of where the boat came from, and under what circumstance. A small paint issue and small, intermittent engine hiccup are hardly worth any effort other than the bare minimum. The position the dealer has apparently taken is common in any line of business. Anecdotally, I received the same treatment when I took my jeep in for warranty service at the local dealer. I had just moved from across town, and the local dealership was not the selling dealership. I also have had the pleasure of being on the opposite end of this debate when a neighbor in my old neighborhood engaged another builder to build his home at a cheaper price. It did not take long for the other builder to discover what I had learned building other houses in the area, and the house construction began to labor. The soon-to-be neighbor began soliciting my opinion and recommendations on problems surrounding the project. I asked if he wanted to hire me as a consultant to which he responded no, he just thought I might help him out a bit. I explained I did not work for free and unfortunately could not help him. He later has someone else finish the house...a year and a half later. I suspect the expected warranty reimbursement from either Mercury or Brunswick was very small for both of these problems, and without the profit of the purchase in their pocket, the local Whaler dealership made an understandable business decision. They did not get the original sale, and there was nothing to indicate they would be the dealer of choice on any future sales. |
SC Joe |
posted 02-25-2010 09:30 PM ET (US)
Transam, let me reiterate what I gleaned from your post, and please correct me if I am incorrect. When I need warranty service, it will be best to take the boat back 900 miles to the original selling dealer, as they are the only dealer with a vested interest in fixing the engine...or at least, coercing Mercury stand up to there warranty. I'll assume this would also be the same for a used boat that I might purchase that has remaining warranty. Does this make the warranty void? This does not, of course, include something that I would actually pay for, like regular maintenance, which they'll gladly do. The servicing dealer knows I'll never buy another boat, so not performing warranty work is a waste of their time and not conducive in me ever buying another boat. My question still remains what would happen if I had moved here from 900 miles away, or the original selling dealer goes out of business? Since in that instance the warranty is now apparently invalid, should I sell the boat? |
TransAm |
posted 02-25-2010 10:06 PM ET (US)
Joe-there seems to be some debate on whether your work is covered. I am not familiar with Mercury's paint warranty nor have I had the benefit of seeing a picture of the affected area that Mercury has used to determine the warranty does not apply. If you could cite the warranty language and provide a photograph, perhaps you could make a better case for your claim here. However, my greater point is that if you had purchased the boat from the dealer, you may very well have had the boat fixed at no cost to you from the dealer whether Mercury honored the warranty claim or not. Your local dealer may very well spend hours upon hours trying to recreating a intermittant engine sputter and providing a solution. I would be willing to bet if the dealer ended up spending 15 hours spread over several repeat visits by you they will loose money on that transaction. Mercury likely offers some flat rate of reimbursement for the fix leaving the dealer to sort out the additional time they spent. As far as the "moving to the area" scenario, I suspect if the dealer knew this to be the case, you may indeed recieve different treatment. But since the dealer is likely well aware of your purchase history, they are standing firm on offering the bare minimum of service and not representing your case to Mercury with the same enthusiasm they might if you were a purchasing customer. I can think of another half dozen times this has happened to me. However, I accepted this risk up front and was prepared for this type of scenario playing out. Look at it this way...you are still several thousand dollars ahead. So why the big worry? |
SC Joe |
posted 02-25-2010 10:25 PM ET (US)
I may not have stated this, but I think the dealer has done all that Mercury has allowed them to do, both with the missing engine and the paint issue. IMO, the dealer has not been the problem with getting the engine repaired. My contract isn't with them or the selling dealer, of which they are representative acting on their behalf. Mercury is calling the shots here..not them. |
bloller |
posted 02-25-2010 10:39 PM ET (US)
I have some minor corrosion on the trim/tilt motor of my Mercury 60hp Fourstroke that is still under warranty. The motor has performed flawlessly for 102 hours so I am not inclined to seek warranty service and it probably could have been prevented if I had taken better care of it. You have over 71hrs on your motor in just a year and a half so it is not like you have not had time to enjoy the boat. Has it ever left you dead in the water? Since it looks like you saved quite a bit of off MSRP but are still not happy, why not just sell it. I'm sure there would be a buyer out that that would be very happy to own your boat. |
posted 02-25-2010 10:49 PM ET (US)
