ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: The Whaler GAM or General Area OUTRAGE 17: Designing a New Console Cover
Author | Topic: OUTRAGE 17: Designing a New Console Cover |
PeteB88 |
posted 08-09-2010 11:47 PM ET (US)
I am having a console cover made for the Outrage 17 to fit the cooler, console and RPS. I am having the local Amish canvas shop, well known in these parts, to make it. Previous owner lost the one he had for the boat which is a bummer so there are snaps located at low points around the RPS, console and cooler blocks. I was wondering if any of you who have console covers have any suggestions or ideas that I should incorporate into mine. Let me know if you do. I was thinking about a zipper to access the console door on the port side. Not [expensive] but not sure if it makes a lot of sense really. That console is big and holds lots of stuff and it has a huge door. I appreciate any thing you might [want to] share. Thanks |
lizard |
posted 08-10-2010 10:21 AM ET (US)
The 1993 19 Outrage we share on the East Coast has the exact same console cover- Cooler, RPS and Console. It, too, is secured by bottom snaps. We have no extra access points (like a zipper). Two down sides- several of the snaps no longer function, on one side of the snap or the other. That is the nature of snap-fitted canvas I believe. The other is given the heights of the 3 covered items, it has to be put on and removed in one order only. It might have been nice to have a zipper somewhere that made removal and fitting a bit more flexible. The pluses- well the three items are well protected, clean when you remove the cover, there is little sun wear, and the SUNBRELLA [fabric] has held up well. If you do not have wood gunwhales to protect, I think it is an ideal cover for seasonal boating with a Whaler. |
davej14 |
posted 08-10-2010 10:51 AM ET (US)
I have a Mills cover for my console which I had modified. The top was modified to fit the GPS antenna on the top of my console rail and a zipper was added down the side to allow it to go around my VHF antenna. There is reinforcing in the area of the steering wheel and at the top console rail. The Mills cover is shaped so that it does not block the console door. I strongly recommend you make accommodation for this if you intend to have the cover extend to the deck. A zipper on each side of the door with velcro to hold the "flap" up during access would do the job. Consider the wind forces when on a trailer at 70 MPH. Make sure the zippers close from the top down. I had to have a flap added with a velcro closure at the bottom of the zippers to keep them from partially unzipping themselves when on a trailer. I'm not sure I would include to cooler in the cover. You may want to change the size in the future. |
Jeff |
posted 08-10-2010 11:07 AM ET (US)
Pete, We had a console cover and RPS cover made for our Montauk that worked great for hauling on a trailer many many miles. We had it made for while we were out on vacation and did not want and need to haul a mooring cover. It was made out of a vinyl impregnated canvas and had 4 swivel snaps holding it down. We had zippers to access the console doors so you did not have to remove the canvas to get into the console. Also, with the set up like this it allowed us to keep duffel bags between the console and RPS under under cover while traveling. There are some good images of this set up in this folder. http://smg.photobucket.com/albums/v427/jeff_rohlfing/dads%20whaler/ ?start=all
home Aside |
posted 08-10-2010 11:51 AM ET (US)
A lot of great ideas here, this is why I love this site!!! I had a console cover on my Montauk that only covered the console, it had a zipper at the back center that allowed access to the helm door and snapped at the bottom, I also had a Mills RPS cover that covered the seat back & only to the bottom of the cushion portion of the seat. It had a draw string. Both worked well, but I do like the idea of one cover for the whole shebang and as Jeff said the ability to store duffles under it while hauling on the trailer. One benefit I liked about having the individual cover for the RPS was that when I had my Montauk and was doing the North Channel and other trips, I had only the Forward shelter, fly-top and windshield. Obviously there was limited storage space when camping & running the boat in the rain. I could put a sizable duffle on my RPS seat, cover it with my RPS cover and it would stay dry while underway, as well as making for a decent leaning post so to speak. I think you should consider the snaps, it seems that swivel snaps would be less likely to come undone when on the trailer, but then again things that do not have moving parts to wear out don't break, malfunction as easily, etc... Pete,I don't know if you looked closely at the cockpit cover for hauling on the trailer on my Revenge when we were leaving Frankfort, but it's made with Top Gun Fabric instead of Sunbrella. Top Gun Fabric is like a vinyl impregnated Sunbrella fabric, it is indestructible and waterproof, my canvas guy, (SHAMELESS PLUG: The Kanvas King Livonia, Mi) demonstrated it by driving a screwdriver through it & then had me try to rip it open from the hole, I tried & tried to no avail, it's great stuff, I would certainly consider it for your application. By the way I had my cockpit cover made so it used only existing snaps already in place for my Mills canvas Camperback Canvas, they are the regular snaps and none have come undone while hauling on the traielr, even for extended periods of time at 65- to 7-MPH on the highway. Good luck Pat |
home Aside |
posted 08-10-2010 12:03 PM ET (US)
Another thought, instead of snaps, mount strap brackets to the deck (like the ones used to strap battery boxes to the deck). and have a straps with velcro sewn at the bottom of the cover to run through the bracket & secure it that way instead of snaps |
Jerry Townsend |
posted 08-10-2010 12:06 PM ET (US)
Pete - consider having your cover made with a "Herculite" material - a vinyl impregnated nylon fabric. Herculite is the name of the company - but also of the material. Herculite is waterproof and virtually indestructible - won't tear, burn, rot, et al. - the only material certified for Naval Gun Covers. I have used the material extensively - covering the boat ('96 17 Outrage) when not being used (on trailer, parked in the driveway, etc), horse packing panniers, tent floors. --- Jerry/Idaho |
