ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: The Whaler GAM or General Area Two-cycle Oil Pedigree
Author | Topic: Two-cycle Oil Pedigree |
rgy |
posted 08-04-2010 09:55 AM ET (US)
[The author began this article by telling us that he] recently bought a 1984 Boston Whaler OUTRAGE 18 with a [1995] Johnson 150-Hp whose previous owner says he always used Johnson oil in it; I thought I would do the same. Problem is I can't find [Johnson-branded two-cycle motor oil]. Sticker on the motor says to use oil containing the TS-3 additive. I can use any two-cycle oil with that designation correct? What would you use Yamalube? |
Tohsgib |
posted 08-04-2010 11:32 AM ET (US)
Johnson oil is gone. I would use Evinrude or BRP XD-30 or XD-50. You can also use any good oil like Yamalube, Quicksilver, etc. Many here use Penzoil or something brand name as well. I would not buy the bargain noname stuff personally. |
Buckda |
posted 08-04-2010 11:41 AM ET (US)
I would buy XD-50. Buy two gallons and then go buy it in bulk afterwards, for the discount. XD-50 oil will reduce an deliminate the need to use carbon guard in your gasoline, as it burns very clean. If you use XD-30 or standard TC-W3 oil, you will need to run carbon cleaner in your fuel. |
Buckda |
posted 08-04-2010 11:43 AM ET (US)
RGY - Van's in Grand Rapids sells bulk XD-50. Unfortunately, it's not a great deal at $30 a gallon. I buy my oil, when I can, from Lockeman's in Detroit. Bulk XD-50 is $22.50 a gallon. If you end up across the state, it's worth the detour to buy the oil from them. Not sure who sells it in Holland, but forum member mateobosch in Holland can probably give you a source there - but I think he runs XD-100 in his E-TEC. |
rgy |
posted 08-04-2010 12:06 PM ET (US)
Thanks all! Bucka if you get over this way give a shout. bob |
pcrussell50 |
posted 08-04-2010 03:28 PM ET (US)
I use WalMart's brand of TCW-3, two-cycle oil. Not only have I never had a problem with it, but I use their motor oil in my racing car engine, and in THAT situation, I send samples of used oil off to a lab for testing. They say WalMart oil is better than many, and as good the better ones they've tested. Obviously, you can't test used 2-stroke oil, but if their automotive oil is as good as it gets, I at least have pretty good faith that their 2-stroke oil is good enough. My problem-free experience with outboards supports that claim, too. -Peter |
L H G |
posted 08-04-2010 06:07 PM ET (US)
Walmart's private label oil is supplied and packaged by Pennzoil. Walmart also handles Pennzoil's own label outboard oils in either part ($14/gal) or full ($26/gal) synthetic. They often have Mercury and Evinrude oils available also. I am now using the $14 stuff with excellent, low smoke, results. OMC's oil, prior to the bankruptcy, was supplied by Ashland-Valvoline. They showed up as a huge creditor in the filing. Don't know if BRP has kept up that relationship, but it could be possible. Don't know who does Mercury's oil, but I have suspected Pennzoil or Quaker State. (my hunch only - don't start a rumor on this, please) I have always been amazed at how well the engine companies keep these confidentiality agreements secret. They must deliver the stuff in the middle of the night in unmarked vehicles! Somewhere, with all the custom bottling and packaging, you'd think some employee at the bottle manufacturer, or oil packager, would get the information out. I think the Evinrude "XD" oils are grossly overpriced, even compared to the other engine brands. |
DanT |
posted 08-04-2010 07:50 PM ET (US)
Here's a current listing. |
bloller |
posted 08-04-2010 07:54 PM ET (US)
I bought a new 70hp Yamaha 2 stroke many years ago from a dealer. They did not tell me what brand of oil to use but they specifically told me to never ever use the the Wal Mart brand of oil. I believe it was/is called Lubrimatic. They claimed that my motor would self destruct on the stuff. |
Buckda |
posted 08-05-2010 08:51 AM ET (US)
Larry - You state that the Wal-Mart fully synthetic oil is $24/gallon. I pay 22.55 a gallon (bulk) for fully synthetic XD-50. Who is overpriced? |
Peter |
posted 08-05-2010 09:40 AM ET (US)
XD50 is not fully synthetic. It's a synthetic blend. At my local shop, the Evinrude oil is no more expensive than the equivalent Mercury oil. Given that XD50 is a synthetic blend, its cheaper than YamaLube. They are all more expensive than they should be but then what marine based product isn't. |
lakeman |
posted 08-05-2010 11:43 AM ET (US)
Nice listing of oil and manufactures, but did not see Mercury oil on there??? In older out boards, burn what you want, but I do suggest keeping with the same brand if possible. New Direct Injected engines, buy the recommend oil, they use so little oil, it is not that big of an expense. Having said that, I may go to a total synthetic in my Optimax, but I have been saying that for years LOL. |
Hilinercc |
I've used Walmart Outboard oil for years, never had a problem. But I recently switched back to the OMC/BRP brand and its been my experience my motor doesn't smoke much at all like it did using the Wal-Mart brand. Could be nothing, but I wasn't getting the smoke I was before I switched back. |
davej14 |
posted 08-05-2010 12:01 PM ET (US)
I have switched back and forth between Penzoil full synthetic and Mercury Quicksilver Plus for the last two years. I honestly cannot see or smell a difference between the two in my Merc 75 Carb'd 2-stroke. |
wannabe |
posted 08-05-2010 08:31 PM ET (US)
Anyone running Amzoil ? |
Mr T |
posted 08-06-2010 01:26 AM ET (US)
I have been running the WEST MARINE [TCW3] oil with really good results. I was running XD-50 exclusive when a buddy suggested the WM stuff. I wait till they sell it for 14.99/gallon and buy as much as I can afford. I still run seafoam every 40 hours, but noticed that there is very little carbon buildup. |
pcrussell50 |
posted 08-06-2010 01:42 AM ET (US)
quote: Do you mean Amsoil? With an "s" instead of a "z"? Amsoil is well regarded by us in the amateur road racing community. This is of course, 4-stroke-automotive engine oil. I don't know if it's correct to assume that because the auto oil is good, the 2-stroke outboard oil is also good, if the price was right, I'd take that chance myself. -Peter |
posted 08-06-2010 10:43 PM ET (US)
I am always amazed at how much insight people can have about two-cycle oil. The stuff only gets used once, and then it is discarded or burned up. Some folks seem quite keen on colors. If brand M oil is blue and brand W oil is blue, then they think it is the same stuff. Blue is a coloring, not a motor oil quality. |
Dave Sutton |
posted 08-07-2010 08:37 AM ET (US)
What's amusing here is that everyone is reporting positive results. Nobody is reporting any adverse results. This can only mean one thing: It's not that critical what you use, as long as you use something. Stands to reason that people support as "best" whatever they have used with success, thus the wide diversity of opinion.
