ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: The Whaler GAM or General Area Bimini for Guardian 17
Author | Topic: Bimini for Guardian 17 |
Rob Darrah |
posted 02-18-2010 01:25 PM ET (US)
I'm interested in putting a Westland-brand bimini top on my [1995] Guardian Law Enforcement Issue 17. I went to the Westland web site and used the closest model, 1995 Outrage 17, and the width seemed narrow. Should I use a different manufacturer? I also want to use the rear support arms so it stays up and out of the way when stowed. Any thoughts would be appreciated. Rob |
Phil T |
posted 02-18-2010 07:16 PM ET (US)
I think you want to select a Montauk and not the Outrage 17. I recall the Guardian 17 is the commercial version of the classic Montauk hull. The 1990-1995 Outrage 17 has a slightly wider beam than the classic Montauk. |
Rob Darrah |
posted 02-18-2010 07:40 PM ET (US)
If I'm not mistaken the Montauk didn't have an internal fuel tank and didn't have rear quarter seats. My boat has both. Guess I will just have to measure the mounting points. Thanks anyway. Rob |
Phil T |
posted 02-18-2010 10:18 PM ET (US)
I may be mistaken. Does your Guardian look like this: http://picasaweb.google.com/CascoBayOutrage/ 1991Outrage17I#5012257117250288306 My boat is sitting in my back yard so I could measure my bimini and rails to get you accurate measurements. |
Rob Darrah |
posted 02-19-2010 09:01 AM ET (US)
Yea, that is identical to my boat. I have different rails and bolster seat, Your boat looks really good, great shape. |
Phil T |
posted 02-21-2010 06:46 PM ET (US)
Rob, do you want measurements? |
Rob Darrah |
posted 02-21-2010 09:14 PM ET (US)
Only if it's easy for you to access. I would appreciate it. Rob |
Phil T |
posted 02-24-2010 01:29 PM ET (US)
Rob - I peeled back the tarp and climbed aboard. Here are two photos showing how the Mills Bimini is installed on my boat. http://picasaweb.google.com/CascoBayOutrage/1991Outrage17I?pli=1&gsessionid=xQb_ZvyOltWEDPfyhXtW4A#5441874485428113986 http://picasaweb.google.com/CascoBayOutrage/1991Outrage17I?pli=1&gsessionid=xQb_ZvyOltWEDPfyhXtW4A#5441874643924573442 There are 16" long tracks that are located 4 inches forward of the rear most bow rail base. The track is mounted as close to the lip as possible but still on the flat section. The raised bimini is slid to the rear stop. To stow, the bimini slides forward and then lays flat on the lip and inside the bow rail. You can store it facing aft but it blocks the rear area. The width of the track, center to center is 68". The tracks on the inside of the rail. As for height, my bimini frame measures +/- 68". Note, I am 6'2 and it is too low for me. It needs to be at least 4 inches higher so it does not block my view and stop me from ducking my head. Let me know if you have any questions or need more information/photos. |
Rob Darrah |
posted 02-24-2010 07:12 PM ET (US)
That is great info, so your top is 68 inches from the top of the side rail or the floor ? Rob |
Phil T |
posted 02-24-2010 07:24 PM ET (US)
The 68" is the height of the bimini frame itself. Since the bows are angled, I do not know the full height of it deployed. I would guess it is 5'9" from the deck. |
Rob Darrah |
posted 02-26-2010 08:30 AM ET (US)
That's great thanks. |