I am afraid I am a bit confused here. In one assessment the remedy to the problem is so trivial that it will only cost $10 in parts and labor, but in the next assessment the problem is so enormous that it will take 15 hours of labor to resolve. And in both cases the dealer will be insufficiently reimbursed by the manufacturer that they will never recover their true costs. If these are the circumstances of the business of being a boat dealer, they're insane. The only enterprise will less chance for profit is running a website that charges nothing to visit. |
posted 02-25-2010 11:07 PM ET (US)
Another variable in the relationship between a dealer and a manufacturer is the labor rate that the dealer is paid by the manufacturer for warranty work. My understanding is that the labor rate, that is the number of dollars per hour of labor, which the manufacturer will pay to the dealer for performing repair work which is deemed to be a remedy provided under the warranty can vary from dealer to dealer. There is not always a flat rate that applies to all dealers. A dealer that has a strong relationship with a manufacturer, whose service department is considered to be highly competent, and who has a high sales volume is likely to get a higher reimbursement for his labor in warranty work than other dealers who don't have those qualifications. This variable could perhaps influence the dealer's willingness to perform warranty work. You could see how for some dealers a warranty repair job might be less profitable than a repair which would be billed to a customer and paid at the full shop labor rate. |
TransAm |
posted 02-25-2010 11:12 PM ET (US)
quote: It would not be uncommon for this type of time to be invested into diagnosing a mysterious, intermittent problem. If I may again speak anecdotally. Years ago, my GMC Yukon XL developed an intermittent problem. Occasionally (once every 30-60 days) the engine would just die while driving normally. Obviously, this became problematic as my wife used this vehicle with kids in tow. The error codes suggested multiple causes. My mechanic spent a couple hours checking likely systems, but the problem continued. The only sure way to diagnose the problem was to have the computer scanner hooked up to the engine while the fault occurred. I have an excellent relationship with my mechanic and he suggested he drive the truck as his daily driver with the scan tool plugged in to the vehicle computer. It took 3 weeks for the truck engine to fail and record the definitive eerror code. A $25 part and $40 to install it. Perhaps that's the kind of service Joe may have encountered if the purchase was made locally. As it seems now, the Whaler dealer has absolutely no incentive to act other than the way they have. |
posted 02-25-2010 11:26 PM ET (US)
ASIDE to prj, who writes:
quote: I am not sure how I could otherwise refer to the manufacturer than by the brand name. I do not capitalize "defect", nor does capitalization make sense. I don't know what other term would be more appropriate for a defect in the product. I eschew use of "issue" to mean defect. In terms of search results, I am afraid this thread barely shows up in the results for a search on the terms Mercury and defect. It comes in at about 90th in the 117 articles that contain those terms: http://continuouswave.com/cgi-bin/sw.pl?Search=mercury+defect |
Bo Neato |
posted 02-28-2010 09:47 PM ET (US)
[Made an analogy to the current situation with Toyota automobiles.] |
deepwater |
posted 03-01-2010 07:56 PM ET (US)
[Picked up on the divergent discussion about Toyota and its recall of their products containing defects. I do not believe that our discussion of Joe's problem with defects in a Mercury Marine outboard motor will be particularly enhanced if we descend into a lengthy sidebar discussion about the personal experience of people who own Toyota automobiles.] |
deepwater |
posted 03-02-2010 12:53 PM ET (US)
Sorry I just got sidetracked |
SC Joe |
posted 03-02-2010 01:22 PM ET (US)
How ironic that I got a Boston Whaler owner's survey in my email today. I'm not certain they want to know my true feelings. |
deepwater |
posted 03-02-2010 04:16 PM ET (US)
I say answer it,, All of it,, Truthfully,,You know where the separation is,,The whaler is one thing the motor another and the dealer,,Whats the problem |
SC Joe |
posted 03-02-2010 07:14 PM ET (US)
As mentioned in another thread, unfortunately the survey had nothing to do with quality of the current crop of Whalers or Mercury engines. I don't remember Mercury even being mentioned. Back to the original subject..a representative from Whaler contacted me after seeing my original post above. After discussing it with him, he could offer no more than having my dealer repaint the area of my engine the paint is peeling off and possibly have the dealer bill Whaler instead of Mercury. Since Mercury has turned the claim down, there was nothing Whaler can officially do. It was a nice offer, but I turned it down. To be honest, I'd rather attempt to paint my engine myself. It may not look like a factory paint job when I am done, but I know I won't get paint over spray all over my engine and boat. Mercury's handling of this has been inexcusable. If the missing/running poorly problem continues, I can only imagine the run around I will get in attempting to get it fixed. I'm not looking forward to it. One thing is certain, however: I'm pretty certain I'll never buy another Whaler or Mercury product again. |