Jefecinco |
posted 08-07-2010 09:41 AM ET (US)
It may be unimportant which TC-W3 oil is used with carbureted two stroke cycle engines. It all meets the specifications, right? When using generic 100% dino oil, however, it is often necessary to decarbonize the engine periodically unless some additive is added to the fuel. Spark plug life may be shortened when using 100% dino oil. Exhaust smoke is usually present. Part or 100% synthetic TC-W3 oil used in the aforementioned engines may eliminate the need to decarbonize engines, extend spark plug life, and reduce exhaust smoke. An additive may not be needed when using synthetic oil. The use of generic oil is probably not the best option with Direct Fuel Injected (DFI) engines . Having enjoyed the experience of operating a DFI two stroke engine for ten plus years using only the manufacturers recommended oil I have concluded that is the best course of action with DFI engines. My experience was having an engine that never required a repair, never smoked, and never even had a layer of carbon on the propeller. The only maintence the engine received was to periodically replace the spark plugs, water pump impeller, and lower unit oil. Butch |
posted 08-07-2010 10:12 AM ET (US)
Butch and I hold the same opinion. The added cost of using the recommended manufacturer's lubricant as compared to using the least-expensive, no-brand WALMART product, when compared to the total cost of boat ownership and boat operation, is actually quite insignificant. With the Evinrude E-TEC engine, if the recommended manufacturer's oil, XD100, is used, the rate of oil use can be reduced by half, which cuts the cost in half as well. I also find it somewhat incongruous that users of the least-expensive, no-brand lubricant often simultaneous recommend use of boutique manufacturer-branded fuel additives to reduce the occurrence of carbon build-up in the engine. If you factor in the cost of the boutique manufacturer-branded fuel additives--which are often priced at $17-per-pint--into the cost of consumables, the price of gasoline, oil, and additives will often be as much or greater than use of the recommended manufacturer's oil without all the home-brew fuel chemistry of adding this and that additive. A good indication of how much soot is created in the combustion process can be found on the exhaust hub of the propeller. On my low-emission engine, using the manufacturer's recommended oil, after running several hundred gallons of gasoline through the engine, the build up of soot on the propeller exhaust hub is miniscule. If I take a clean paper towel with some spray solvent and wipe the inside of the exhaust hub, I get a small trace of grayish residue on the paper towel. There is literally no soot build-up on the exhaust hub. I doubt there is any in the engine. |
Tohsgib |
posted 08-07-2010 10:28 AM ET (US)
Jim that is why I use gas from a marina. Not only is it ethanol free but it also has carbon guard and stabil in it. Those would easily cost more than the extra $.50 a gallon I am paying. |
posted 08-08-2010 12:47 AM ET (US)
At $17 per pint for the boutique manufacturer-branded fuel additives, that comes to $136 per gallon. I don't understand why it is a bargain to buy fuel additives at $136 per gallon but lubricating oil at $25 gallon is "overpriced." Maybe it is Keynesian Economics. Is that possible? |
pcrussell50 |
posted 08-08-2010 02:30 AM ET (US)
I was advised to run my '75 and '76 OMC v4 crossflows with something higher octane than the 91 octane available at the pump here in the southwest. Being a complete non-believer in octane booster additive, I pay about $8/gallon for a couple of gallons of 110 octane leaded racing fuel that I "water down" with enough 91 to get me into the mid-90's. Oh yeah, my point? Yes, I use WalMart 2-stroke oil, but no additives, and I do a Sea Foam de-carb, a-la Sal's technique every 50 hours or so. -Peter |
Jefecinco |
posted 08-08-2010 09:21 AM ET (US)
Peter, What do you estimate the cost is for every decarbonizing treatment on your engines? Are you using Sea Foam? What was Evinrude's recommendation for fuel for your cross flows? Butch |
Tohsgib |
posted 08-08-2010 10:59 AM ET (US)
There is no reason to buy race fuel for an outboard unless your timing is screwed up. 91 or 93 is plenty. I run 93 in my 40 and 89 in 115. The only reason for the 93 is it can sit for a couple months and I don't want the octane to degrade too low. The 89 is marine gas with stabil, etc in it. |
number9 |
posted 08-08-2010 04:10 PM ET (US)
I find the proponents of purchasing top of the line 2-stroke oil to often deflate the oil's cost and inflate the cost of additives. It's human nature but leads to inaccurate reporting. Some manufacture's recommend their premium oil and still recommend the additives. If access permits an occasional visual inspection of your engines combustion chambers should answer many questions about the oil in use. |
posted 08-08-2010 05:35 PM ET (US)
I can buy the recommended manufacturer's oil in bulk for about $30/gallon. The oil use ratio is 100:1. This means that to treat one gallon of gasoline with my "overpriced" oil my "deflated" cost will be $30/1-gallon-oil x 1-gallon-oil/100-gallons-gasoline = $0.30/1-gallon-gasoline Now we compare the cost to the boutique manufacturer-branded additives at $17-pint or $136-gallon. I believe one ounce of additive treats one gallon, or roughly a ratio of 128:1 $136/1-gallon-additive x 1-gallon-additive/128-gallons-gasoline = $1.06/gallon-gasoline
Oh, by the way, I still have not added any of the stinky blue WALMART cheapo oil to the fuel, so you have to figure that cost and add it to the other side. Let's say we catch a sale at WALMART and get their no-brand oil for $10-gallon--quite a bargain compared to my $30-gallon "overpriced" oil, eh? Now we add the no-brand at 50:1 $10/1-gallon-oil x 1 gallon-oil/50-gallon-gasoline = $0.20/gallon-gasoline The total cost for the "cheap" approach is now about $1.26 to $0.73 per gallon compared to my "overpriced" $0.30 per gallon method. |
pcrussell50 |
posted 08-08-2010 06:31 PM ET (US)
