ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: The Whaler GAM or General Area OUTRAGE 17: Water Accumulating In Stern Cockpit Locker
Author | Topic: OUTRAGE 17: Water Accumulating In Stern Cockpit Locker |
grossjas |
posted 07-08-2010 04:13 PM ET (US)
I am accumulating water in [the stern cockpit locker of what was later identified as a 1999 Boston Whaler OUTRAGE 17 boat]. It fills up! I do not have a live well. The only holes in the boat [are] the drain plug and the scuppers. I plugged the scuppers and the [the stern cockpit locker] is still filling, The drain plug is new and seems to fit tight. Where is this water coming from? |
Buckda |
posted 07-08-2010 04:28 PM ET (US)
Which boat do you own? Does it fill with water when you are stopped (at the dock) or when you are under way? I think you need to find a second person to ride along and see if you can find the source of water coming aboard - it could be splash back over the transom, it could be spray if it's during rough conditions, etc. Also, inspect very carefully around the drain tubes and scuppers for any voids or open cracks where sealant may have pulled away. |
grossjas |
posted 07-08-2010 04:50 PM ET (US)
The boat [under discussion is] a [1999] Outrage 17. I believe it takes on water when it is sitting. With two people in the back the scuppers are under water. I put some sink plugs in, but I am not sure they are sealing tight. |
Buckda |
posted 07-08-2010 05:04 PM ET (US)
I doubt they are. If they are flapper type scuppers, they will never seal completely. The best way to find out how an dwhere the water is coming in is to haul the boat and dry the sump. Then re-launch the boat with someone in back keeping an eye on the bilge to locate the water entry point. Bilges are bilges - they almost always have some amount of water in them. Obviously, if it is FULL, that is a real problem. I am not familiar with that hull to tell you where the "problem points" might be - but I stand by my assessment. I have plugs that I thought were sealed tight - and they were tight - but they were also dry - so they didn't expand properly for a good seal. I'd check very carefully - you will find the source. |
diveorfish |
posted 07-08-2010 05:38 PM ET (US)
grossjas: Another thought: Do you have any other through-hulls on the boat? I don't know squat about the 17 Outrage but my boat has a through-hull right below the console, which is theoretically the lowest point of the boat. The through-hull inlet is in my console at the bottom which has a mini bilge about 4-inches deep and has a bilge pump next to the hole. I always have a plug in that hole while in the water. If water is coming in from there it will go to the aft bilge if you are stern heavy in any way. |
grossjas |
posted 07-08-2010 05:42 PM ET (US)
The only through-hull is the one in the[the stern cockpit locker], which I bought a new plug for, fits tightly. |
Bella con23 |
posted 07-08-2010 06:06 PM ET (US)
Grossjas - Does that 17 have a fishbox on the deck? |
grossjas |
posted 07-08-2010 06:09 PM ET (US)
Not sure what a fishbox is. There is a 4'x3' door that opens up to the [the stern cockpit locker], just aft of the RPS. |
Bella con23 |
posted 07-08-2010 06:21 PM ET (US)
I don't know a heck of a lot about this boat either. I am looking at this diagram http://media.channelblade.com/boat_graphics/electronic_brochure/ Company94/_56_74201062625PM.pdf and I don't see what you are refering to. Take a look at the link and let us know were the water problem is. Joe |
grossjas |
posted 07-08-2010 06:26 PM ET (US)
The door to the [the stern cockpit locker] is #104 |
Bella con23 |
posted 07-08-2010 06:29 PM ET (US)
And that is were the water is accumulating? It has or had a pump installed from the factory. Is it still there? If not, is the pump discharge line hanging in that box unplug? |
grossjas |
posted 07-08-2010 06:35 PM ET (US)
Yes that is where the water is accumulating. The pump is there and it is factory installed. Thats what I use to get the water out. It pumps out well above the boat's waterline. |
Moose |
posted 07-08-2010 06:58 PM ET (US)
For what it's worth. This shows that year and model should have an insulated, in-deck storage or fishbox as standard equipment. http://web.archive.org/web/20000304195358/www.whaler.com/Boats/ outrage17.html Each fishbox on my 18' Outrage from the same era has a through hull that goes directly downward below the waterline, vs. to the stern. If the hose and/or clamps that connect the hose to the fitting on the box and to the through hull failed water could enter the bilge from both the box and the lake. |
Bella con23 |
posted 07-08-2010 07:00 PM ET (US)
There appears to be a PVC thru-hull fitting under that pump with #75 plug. It this fitting and plug secure? http://media.channelblade.com/boat_graphics/electronic_brochure/ Company94/_56_74201062625PM.pdf |
Bella con23 |
posted 07-08-2010 07:14 PM ET (US)
For your information - http://www.whaler.com/Page.aspx/pageId/34791/Parts-Diagrams.aspx |
grossjas |
posted 07-08-2010 07:32 PM ET (US)