TRAFFICLAWYER |
posted 03-02-2010 07:33 PM ET (US)
X2 |
Buckda |
posted 03-03-2010 09:23 AM ET (US)
SC Joe - I've figured out why Larry wants to buy your motor from you. You see, it was delivered to you by mistake. This is a "Project Y" motor. Back in the day, Mercury Marine was working with the Yale department of Psychology in New Haven, recruiting students for special study. This top secret program resulted in certain people having "Blind Loyalty" in their motors. The program was so successful that the NSA shut them down and folded the operations of this special unit into their efforts to make the Russians love the United States. As with most government programs, it failed miserably, but the few student-loyalists remained - and of course, they needed their Mercury motors! Mercury, being the upstanding corporate citizen that it is, has been providing motors to these loyalists. Because of their blindness, however, a special system has been developed to secretly communicate with them. Braille messages appearing in the finish of the outboard. How you received one of these motors with the raised braille motors is unknown (Looks a LOT like paint bubbling, doesn't it - they fooled you!). Of course, when you contacted Mercury about such a "defect" they denied all knowledge. You'd better invest in a good metal colander, my friend. They'll be looking for you. |
SC Joe |
posted 03-05-2010 09:45 AM ET (US)
Since I have decided to attempt to repair the paint on the engine myself, I phoned Mercury to see what their approved method of paint repair is for normal "cosmetic corrosion". The person I spoke to could not immediately provide a part number of the primer, but said that it requires a primer that has a catalyst mixed with it, and that the surface should be sanded down to the metal, then painted with a gloss coat. I commented that it sounds like it needs to be done professionally, as I don't have the necessary mixing facilities, air compressor or paint gun required to mix a catalyst and primer to paint a "cosmetic corrosion issue.I then asked if this could not be done with a spray can primer, and touch up paint, and she said that she could not confirm that, but she did say that it should be painted "just like I would a car". Perhaps my line of thinking is way off base here..but for an engine that only has "normal cosmetic corrosion", should I have to have a paint shop professionally repair this? My point is that obviously, this is far beyond "normal cosmetic corrosion" if it requires this scale of repair. Mercury Marine..if you are reading this...this was the first and last time you will ever get any money from me. I recommend everyone take this approach with Mercury. |
L H G |
posted 03-05-2010 03:51 PM ET (US)
I hope other boat dealers, other boat manufacturers, and other engine manufacturers have been reading this thread and are continuously reminding themselves never to sell this guy anything, at any price. When Boston Whaler and Mercury Marine have a customer from Hell like this, who needs enemies. |
howlingdogsteve |
posted 03-05-2010 05:10 PM ET (US)
Joe, they are telling you not to paint with a rattle can. You would need a full respirator with fresh air supply and assorted other equipment to use a catalyst based paint. The previous owner (and longtime Mercury owner) of my 170 Montauk / 90 HP Mercury had been plagued by problems with the then brand new carbed version of this motor. His stalling issues continued for a little over two years. He was relentless with phone calls to Mercury and Whaler. Bottom line is that Joe spent a sizable amount of money on his purchase and between the SELLING dealer and the TWO manufacturers, they need to make it right. Remember, the selling dealer does share some culpability since he sold you the potential defective product. As far as brands, things can go wrong with ANY mechanical item so don't get too happy with your purchases. PS- I love my Whaler and Mercury. PSS- I am not interested in getting into any heated debates with anyone, so respect my right to my opinion and move on. |
SC Joe |
posted 03-05-2010 06:27 PM ET (US)
quote: "Customer from hell"--because I'd prefer the engine break at least 100 hours before beginning to self destruct? And I thought you said you weren't going to post any more about this? I think it's wonderful that Mercury has someone {you} who would buy an engine that has a running miss problem as well as having defective paint on the exhaust stack, and have absolutely no problem with them not covering the paint under warranty. I'm not sure you would be so generous with any other brand of...anything, however. Are you on the Mercury payroll or something? |
SC Joe |
posted 03-05-2010 06:35 PM ET (US)
Howlingdogsteve--I'd agree with all of your points except these:
quote: I don't believe that. They, and the employee at Whaler who contacted me, are aware that the continuing "miss" and the paint peeling off are end-it-all, deal breakers for me. Mercury at least, doesn't care.
quote: They, like the servicing dealer, would be dealing directly with Mercury for reimbursement. I don't think Mercury cares anymore what they or the servicing dealer say, any more than they care what I say.
quote: The servicing dealer has the motivation to honor Mercury's warranty--which is what they have attempted to do. As I have said before...Mercury Marine is the hold up here.