quote: For my big crossflows, I use a whole can of Sea Foam, the regular stuff, not the, pay-more-get-less, Deep Creep. I buy it when it goes on sale at NAPA. This last fall, it was $6.50/can. Regular price is like $11.00. However, for my Precision Blend(TM), oil injected Yamaha 40, (which is on my 1985 Sport 13), I also decarbed my chainsaw, leaf blower, string trimmer, and 25cc folding scooter, in addtion to the Yamaha... all out of the same can. Not sure the _required_ fuel for the '70's crossflows because I only have the Seloc manual for those. I can email you offline some linked info from the fastboaters forum where they talk about it. Tohsgib... As for the fuel in my mid-70's, high compression crossflows? 91 is all we have here in the southwest. There is no 93 where I go boating. FWIW, I don't use straight race gas. I mix it down to something in the mid-90's. I keep hearing again and again that 91 is marginal, and I'm just not comfortable that close to the edge. As an anecdote, in the fastboat community, the mid-70's heads are sought after by the "hot rodders", because of their high compression. Remember, higher octane fuel was the norm back in the 70's. Are you _sure_ you would run 91 in a '75 135hp model like mine? Further, this boat sits a lot at the wife's grandparents house where we use it for fresh water lake/river boating. Sits up to 3 months are possible and 1 month sits are the norm, so at least some degradation in octane is a factor. I use Stabil in every tank, no matter what, to help with that. (Whoops, I guess that puts the lie to me when I said I don't use additives, but Stabil is pretty cheap). My third crossflow is a 1993 with VRO and all the bells and whistles. It's sitting on a stand as a spare, right now, but I think I can run 87 in that one. -Peter |
L H G |
posted 08-09-2010 03:30 AM ET (US)
Jim - Your cost per gallon data on oil for a conventional 2-stroke is faulty. Incidentally, your quoted price on bulk XD 100 is quite good. How many can actually buy it that cheap? Not many. I have seen it at more like $38/gallon. But anyway, let's try again on the conventional engines, none of which use oil at 100 to 1 ratio except on idle. My oil injected 2-stroke Mercs use oil at somewhere around 55-75 ratios, depending on averaged engine speed. So lets say a gallon of Walmart's Pennzoil 2-stroke oil costs your quoted $10. That will treat about 65 gallons of gas, or about 15 cents/gallon. Now let's use Mercury's botique QuickClean, a highly effective engine cleaner and decarbonizer. Almost everyone says it's really good. A $12 bottle, needed every 4th fillup according to my highly regarded Mercury mechanic, treats 80 gallons of gas, as shown on the bottle. So for every 320 gallons of gas, I have to spend another $12 for Quickclean, or 3 cents/gallon. So running an old 2-stroke, and keeping it clean, costs a total of about 18 cents/gallon of fuel. let's be generaous, and raise that to 20 cents/gallon of fuel. Hence oil cost for running an E-tec on XD 100 is 50% more than oil cost for running an old conventional oil injected 2-stroke. When you run that "snake oil" high priced XD100 you really don't know what you're getting or what's in it. When you run Walmart/Pennzoil 2-stroke oil you also don't know what you're getting. But with the addition of Quickclean, you KNOW what you're getting. So Walmart plus Quickclean really is a bargain to keep your engine in great running condition and decarbonized. My guess is that for an E-tec it's more cost effective to use XD50, with Quickclean added every 4th tank, than just plain XD100. |
Lil Whaler Lover |
posted 08-09-2010 08:31 AM ET (US)
Finding out who makes oil for he rebranded products really is not that difficult. All one needs to do is look at the MSDS (Material Safety Data Sheet) for the product being sold. It will tell you the manufacturer. For example Yamaha Ringfree Has often been said to be repackaged Chevron Techron. Actually it is made for Yamaha by Golden Eagle. Golden Eagle's best known product just happens to be Stabil. I will try to check some MSDS sheets today. |
An additional variable in these calculation is the rate of fuel use. With a modern low-emission direct-injection engine the rate of fuel use will be lower, so less fuel is used. Correspondingly less oil will be used. If we compare the cost to travel 100-miles, I suspect that the modern engine, running on its recommended manufacturer-branded oil will use only about 0.66 as much oil as the classic smoky two-cycle running on no-brand oil because it will use 0.66 as much fuel. We see the cost of oil or oil and additives is in the range of $0.20 to $0.30 per gallon. Now we compare to marine fuel. On my recent trip in Ontario I bought fuel at $1.19-CA/liter. Assuming the exchange rate will be close to par, that fuel cost me $4.50 per gallon. The gasoline cost is much higher than the oil and additives cost. This means that if we seek a mechanism to reduce our costs, the most effective vector is to target the fuel use. The modern engine reduces fuel costs significantly through its lower fuel consumption. Thus overall fuel and oil costs will be lower with the modern engine running on its specialty oil than compared to the older engine running on its no-brand oil and boutique additives. |
posted 08-09-2010 08:36 AM ET (US)
L H G writes: "When you run that "snake oil" high priced XD100 you really don't know what you're getting...." Actually, I know exactly what I am getting: When I buy XD100 I am getting the product that the manufacturer of my engine recommends for use with my engine. |
tom976 |
posted 08-09-2010 09:20 AM ET (US)
I am surprised that nobody bothered to go to their local dealer and get a fillup there. That's basically what I do. I take a few empty yamaha containers to my local dealer and he charges me $16.00 a gal for Yamalube. They buy it in bulk and happliy sell it for a discount. The West Marine stuff isnt too bad. (only buy it on sale) I have it on the boat as a backup just in case. As for the Wally World stuff. Again for me good in a pinch but use it mainly to mix with my lawnboy mower, weed wacker etc. Tom |
Buckda |
posted 08-09-2010 09:44 AM ET (US)
You use TC-W3 oil in air-cooled lawn equipment? I use Golden Spectra in my lawn equipment that requires mixing. It is designed for air-cooled engines. |
Buckda |
posted 08-09-2010 10:16 AM ET (US)