That plug is missing, but I wouldn't think that should matter as there is only one through hull, the drain. I think that the pvc fitting and piping is so any water that gets in the compartment where the gas tank is will drain into the [the stern cockpit locker]. |
diveorfish |
posted 07-08-2010 07:36 PM ET (US)
According to the diagrams of the 17 Outrage linked to by Bella Con23, the in-deck storage does duty as a makeshift livewell, fishbox, in-deck storage and bilge area. The thru-hull at the bottom has a plug, but I now wonder if the parts 72, 73, 75 may have failed. From the diagram, I just don’t see any other place that would allow enough water in to fill up the [the stern cockpit locker]. Part 72 is the: thru-hull, PVC Press fit and part 73 is the: nut PVC retaining Thru-hull and part 75 is the: clamshell. I know this happens occaisionally and sinks lesser boats, but I don’t know how likely it is. Maybe the clamshell was torn off and damaged part 72. If that is the case is the fix very difficult? The only way to know for sure is to be inspecting that area as you put the boat in the water with the plug in. By the way, a very special thanks to K Albus for linking to “whalerparts.com.” Man it has all the diagrams and parts names for all Whalers from 1998 onward. I never knew it existed. |
Bella con23 |
posted 07-08-2010 07:38 PM ET (US)
According to the diagram it drop out the bottom of the hull as indicated by the water deflector on the bottom of the outlet. I would say this is the problem. Add the extra weight of a friend or two in the boat and you will displace more water causing the compartment to fill a little more. |
grossjas |
posted 07-08-2010 07:40 PM ET (US)
I saw the "clamshell" in the diagram but when I inspected the boat I can't see it. There is just the through hull fitting on the bottom of the boat. I can see the plug in the fitting. |
Bella con23 |
posted 07-08-2010 07:52 PM ET (US)
The "clam shell" is in place so you can drain the tank while underway. It works very efficently by creating negative pressure on the tube leading to the fishbox much like and inverted wing. |
Jamber |
posted 07-08-2010 07:54 PM ET (US)
I had a 1999 Dauntless and it's on deck self bailing drains (that drained the cockpit out through the scuppers on the stern) slightly leaked around them into the bilge. I am not familiar with the 17 Outrage and if it has a similar design. Not sure if this would work... could you put the boat on the trailer and put water the [the stern cockpit locker] with a garden hose and look at all the fitting from the outside to see if water is leaking out? |
grossjas |
posted 07-09-2010 08:47 AM ET (US)
T think that I should be able to see the "clamshell" on the bottom of the hull, but its not there. I am now wondering if that through hull did get damaged. I think this afternoon I am going to put water in the [the stern cockpit locker] with the boat on the trailer and see what happens. All advice is welcome. |
towboater |
posted 07-09-2010 10:31 AM ET (US)
I have owned a 17 with 110 Ficht and kicker. I agree with Super Dave Buckda, haul out and resemble trim as much as possible, let the trailer and hull drip dry until next morning. I mean, you probably need to haul out to patch it anyway. ADD a lot of water inside the boat, let set for a hour, look for a puddle of water on the ground, follow to the source, patch, splash and go.
towboater |
posted 07-09-2010 10:33 AM ET (US)
sorry to be redundant there...I guess you posted while I was composing. Good luck. |
grossjas |
posted 07-09-2010 03:12 PM ET (US)
Well, I filled up the entire [the stern cockpit locker] and waited a while then checked everything and all was well. The through hull was bone dry. Not leaking. I'm back to my original conclusion that the scuppers are allowing water to enter. As weight builds up in the back of the boat (people and water) the boat sits lower and lower, putting the scuppers well below the waterline. I would like to find a good 1 1/2" plug to plug them properly but they are not easy to come by. I am using sink stoppers now but think they are inefective. |
K Albus |
posted 07-09-2010 03:18 PM ET (US)
You might want to look into these: http://www.thmarine.com/product.cfm?PRID=55 . |
grossjas |
posted 07-11-2010 04:44 PM ET (US)
After all day yesterday conducting various tests and searches on the water. The water entering the boat and filling the in deck storage compartment is coming in from the scuppers! I am a little disapointed that such an obvious flaw was overlooked in the design. I am using sink stoppers now and am looking for some good 1-1/2" plugs. Any suggestions the larger size seems pretty hard to come by. T H Marine makes some I may purchase. Has anyone else plugged there scuppers |
Bella con23 |
posted 07-11-2010 05:16 PM ET (US)
Well that's good news. I would still check the clam shell missing on the bottom of the fishbox/cooler drain if for no other reason then to patch the screw holes if they were ever there. Joe |
grossjas |
posted 07-12-2010 08:29 AM ET (US)
I think I am going to install a new clamshell vent. It looks like the holes were either already patched or no vent was ever put on. Any one know the size and source for the vent? |
posted 07-12-2010 08:40 AM ET (US)