quote:That's not really an option, nor is it something I'll even attempt. They didn't sell me the warranty nor do they honor it--Mercury Marine does. |
number9 |
posted 03-05-2010 09:13 PM ET (US)
Joe, Is this on or off topic? Think my comments concerning the corrosion/paint issue will wait until you show use some before and after photos. Far as the painting is concerned I have a couple of recommendations that may get you close to what you want want. |
SC Joe |
posted 03-07-2010 01:32 AM ET (US)
I wanted to wait until I painted it to post any pics, and found it was actually much worse than I originally thought. Here is what I originally noticed-the bubbling paint on the port and front of the exhaust stack, and the paint peeling off of the steering arm attachment: Port exhaust stack: http://home.comcast.net/~joefiat/whaler/DSCN0241.JPG Front of exhaust stack: Steering arm: This is what I started with. The paint started to come off the last time I went out for about an hour (in fresh water), about 2 weeks ago: http://home.comcast.net/~joefiat/whaler/paint1.jpg Here is what the front looked like: http://home.comcast.net/~joefiat/whaler/paint2.jpg It was at this point I realized that to properly to remove all of the corrosion, I'd have to drop the lower unit to paint between the halves. Here is some corrosion I found on one of the studs: This is inside of the exhaust stack in the front. You can see the paint wasn't adhering to the metal at all: After trying to sand the port side area, I noticed that it wouldn't feather through to primer; it was just not adhered to the metal at all and there was no primer either. AS the paint was "moving" while sanding it it, I found it was easier to take a razor blade and get up under the paint until it finally got to a place that the paint was actually bonded to the metal. I used a only a razor blade to remove most of the paint on the port side of the exhaust stack, and it wasn't difficult to do. It came off in large pieces and went down to the metal without any scraping. The last time it froze here, the ice on my windshield was harder to remove than this paint! I feel sure that eventually, all of the paint I scraped of would fallen off. I caught it at just about the right time I guess. I'd say this is more than "cosmetic corrosion"- this a complete failure of the paint to adhere to the metal. There didn't appear to be any primer applied in this area. Here are some of the pieces of paint that basically flaked off. You can tell the size of them compared to the small pen screwdriver and tie wrap-they came off in pretty big srips. http://home.comcast.net/~joefiat/whaler/floor.jpg Here is what the steering arm looked like when I took off the attachment. Remember, this is what Mercury calls "cosmetic corrosion". http://home.comcast.net/~joefiat/whaler/paint7.jpg Here is what it looked like after I sanded it a bit with some 150 grit paper. Again, not much of the paint was actually adhered to the metal. All of the paint on the front peeled off, just like on the exhaust stack. It had been rusting for a while. At least I did sand into some primer on the top of the steering arm. http://home.comcast.net/~joefiat/whaler/paint8.jpg I noticed a paper inspection sticker (I guess) that Mercury had put on the lower unit from when it was new. Apparently, the paper has stuck to the engine better than the paint has. http://home.comcast.net/~joefiat/whaler/sticker.jpg After sanding the affected areas, I primed it with 2 coats of Evinrude zinc chromate primer, and then applied 2 coats of Mercury Shadow Black spray paint to the entire visible area. After that, I applied 2 coats of dupli- color acrylic enamel clear. It actually turned out pretty good, but I don't know how long it will stick. I am more concerned at this point of even more paint on the engine "falling off". |
Rick U |
posted 03-07-2010 09:19 AM ET (US)
I'de be rattled if that was my new boat. I does look like something in their paint system failed and like any system, it happens. Did you see any signs of primer on the lower unit? Was it possible the primer was black? To late now, but while everything was disassembled, treating the raw aluminum with the right liquid metal prep them the best zinc chromate primer available (not a spray can) then anything you want over that. I think Boston Whaler is making a mistake by letting this turn you into a customer from hell. My 2007 Mercury 115 lives in the saltwater full time and has no [paint flaking or corrosion] like that. |
posted 03-07-2010 09:34 AM ET (US)
Joe--Thank you for providing the images of your Mercury Marine outboard motor that show the problems with flaking paint and corrosion after only 80-hours of use. I was browsing on the Mercury Marine website and I noticed this somewhat ironic image being used as an in-line graphic on their web page about Warranty and Service. It shows a customer using spray paint to paint the gear case of a Mercury motor in precisely the same area you have painted your motor. |
posted 03-07-2010 10:12 AM ET (US)