I don't know about pedigree's, but for someone who squirms at the thought that another forum member might consider buying a foreign-brand outboard motor, L H G sure spends a lot of time inside one of the biggest foreign product importers in the country. Based on their business model, it is unlikely that a person entering the store to purchase oil leaves having purchased only oil on the visit. |
gnr |
posted 08-09-2010 10:20 AM ET (US)
I worked in a commercial bakery for a summer many moons ago. The difference between the premium hamburger buns and the bottom shelf economy branded hamburger buns was the bag they were packaged in.
posted 08-09-2010 01:04 PM ET (US)
I agree there is some marketing in the concept of an outboard engine manufacturer offering their own brand of consumables for use with their engine. Mercury, Bombardier, and Yamaha all seem to do it. I have not seen any Honda-branded oil or Suzuki-branded oil. Part of the marketing plan is probably a draw to bring customers back to the dealership to buy consumables. This brings traffic into the dealership and adds to dealer sales. I enjoyed the parable about the baking of hamburger buns, however I do not find the anecdotal experience of one bakery to be binding on all outboard motor oil products. Outboard motor oil has many easily discernible qualities which identify it. The oil I use, XD-100, has a different color, a different smell, and a different viscosity than other outboard motor oils. I do not think XD100 is the same product as the WALMART no-brand oil and it has simply been placed in a different container. |
Tohsgib |
posted 08-09-2010 02:04 PM ET (US)
Suzuki has their own oil...$$$$$. |
pcrussell50 |
posted 08-09-2010 03:53 PM ET (US)
FWIW, here's my attempt to distill this: A lot seems to boil down to whether or not premium oil users are comfortable NOT decarboning. For my part, I lack that confidence. Since I'm going to decarbon my motors anyway, I use whatever TCW3 is selling for a good price. I've never conducted back to back "smokiness" tests with cheap TCW3 versus premium stuff, and I probably won't because my sensibilities cannot make ordinary 2-stroke smoke register above a "0", on my self-designed, "give-a-crap" scale. That said, I did use a gallon of Quicksilver oil, instead of my usual WalMart oil, and if there was a difference, it was not obvious enough to detect it. -Peter |
L H G |
posted 08-09-2010 06:43 PM ET (US)
I think we all know Walmart's private label TCW-3, made by Pennzoil, is not the same as 100% synthetic XD100. But it is probably pretty close to Evinrude's XD-30. Besides brands, there are three TYPES of oil to consider using: 1. Pure oil TCW-3, like Mercury Premium, XD-30 or Yamalube. 2. Part synthetic mixtures, usually billed as lower in smoke, such as Mercury Premium Plus, XD-50, Pennzoil XLF, CAblea's etc, etc. Highly recommended for conventional 2-strokes, and can be used in all DFI's. 3. High priced full synthetic oils, usually recommended as the premium oil for DFI 2-strokes, such as Mercury "Optimax" oil, Evinrude XD-100, Pennzoil 100% synthetic, etc, etc. Not necessary or even recommended for conventional 2-strokes. I have seen Pennzoil full synthetic for about $26/gallon. I have been using the #2 type, since it gives conventional 2-strokes less start-up and idle speed smoke. Using this oil, except for higher gasoline consumption, one can barely tell a regular 2-stroke relief port exhaust from a DFI. I think these three categories are the major difference in outboard oils, and within these categories branding is nowhere near as important. |
Lil Whaler Lover |
posted 08-09-2010 10:36 PM ET (US)
This thread started out looking at the "pedigree" of certain oils. I just took a quick look at the MSDS on BRP, Mercury and Yamaha oils. All BRP oils are made by CASTROL for BRP. All Yamaha oils are made by "CITGO" for Yamaha. Mercury (Quicksilver) oils are much more complicated. They seem to have diffent suppliers for product sold in the United States compared to Canada. The Mercury distributed in the United States are all "CITGO" products escept the 2-cycle high performance, as in racing, whichis made by SPECTRO. In Canada, the 25/40 oil for IO's comes frp, ESSO CANADA, and all the other oils seem to come from SHRADER CANADA LTD. I also noted that "QUICKCLEEN" and "RING FREE", both come from GOLD EAGLE, and have no reference to CHEVRON or TECHRON. GOLD EAGLE is best known for STABIL. YAMAHA is now recommending that we use STARTRON |
Lil Whaler Lover |
posted 08-09-2010 10:43 PM ET (US)
Hit wrong key. Need to finish thought. YAMAHA now recommends that we use STARTRON to help protect against damage from ethanol. This the first time they have recommended a product that they do not make a profit on! When I asked a Suzuki rep what they recommended to protect against damage from ethanol, his comment was: "we have not tested anything, just use what Yamaha says to use." Sure says alot about Suzuki's commitment to the customer! |
L H G |
posted 08-10-2010 12:01 AM ET (US)
That's really great information, LWL. CITGO, our friends in Venezuela, of all possible people, supplying Yamaha and Mercury! Who would have guessed. I think I'll keep using Pennzoil products. I have noted that on the black bottles of Techron they specifically say "not recommended for 2-stroke engines" |
Lil Whaler Lover |
posted 08-10-2010 09:14 AM ET (US)
Suzuki oils are also made by CITGO. |
adlert |
posted 08-10-2010 10:53 AM ET (US)
Some additional information I find interesting. Though I've never purposely visited a bassfishing site, I strayed upon a thread today containing a link to some independently conducted TCW-3 oil analyses. It seems one of the site members (Paul Dougherty) decided to send blind samples to "Blackstone Laboratories" for some general analysis. It also appears the laboratory is familiar with this sort of work. The Laboratoy technician's comments on each report are brief but worth reading. There is also a link to other oil analyses via "Results from someone else." http://home.comcast.net/~team_dougherty/results/results.html |
fluke |
posted 08-10-2010 11:53 AM ET (US)
I'm down to my last quart of lubrimatic tcw-3 2cylcle oil, is it ok to mix with west marine 2-cycle oil? |
L H G |
posted 08-10-2010 08:03 PM ET (US)