PeteB88 |
posted 08-10-2010 02:21 PM ET (US)
Thanks and keep the info coming. I already thought about zipper access to the console door (big door, awesome console with tons of usable space and my battery (maybe soon batteries) are in there. Would be great for access and for hooking up charger (tender). I do not think I want zipper access to console radio bay just above the steering wheel. Andy, the Amish canvas man, already discussed Top Gun which is fantastic and looks totally bombproof. I told him I would worry about abrasion to the pristine gelcoat on my console and he said he has had some complaints about that with Top Gun in some applications. He did not say anything about Herculite but I will ask, Jerry, it looks like there are several different options for Herculite - which one is yours? Andy also showed me a vinyl option with fuzzy backing but I am not sure how well that would hold up in the long run. I have a Mills Bimini and Take A Tan Ellen mentioned something about "the fabrics should match buckaroo..." and I said "What?" but Sunbrella matches exactly. AQUALON? anyone heard of Aqualon? I am calling Andy to confirm his first recommendation (fabric impregnated with vinyl) but I think it is Aqualon which is $5 bucks cheaper per yard than Sunbrella. SNAPS VS TURN FASTENERS - Bart, previous owner of the boat, had a console cover for it but could not locate it when I picked the boat up last year and apparently hasn't since. The snaps are screwed into the bottom console brackets, each cooler mount (one each) and RPS. There were are very few snaps. Jeff suggested turn fasteners which make sense but canvas man warned that they stick out and passengers could stub their toes or they would catch things because they stick out. Since I broke my toe (really did) stubbing the sucker jumping around in my boat a few weeks ago, could be an issue. However I am thinking about having a few put in for extra hold power. They can shoot them in quickly, no big deal. THANKS - I need to get back to Andy ASAP for final instructions and I don't want to drive him nuts. AMISH shop - runs entirely on compressed air, impressive, all machines even the ceiling fan driven by air. Compressor is diesel powered, shop has air lines running all over the place. He has a fax machine (all in one printer wired to an inverter with alligator clips that he runs off 12 VDC battery. Freaking cool. I asked him about how all this fits in to their traditions and religion (garage is like two bay filled with buggies and wagons, his boys use a sulky to go fishing) and he said "Well we don't think you guys will go to Hell because you drive cars and have boats...we just like to live as simply as possible..." Makes sense to me. He said the mess around with solar and other energy sources. You ought to see his their garden!! WOA I'm hoping for the best result. Prices are great. |
PeteB88 |
AQUALON? anyone heard of Aqualon? |
Jerry Townsend |
posted 08-10-2010 07:38 PM ET (US)
Pete - Wow! I just went into their website - www.herculite.com - and there are many choices. I first started using this material over 40 years ago and the last about 10 years ago. At that time, there wasn't, as I know, any choices - other than the color. I just told our local canvas shop - use double weave/interlocked herculite in the color that I wanted. Herculite is typically all around 12 - 13 oz per lineal yard (62 inch width) as I recall. On the boat cover, they asked if I wanted a soft interior surface to minimize abrasion - yes. The boat cover is red, the tent (wall) floor is green, the packs (boy scout project) were bright yellow (so that I could see a bright yellow pack from a long way) and the panniers were a kinda dull yellow. Some truckers are using the material - but I would suspect that those applications, as well as naval applications, might use a heavier fabric. Your using an amish shop is great - as they do truly wonderful work - that they and you can be proud of for many years. Unfortunately, we don't have the amish around Idaho, but I visited one of their towns in Illinois several years ago and was truly impressed. --- Jerry/Idaho |
Waccamaw Whaler |
posted 08-10-2010 11:38 PM ET (US)
I replaced several of the screws on the console door frame and the fire extinguisher frame with 'male' snaps then marked and installed the 'female' snaps on the cover. Works great and I didn't have to put more holes in the console. Also, consider having extra stitching done and make sure they use a high quality thread. These are weak points. My preference would be to have a seperate cover for the cooler but if you go that route be sure to provide reinforced cutouts for the hold-downs. This arrangement also secures the cooler cover from blowing off. |
PeteB88 |
posted 08-11-2010 09:11 AM ET (US)
Well, I figured I was on Amish time and the cover would take a couple of weeks. As I told him yesterday, I wanted to have the boat available for possible cruise later today. I called Andy yesterday midday and thought I had some wiggle room on choosing material and he said "it's too late, it will be ready by noon tomorrow." When I dropped it off material chosen was Sunbrella for best match to Mills bimini. We agreed to consider Aqualon or another fabric and I was to call him back to give go ahead for zipper access to console and final on fabric. He matched the Mills Bimini and will install a zipper for access to the port side console door which will be great. We agreed that the turn snaps are not a great idea for anything below the ankles because of toe stubbing hazard. I can't wait to see it and will be picking it up later probably mid afternoon. I think this will be perfect for my needs. FYI - Andy's preferred material is Aqualon which I would have gone with except color match was off and I was advised by my regular crew canvas needs to match. Next could be forward shelter. I might take my Mills 13 set to see what he says. Thanks for the tips and advice. |
sternorama |
posted 08-11-2010 06:32 PM ET (US)
Depending on your climate, breathable storage canvases can help prevent mildew growth. |
PeteB88 |
posted 08-11-2010 09:56 PM ET (US)
I'll get some photos, cover done in about 24 hours, it seems great to me, Very busy w/ family priority. |