This is a bit curious: I downloaded a document from Mercury on the Warranty and Maintenance for Joe's engine. Then I scanned the document looking for the word "paint." The only mention of paint was in regarding to not painting over the corrosion protection anodes. Joe--What does the owner's manual for your motor say about the owner's obligation to repaint areas of the motor where the paint has been lost? ASIDE: Is the owner's manual for Joe's engine available on-line? |
SC Joe |
posted 03-07-2010 06:49 PM ET (US)
Jimh-The newest owners manual is available for download here: http://www.brunswickmarineemea.com/download/dosearch/@isnew/desc; jsessionid=1ria3esj6t0al?lang=EN&categories=OUTBOARD$&mod=4 I do not see a difference between my owners manual and this one. As to what it says about paint--it mentions not painting the anodes and some verbage about anti fouling paint, but the only thing it says about my responsibility to painting is in the "Storage" section of the owners manual, it says: Protecting External Outboard Components Apparently, the paint is not warranted. The only warranty I have for paint or corrosion is that: 3 Year Limited Warranty Against Corrosion I will make it a point let everyone I see at boat shows or that I know that may be shopping for an engine Mercury's exact stance on their paint: As soon as it leaves the dealer..it is your responsibility. Knowing this, I'm a little surprised they paint the engine at all. They could only coat the engine in corrosion block type products and that would probably keep the engine from failing for 3 years. |
SC Joe |
posted 03-07-2010 06:57 PM ET (US)
quote: While sanding the exhaust stack, I did not see any traces of primer. Where I could feather the existing paint is where the existing paint was still adhered to the metal. I did see primer on the steering arm attachment. quote: The second level of paint that I was able to see while sanding the steering arm attachment point shown through as grey. I am assuming this level of paint was primer.
quote: I treated it to the best spray primer I could get, which as I see it, is better than what was there which was nothing.
quote: I don't think Boston Whaler nor Mercury really cares--They already got my money. They won't ever get any more of it. I'm glad that your paint is working as it should. I wish mine did. |
number9 |
posted 03-07-2010 09:28 PM ET (US)
Joe, Your version of the warranty left out the word operative. It's similar to the perforation clause in auto warranties. Apparently all the paint can come off the lower unit and it's still considered cosmetic.
quote: |
SC Joe |
posted 03-07-2010 10:15 PM ET (US)
quote: I actually inadvertently left out the word inoperative. Not sure what happened to my copy and paste. And you are correct; it appears Mercury doesn't warranty the paint quality, or even the paint, at all. |
L H G |
posted 03-23-2010 12:52 PM ET (US)
I assume Boston Whaler and the local Mercury dealership has this engine running flawlessly again, and cosmetically perfect? |
Buckda |
posted 03-23-2010 03:32 PM ET (US)
Larry - Please refer to Joe's post above where he fixed it HIMSELF. He posted pretty interesting photos of the legendary quality of Mercury's paint you keep talking about. Don't get me wrong - I know they have quality paint. But someone in Wisconsin was definitely asleep at the paint booth on the day Joe's motor was made. Mercury really should apologize for the treatment they gave him when it was just visually proven that they didn't prime the motor at all. Of course, they're not going to, but they should. I find it hard to believe that such an oversight occurred at an otherwise excellent production facility. Perhaps the union members weren't happy with the contract negotiations or Mercury's threat to take their jobs to Oklahoma that day? Who knows? |
SC Joe |
posted 03-23-2010 03:37 PM ET (US)
quote: You assume completely incorrect. Mercury collectively threw their hands up in the air and finally said the paint wasn't covered. Read the warranty, for what it is, carefully. Unless a part fails due to corrosion, it's considered "cosmetic" corrosion only, and not covered under warranty. As I have stated before, I'm surprised Mercury hasn't completely dropped painting their engines, just for the cost savings alone. I would imagine they could cover it in cosmoline and have it last for 3 years, even in a salt water environment, and still "honor"(lol) their warranty. As for the intermittent miss, the weather hasn't allowed me to have it out in the water any to see if it's still doing it. I went through the the engine grounds and took them all off, cleaned them and reinstalled them in a hope that may fix the problem. I'll see if it did in another week or two. If it doesn't, it will go back to the dealer and stay until it's fixed, or I'll trade it in on another brand boat and engine. I've go no allegiance to the boat or engine, aside from the fact it's paid for. |
mobey |
posted 03-24-2010 06:31 AM ET (US)
"I've go[t] no allegiance to the boat or engine, aside from the fact it's paid for." True Wisdom, indeed. |