It appears that Walmart/Pennzoil's "SuperTech " is just as good as the Evinrude XD-50. Iit looks like Mercury and Yamaha do indeed add a few anti-wear extras, but nothing of major significance. |
posted 08-10-2010 08:11 PM ET (US)
One of you oil scientists will have to lay it out for us gullible victims of marketing--how do we interpret the Blackstone Laboratory findings? There are columns and numbers, but they don't tell me a thing. I await enlightenment. |
adlert |
posted 08-11-2010 08:42 AM ET (US)
Jim, there's a link to some concise descriptions of typical oil components and their uses/implications on that same page. Actually, some of the other links are interesting too. I'm no oil scientist but it appears the person providing comments on the results sheets may very well be. Based on the comments provided and the specific analytical results I think LHG's summary is correct. There appears to be little more than slight viscosity differences between Supertech, the Pennzoil, and the XD 50 samples. They're all dry, clean, have similar flashpoints, minimal additives, and similar composition as far as the measured analytes are concerned. I am currently assuming that the analyte list is appropriate and typical though more research would obviously verify. The apparent similarity between these oils does not surprise me. I have yet to hear of anyone having any significant problems clearly linked to any of these products. I certainly haven't had any problems in the thousands of hours I've put on my carbed 2-strokes burning Supertech and Pennzoil. That being said, as the technician noted on the last sheet you won't go wrong using the manufacturer's recommended oil. My owners manuals recommend using TCW-3 oil so that's what I do. Just picked up 4 gallons of Pennzoil synthetic blend for $13 each yesterday from Wally World. Life is good. |
gnr |
posted 08-11-2010 09:10 AM ET (US)
This is all you need to know right here Jim.
quote: Taken from the posted link. FYI. I not a scientist nor a gullible victim of marketing. :-) |
seahorse |
posted 08-11-2010 09:13 AM ET (US)
The thing to keep in mind when comparing 2-stroke oils lab results is the the lab is set up for testing and comparing 4-stroke oils and the results column only lists common elements that are widely used in those oils. 2-stroke oils are a different breed as they have to be burned and not leave damaging deposits on the piston, heads, and ports. At 6000 rpm 2-stroke oils only have to perform inside the motor for about 1/100th of a second. 4-stroke oil labs do not test for organic and nitrogen based additives and elements that are commonly used in 2-stroke oils. Metallic additives generally leave hard carbon deposits on the piston and organic additives leave soft deposits in outboard duty cycles. Bottom line is that oil labs do not tell a complete story when comparing 2-stroke oils |
posted 08-11-2010 09:28 AM ET (US)
Based on the odor of the Evinrude XD100 oil, I suspect there is something organic in its composition. XD100 has a very unique smell, and it is unlike any other two-cycle or four-cycle oil that I am familiar with. The principle feature of the premium oils has been previously cited as their ability to be consumed or burned in the combustion chamber without leaving a residue of ash or soot, or producing noticeable smoke in the exhaust. I don't see any indication the Blackstone Laboratory tested for this characteristic. It is not surprising that their results do not distinguish one oil from the other on this basis; they did not test for it. |
adlert |
posted 08-11-2010 11:43 AM ET (US)
Fortunately the NMMA TCW3 testing and certification process does just that. It is strictly a performance-based test (residues, scuffing, etc.). They care not what the oils they certify actually contain, they simply set minimum performance standards they must pass given their chosen testing methods. Their chosen testing methods and minimum required results have worked very well for my engine choices and use patterns, allowing me to use the cheapest oil I can find with confidence. If however, I had an expensive, brand new E-Tech or Optimax engine using so little oil I admit my oil purchasing habits would likely change. |
Tohsgib |
posted 08-11-2010 12:38 PM ET (US)
You guys kill me...You spend $14k for an engine and then cheap out on $60 worth of oil per SEASON?????? (6 gals of oil at $10 premium over what you pay) |
gnr |
posted 08-11-2010 12:51 PM ET (US)
You're a marketer's wet dream Bigshot. ;-) |
Tohsgib |
posted 08-11-2010 01:10 PM ET (US)
I never have nor ever will run oil that does not have a engine name on it, why take the risk. Thanks To Whaler sponsored events I currently have about 6gals of premium plus in my garage. I gave away 5 gals of Optimax about 4-5 years ago. Now I burn 3-5oz of 2 stroke in my diesel per tank, ads lubricity that low sulphur fuel has lost so my supply is starting to dwindle. |
Buckda |
posted 08-11-2010 01:18 PM ET (US)
What interests me is that folks put weight on a lab result that is designed to test used 4-stroke crankcase oil for residual elements that give a hint to how well an engine is running, not to test the quality of the oil itself, or any specific lubricating properties. These labs test used oil to see if they can identify problems in your high performance motor. Since 2-stroke oil is burned in the combustion process, this analysis is not possible. Personally, I do believe that running ANY NMMA TC-W3 certified oil is sufficient to lubricate your motor safely. But I burn a higher quality oil because it leaves less ash and does not require any anti-carbon supplements in the fuel. It also is more pleasant to operate an engine that smokes less. So, whatever. I spend more for quality. I buy American when I can, I shop at small, family owned businesses when I can. Yes, I spend a little more, but I'm blessed with a good job and can afford the slight premium if it means that a local business is going to have money to support the local schools, employ local people and generally contribute to overall quality of life. In this case, that means I buy my XD-50 Oil (at a discount and in bulk) from a family-owned shop. Be that across the state at my preferred dealer, or in town at the alternative dealer which I've identified. Both are mom and pop places and I'm proud to give them my business.
