ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: The Whaler GAM or General Area 21-Footer: SONAR Transducer Mounting Location
Author | Topic: 21-Footer: SONAR Transducer Mounting Location |
1974revenge |
posted 04-06-2010 08:37 AM ET (US)
[What is] the best place to mount a transom-mount SONAR transducer to a 21-foot banana hull? I currently have it mounted to the starboard sponson but lose readings at any planing speeds other than idle. Thanks |
posted 04-06-2010 09:49 AM ET (US)
Mount the transducer closer to the keel center line. You describe the transducer coming out of the water or into airy water. |
Tom W Clark |
posted 04-06-2010 10:09 AM ET (US)
There is some good information from the Boston Whaler Owner's Manual reproduced here: http://continuouswave.com/whaler/reference/manual18-25/electrical. html#fathometer |
2manyboats |
posted 04-06-2010 10:33 AM ET (US)
Ours is mounted on the port side directly under the splash well drain. |
1974revenge |
posted 04-06-2010 02:26 PM ET (US)
Thanks all for the info...I will pull the boat..remount and post the new results. |
posted 04-06-2010 03:14 PM ET (US)
Also see in the REFERENCE section this article: SONAR Transducers |
1974revenge |
posted 04-07-2010 08:30 PM ET (US)
Ok, repositioned the transducer to below the drain holes but still lose reading at any speed over fast idle. I think it is not just a tweaking/adjustment issue as I am about as low as you can go on the hull. 2manyboats...can you share more detail on running angle and how far below the hull does your transducer sit. Thanks |
2manyboats |
posted 04-09-2010 01:36 PM ET (US)
I would think the installation instructions specific to the transducer would be important as to angle and distance below the bottom of the boat. That said my depth find is a Hummingbird and the transducer is depth and temp only. It is shaped like a flattened bullet. The lower surface is about 1/2 inch below the hull and the trailing edge of the transducer is probably 10 degrees lower than the front. Because these transducers ride low the are on a kick-up bracket. We have the same unit on our Montauk and it is set up about the same way and both units read well at all speeds. |
1974revenge |
posted 04-09-2010 02:57 PM ET (US)
Thanks, I meant to say that I believe it is a tweaking/adjustment issue now that I have it mounted at the appropriate location. I changed the angle and can now get a solid read at just over planing speed..around 15 mph..I lose it after that though, so will do a few more adjustments and retest. |
Fishmore |
posted 04-10-2010 01:19 AM ET (US)
You might also try to increase the transducer ping rate and sensitivity. On your Fishfinder menu settings you should find these adjustments. |