Information about the clam shell vent used to cover the outboard end of brass through-hull drains is given in the FAQ on that topic. |
posted 07-12-2010 08:53 PM ET (US)
The under-deck storage area at the stern of a Boston Whaler OUTRAGE 17 is an aft or stern cockpit locker. The cockpit locker is covered by a hatch, but the fit of the hatch may not be water-tight, so that water on the deck could drain into the stern cockpit locker and accumulate. At the forward end of the stern cockpit locker at the center, in what is likely the lowest point, there is an additional sump molded into the locker. This is intended to collect water. In the sump there is a pump mounted. The pump is intended to expel water from the sump. Although not clearly shown in the exploded view diagram (linked above), we assume that the exhaust hose of the pump discharges overboard. At the bottom of the sump there is a through hull drain that leads downward and through the hull bottom. If this drain is opened the aft cockpit locker will begin to fill with water. If the boat is underway, and the drain is opened, water will tend to drain from the sump due to the Venturi effect of the drain. Other than the pump and the through-hull drain, the aft or stern cockpit locker appears to have no other methods for removing water. Water can enter the aft cockpit locker by three methods: --drain downward into the locker from the deck |
Jerry Townsend |
posted 07-12-2010 11:02 PM ET (US)
Jim - the pump discharge is just below the starboard rub-rail. I had not seen the sketch before either - and it is good - though I did not see the pump discharge. Grossjas - I have about the same boat (albeit mine is a '96). Underway, the scupper flappers are controlled by the velocity pressure acting on the flappers. That is, with the boat underway, the flappers will be "open" sucking any water from the in-floor drainage ditches. When the boat is stationary, the water pressure acting on the flappers is intended to "close" the scuppers - but "things" do get stuck around the flapper, perventing it to completely seal. My mode of operation - periodically when somewhat stationary, fishing, having lunch, et al. - I will turn the pump on - and when water stops coming out of the starboard discharge, I will turn the pump off. I always do this just before getting underway. I have thought about an automatic pump - but haven't gone that route yet. I would not put anything on the outside of the boat covering the scuppers - as it would effectively block any obstruction (branches, leaves, twigs, et al.) from moving through the scuppers. I have often thought that I need to invent something that works better than the rubber flapper - but, at this point, I don't have a better answer. You, I believe, aware of the drain from the fuel tank area into the sump/fishbox. I will open that drain once or twice a year to check for any accumulation of water in the fuel tank area. -------- Jerry/Idaho |
davej14 |
posted 07-13-2010 10:11 AM ET (US)
K Albus, Would you please comment on the effectiveness of the ball scuppers in your link posted above? Are you using them and do they seal completely ? For reference, I am using Raybud ball scuppers but they do not seal completely so I also insert large rubber plugs on the inside of my scupper drains. This obviously defeats the purpose of the drains as I need to pull the plugs when under way to discharge any water that sloshes over the transom. |
K Albus |
posted 07-13-2010 10:18 AM ET (US)
I don't use the ball scuppers. I've just seen them recommended a number of times on this website. Try running a search of this website. |
grossjas |
posted 07-15-2010 03:12 PM ET (US)
I think I solved the situation. I am using plugs on the inside if the boat to plug the scupper holes. The hatch has a seal to the in deck storage compartment but I don't believe it seals very well at all (the rubber seal has hardened over the years. I think my problem was magnified because I had a full tank of gas (56 gallons) and 5 people on board. The scuppers were at least 6" below the water line. When I am fully loaded from now on I will just install the plugs. |
towboater |
posted 07-20-2010 11:37 AM ET (US)
My 17 Outrage foundered (filled up with water while secured). We were using it for crew boat on short notice job, boat was tied alongside a small barge, wind came up while we were sleeping on the Tug, 2-3 ft chop splashed over the spill dam. As the legend implies, the boat didnt sink... Problem was resolved by moving gear fwd, reduce fuel tank level, turning the boat around at night and having crew keep and eye on it, pump as needed. Side note. Dry, this is a pretty stable boat. Full of water, it wont sink but trust me, wouldnt take much to roll it. Gross; full tank of fuel, 5 people and scuppers/spill tray are near flooding, with all respect, I wonder if you are not right on the edge of overloading this 17 ft boat that has a FAR above average deadrise (hull angle). This is a super strong unsinkable foam filled hull but has limitations. Other than below deck fuel tank that varies, does not have any ballast near the keel...the more weight added above deck = less stability. |