Tohsgib |
posted 08-11-2010 01:31 PM ET (US)
My father back in the mid 80's ran out of OMC oil so he bought a case of Texaco. It was in the metal pint cans if you remeber them. After about a VRO tank of the stuff it fouled out the plugs. I changed the plugs not thinking it was the oil and BAM! It did it again. Put OMC back in and NEVER had the problem again. The ash & soot was unreal. Ever since I never ran anything but an OEM brand. |
gnr |
posted 08-11-2010 01:37 PM ET (US)
What the heck does where you shop have to do with the topic? |
gnr |
posted 08-11-2010 01:41 PM ET (US)
Bigshot, Do you run the manufacturer's branded oil in that new Harley? You might not remember a few years ago when Harely Davidson made it clear that they DID NOT recommend running synthetic oil in their engines. Some crap about bearings slipping or something. A couple years later they had their own synthetic oil to sell and suddenly it was not only ok but encouraged. LOL |
Buckda |
I don't know GNR, can you get SUPER TECH at your local hardware store? |
gnr |
posted 08-11-2010 03:01 PM ET (US)
Come on Dave, It's not like you to troll. I had to Google Super Tech to find out that it is a lower priced brand sold at Wal-Mart. I have never noticed it the local hardware or auto parts store so I will have to assume the answer is no. The local auto parts and hardware stores do typically carry Lubrimatic or some other "off brand" oil. You may or may not be interested to know that in my neck of the woods doing business with the locals is the ONLY option. Nearest Wally World is 45 miles away. Your implication that those of us that don't buy manufacturer branded oil are somehow contributing to the demise of the local "mom & pop" (nice marketing speak there) is misguided and false. You know what they say about assumptions.... Did I mention it's not like you to troll? :-) |
Buckda |
posted 08-11-2010 03:09 PM ET (US)
I never implied you had to buy engine-branded oil. Re-read my post(s). My defense of national branded oils was based on the assertion that there is no difference between them. I posit that there is - and while it may not make a lubricative difference in terms of initial lubricity of the base product, I assert that there is a longer-term difference in qualitative aspects (less smoke) and engine performance (cleaner burn, less deposits, no need for decarbon gas treatments, etc). You can do with that what you want. My argument is not with you. |
pcrussell50 |
posted 08-11-2010 03:11 PM ET (US)
So again, all this boils down to: 1) use cheap TCW-3 and decarb every so often Someone made an argument about spending $14,000 on an outboard and cheaping out on oil. I just bought my fourth, grrreat running, reliable boat, in two years in the hobby, and I've just barely spent _half_ that on all four boats and great motors, _combined_. By some standards, that in itself is cheaping out, I suppose. I prefer to refer to it as a fiscally responsible way to participate in a frivolous luxury hobby that 90% of the world has no access to. I use cheap TCW-3 and decarb my motors every so often. I do not put expensive additives in my fuel other than StaBil. -Peter |
gnr |
posted 08-11-2010 03:21 PM ET (US)
Here is your post right here.
quote:
when I questioned the relevance of those thoughts to this thread you came back with,
quote: You are are now saying that you civics lesson and not so subtle shot at Wal-Mart carried no implications? Sure dude. ;-) p.s. This not an argument it is a discussion. |
Buckda |
posted 08-11-2010 03:31 PM ET (US)
GNR - Any car will get you to work. Why pay more than the cheapest car available? Any board-certified doctor will provide you standard medical care, why pay more for one over the other? It is your life, your boat, your money. Spend it as you wish. I'm going boating and burning my XD-50 oil. If I had an E-TEC or an OptiMax, I'd burn Opti-Max oil or XD-100. If I had a Mercury, I'd burn Premium Plus. If I had a Yamaha, I'd burn Yamalube. I'd buy it from a local dealer, not a big box store. There you go. That's me. It's a free country. |
gnr |
posted 08-11-2010 04:32 PM ET (US)
You Ok Dave? It's not like you to completely dodge the point that is clearly being discussed. Here it is again.
