  Ocean Viewing From Deck
Author Topic:   Ocean Viewing From Deck
Newtauk1 posted 11-01-2010 10:05 PM ET (US)   Profile for Newtauk1   Send Email to Newtauk1
I have good binoculars on my Boston Whaler. I would like to buy quality equipment to view the harbor and beyond from my deck that looks over the local harbor and on clear days far beyond.
Should I buy binoculars on a tri-pod or something else?
I want to view out over the ocean from my roof top deck.
lizard posted 11-01-2010 10:15 PM ET (US)     Profile for lizard  Send Email to lizard
Have you thought about a nice sporting scope? Nikon, Zeiss, etc.
contender posted 11-01-2010 10:19 PM ET (US)     Profile for contender  Send Email to contender
Lizard is correct
AZdave posted 11-02-2010 01:09 AM ET (US)     Profile for AZdave  Send Email to AZdave
Add Swarovski to the list of excellent spotting scopes. The initial cost is high, but you will be sharing the fun of amazing performance for the rest of your life.
Newtauk1 posted 11-02-2010 01:45 AM ET (US)     Profile for Newtauk1  Send Email to Newtauk1
Yes-A sporting scope was one idea. I want to view freighters in the distance and try to view some far away land structures. I can't believe I have waited this long to buy a quality device. The view has been very clear lately. I specifically look South over Gloucester's Outer Harbor in Gloucester Ma. Thanks for the responses.
-John
AllanR posted 11-02-2010 05:26 AM ET (US)     Profile for AllanR  Send Email to AllanR
Since you are going to use them from your deck you have several choices but first I would visit a site called "cloudynights.com" it is an astronomy based group but it has a tremendous amount of info on binoculars, spotting scopes and telescopes.
Another great site for binoculars, etc is "birdforum.net". They have forums on all the different brands.
Personally, I would prefer binoculars over spotting scopes. It is just a better view using both eyes.
Also you will likely need a powerful pair of 15x or more to get the reach for what you want . That also means that you will need either a tripod or stabilizing system to take out the "shakes" from hand holding.
I have a similar use from a condo in Hollywood, FL where I look over the ocean from my balcony. I use a pair of Canon 18x50 image stabilized binoculars. They are amazing. I can read ships names from miles away. And no tripod is needed, I prefer to hand hold them, which is no problem with these.
Newtauk1 posted 11-02-2010 07:34 AM ET (US)     Profile for Newtauk1  Send Email to Newtauk1
I guess I need to get out and try soem of these different options. A tri-pod would be fine for my set-up.
jimh posted 11-02-2010 07:39 AM ET (US)     Profile for jimh  Send Email to jimh
Quality binoculars are a good investment. For hand-held use there is a practical limit to the magnification power of about seven times.
tjxtreme posted 11-02-2010 08:27 AM ET (US)     Profile for tjxtreme
You will need to decide if you want a wider field of view for closer viewing, or for really far, but narrower viewing. Both have their benefits, it will depend on the situation and distances.
I suggest trying them out to see if you prefer high or low power binoculars or a spotting scope. Higher power optics tend to be darker (and for me less pleasurable)... but I'm sure if you're willing to spend enough that won't be a problem.
Dave Sutton posted 11-02-2010 08:31 AM ET (US)     Profile for Dave Sutton  Send Email to Dave Sutton
I'd suggest that you look at a god pair of 10 power gyro stabilized binoculars. I added a pair of Cannon 10 power gyros to my collection of binoculars two years ago, and they have pproven to be absolutely perfect for almost everything. They can be hand-held without any shake,work fine from the Whaler (!!) when it's not too rough, are carried in the truck at all times, and have just been super. The lack of shake is amazing. No tripod needed at all. Try a set and you will be amazed.
If you go to a spotting scope (I have one of these too), you will be locked into using a tripod. If that's OK, then these are good tools. If you do decide to go to a tripod mounted device, I'd seriously look at some of the Russian and East German military surplus tripod mounted observation binoculars that are available. A little Googling will find sources. These are generally copies of the WW-II Zeiss artillery spotting and opservation binos. Compared to a monocular spotting scope they are night and day.
Dave