quote: I know you are no dummy but you usually don't play this game. How is buying lower priced oil affecting the local schools the employment of the local people and the overall quality of life? These are your words not mine. You opened this door. Why are you refusing to walk through it? ;-) |
Buckda |
posted 08-11-2010 04:37 PM ET (US)
GNR, if you would like to enter a discussion of how local businesses contribute to our economy, including jobs, personal wealth and community enrichment, I'd be happy to engage that discussion via e-mail. |
gnr |
posted 08-11-2010 04:56 PM ET (US)
WOW! You have fallen a few notches on the old respect-o-meter today Dave. You know damn well that is not the issue here. First you insult everyone who chooses to buy lower priced oil by ASSuming that we all run down to the the local china-mart to get it. Now this? Why did you introduce the local economy angle if you didn't want to disuss it? Oh I know... Because its a free country, right? LOL |
Buckda |
posted 08-11-2010 05:14 PM ET (US)
Where is the passage of my post that insults you? LHG is the one who highly recommends Wal-Mart for batteries or oil and scoffs at anyone who considers buying a Suzuki motor throughout his posts. That is what I was responding to. I could care less if you buy Pennzoil or SuperTech or Jerry's Golden Motor Oil. I choose to buy what I choose to buy. Part of that decision is based in a larger worldview of WHERE and WHY I buy things, which is what my post was trying to elucidate. If it offends you that I choose to buy a premium brand and choose to buy it from a locally operated or owned store for a few more pennies per purchase, where is the insult to you? The original poster asked what we would do. I attempted to answer fully and honestly what I would do. I won't apologize for also encouraging others to understand and consider my viewpoint. I'm not going to (and don't) look down at anyone for buying Cabelas or Super Tech or whatever, but I also don't expect them to do so and then belittle others for choosing other purchases based on price or brand preferences. I believe that this is a wash on cost - i.e. that the cost savings is a mirage, as discussed further up on this thread, and that one would be better off purchasing the premium product in the first place. That's an opinion. I won't apologize for holding it because I believe it is a rational one.
quote: It is not. If you read my threads in context, you will see that this point is discussion WHERE you buy, which as I state above, was part of my viewpoint on WHAT I buy. WHERE you source ANY brand of oil you choose DOES HAVE A SIGNIFICANT EFFECT on the local schools/employment and quality of life. Again, if you wish to further discuss the impacts of local companies and businesses on communities in which they operate, give me a buzz. My e-mail is listed in my profile, and although SOME people think Hotmail is a junk mail account, I am an active user. In other words, I'm there, every day. I'll respond. |
pcrussell50 |
posted 08-11-2010 07:13 PM ET (US)
Dave, to use your, car-for-getting-to-work analogy, yes, buy the cheapest available. Why not? If thats all you want out of your car, why wouldn't you? But what if you want a 2 door sports sedan with at least 400hp, 50/50 weight distribution, a proper 6-speed manual, and impeccable track manners? Well, you still buy the cheapest thing available that meets those particular requirements. Its just that it wont be the cheapest car you can buy, (It's the e92 BMW M3, in case someone is curious). If your requirements out of your 2-stroke oil are to lubricate your engine, and you will be decarboning anyway, and you don't care about smoke, buy the oil that fits that bill. -Peter |
L H G |
posted 08-11-2010 07:24 PM ET (US)
I have no idea why Dave has attacked me in this thread. I don't think I even mentioned his name. Nor do I see a problem with buying American made Johnson Controls batteries at Walmart, nor American produced Pennzoil outboard oil in any of three grades, at Walmart. It has absolutely nothing to do with buying a Japanese outboard, and all my Mercs seem to run just fine, thank you. Am I like Dave, and "spend more for quality"? You bet, but I do it differently, only when the quality is actually there. Take buying a used Boston Whaler for instance. Most of you have seen the two early 70's models I bought used. When it comes to used Boston Whalers, spending more to AVOID an oxidized, well worn, mis-rigged, fixer-up special with bottom paint is the best thing you can do in "spending more for quality". |
posted 08-11-2010 11:17 PM ET (US)
The outboard manufacturers generally do NOT let the big-box discount stores sell their products. You typically cannot get Mercury oil or Evinrude oil at WALMART. Mercury uses a workaround: they sell equivalent products to their Mercury branded consumables under the Quicksilver label, and you can find Quicksilver branded consumables for sale at big-box stores. For me the biggest problem with depending on WALMART as a source for oil--or anything--is the high variability of inventory. One store may have the product one week, and then be out the next. Another store may never carry it. I really don't need to drive around the country looking for the one WALMART that has the oil I want in stock. There is some cost involved there that has not been accounted for in the discussion of buying bargain oil at WALMART. As I mentioned earlier, I firmly believe that part of the marketing effort the outboard manufacturers have made with their own brand of consumables is to drive traffic back to their dealers. That is where I buy my oil--at my outboard motor dealer. This is another concept that seems foreign to some: the notion that you have a local dealer who your work with, who maintains you motor, who provides service and value. What annoys me most in these discussions is the notion that anyone who pays more for something different must be a fool. This argument has been applied several times here by those proponent of using the lowest price no-brand oils. Now I cannot blame them because that is the only argument they can make. When they use less expensive no-brand oils, they must argue that these oils are as good as the more expensive manufacturer-branded oils, and they are the smart ones for seeing through the marketing-hype, which they argue is the only thing differentiating the two oil products. If they do not take this position then they would have to admit the cheap no-brand oil was not as good and they were simply cheapskates who wanted to save $10 per year on oil for a $14,000 motor. That position is much harder to defend, so, naturally, they avoid it. I think everyone should use the oil they feel comfortable using. I don't try to make any arguments that anyone should use the oil I have chosen, but I do feel obligated to reply when people accuse me of being a gullible uninformed naive consumer and tell me I am getting duped by unscrupulous marketing. Or people tell me that I am overpaying for the product, when, in fact, as I have shown above, I actually end up paying no more or even less for the oil I use when compared to oil and boutique manufacturer-branded additives. |
Buckda |
posted 08-12-2010 09:47 AM ET (US)
Actually Larry, I appreciate your path correction on my most recent purchase - and you're right. Unfortunately for me, and without airing too much dirty laundry, I was put in a difficult position and a bit cornered on that purchase. Be that as it may, you're right. The good news for me is that I do enjoy working on the boat, so while it will set me back a little bit and some time, the "bones" of this boat are definitely quality. She just needs a little TLC and elbow grease. As for the buying patterns, we do agree on a lot, but not everything, obviously. Enjoy your hours aboard your boat burning whatever oil you choose. Own whatever engine you want. Next time someone asks what I would do, I'll still give them my opinion. It clearly differs from others. No worries on my part. I'll say it again to RGY - I would not use Yamalube in an Johnson motor. If buying a branded, premium oil (Which is what I'd do), I''d buy XD-50. If you want to take the inexpensive oil route, that's fine. I'd buy Pennzoil - the oil that is readily available to me at my locally owned and operated hardware store. |
Tohsgib |
posted 08-12-2010 10:30 AM ET (US)
Why would you not run Yamalube in a Johnson outboard? If it is good enough(and it costs enough) for a Yamaha it is darn sure good enough for a company that went bust 10 years ago. I run Mercury brand oils in my engines mainly because I know it is good and I get it for free. |
gnr |
posted 08-12-2010 10:36 AM ET (US)
Jim, I never said that you or anyone else who buys manufacturer branded lubricants is a "fool". My point was that in today's world one must be careful when purchasing products based on labels and claims. I gave one example of a situation where the marketing of a product lead to higher profits for the exact same product one could purchase at a lower cost. I can list many more examples of the same type. One only has to pay attention to see that some marketing tactic are misleading at best. Automobile manufacturers are notorious for this type of thing. Sure you can get the super duper aftermarket shocks from the factory on your new truck if you buy the "4x4" package. They don't tell you the Rancho 5000's that come on your new truck were indeed made by Rancho but to Ford's specifications and are inferior to the Rancho 5000's you would get if you purchased them from the manufacturer directly. The examples of this type of marketing are endless. I am not an expert on oil. I do know the none of the outboard manufacturers produce their own oil. It is not a big leap for me to believe that the only difference between the Evinrude branded oil and one of the other oils on the shelf at the parts store is the package it is in. I wonder if enough manufacturer branded oil is consumed to make it worthwhile for the oil manufacturers to run a batch of this specially blended top shelf oil. I believe it is good stuff. I also would bet you can buy the exact same stuff in a different package most likely a bit cheaper. Of course the XD100 is its own animal and I would not include it my thoughts here. At least without learning more about it. ;-) It would not surprise me in the least to find out the color and odor you talk about is less about it performance properties and more meant to differentiate from the other oils for marketing purposes. Now I'm not saying that is a fact. Just saying it wouldn't surprise me. Dave, Get over yourself. I don't care what you buy for oil. I've already quoted the post you made which implied that those of us who buy cheaper oil don't support the local schools and little league and the boy scouts..... You came across a bit holier than thou there, no? All those things that you do which you feel makes you a better citizen I do also. My point was that what shelf you buy your oil from has no affect on this. Non what-so-ever. In spite of your not so subtle implications to the contrary. I appreciate your efforts to keep the local economy going. I feel the same way. My family runs a business that competes directly with the big box stores found a few exits down the highway. They survive by being straight up and honest. |
rgy |
posted 08-12-2010 02:41 PM ET (US)
Dave, I now know what xd-50 is!! I found it at the holland marina across from the pickle factory. 35 bucks a gallon. I think that is what I will run since the previous owner says he always ran the johnson oil. thanks |
Buckda |
posted 08-12-2010 03:00 PM ET (US)
rgy - I'd buy a couple gallons "off the shelf" so you have the containers, and then start buying it in bulk. You can get it in downtown GR at Van's on Alpine (bulk) for about $29/gallon, and I often buy mine from Lockeman's in Detroit fro $22.95/gallon. I usually combine a trip if I'm over there for business or pleasure and stop in to get some. I've also had the benefit of a couple members here who are friends who've delivered it to me on their way over this direction. I used to keep 3-4 gallons of XD-100 handy, and now have the containers to keep 8 or 9 gallons of XD-50 on hand - so when I run over there, it's a pretty hefty outlay, but covers my season. I'm checking down on Gun Lake for a vendor, but so far only found Mercury Premium Plus in bulk on that lake. If you want, I can get you some from Detroit at the discounted price when I run over there if you give me a container. We could meet up halfway - Zeeland or Hudsonville to exchange. Dave |
rgy |
posted 08-12-2010 03:31 PM ET (US)
thaks dave, I will get you a conainer. bob |
pcrussell50 |
posted 08-12-2010 04:12 PM ET (US)
Further, it is impossible to be perfectly socially responsible anyway, not to mention peoples varying degrees of interest in being that way. Even amongst those of us to whom it is important, we still have to make arbitrary decisions as to where to draw the line. So, while some of us might pay a little extra for our oil to support the mom'n'pop, how many of the same folks would apply the same rarionale to pay the local repair shop to change a water pump they could change themselves? The answer is that we all draw the line somewhere. Further, there are things you might not even think of, even if you want to be socially responsible. We use compostable diapers for our 8-month-old. Do (proverbially), you? Some of our bumper crop of tomatoes and romaine this year are grown in it. Wanna come over and have a blt at my place? I'll provide the lettuce and tomatoes. :) *poopy diapers excepted, of course. -Peter |
Buckda |
posted 08-12-2010 04:56 PM ET (US)
Awesome. :) |
