ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: The Whaler GAM or General Area Driver Thrown From Boston Whaler Boat
Author | Topic: Driver Thrown From Boston Whaler Boat |
florida1098 |
posted 04-12-2011 09:57 AM ET (US)
http://www.wpbf.com/video/27511820/detail.html |
florida1098 |
posted 04-12-2011 09:58 AM ET (US)
Still no sight of missing man. That is however one big bridge. Kinda hard to hit, especially as it is in a no wake zone. |
lizard |
posted 04-12-2011 12:06 PM ET (US)
Was it an Outrage 18? |
Fishmore |
posted 04-12-2011 01:35 PM ET (US)
This is a good reminder to check your steering and throttle cables this spring. Terrible things can happen to anyone. |
L H G |
posted 04-12-2011 05:05 PM ET (US)
I'm glad I wasn't the one who rigged the E-tec engine on that Outrage 18. I wonder what caused it to go out of control? Does the boat belong to anybody here? |
JTC |
posted 04-12-2011 05:22 PM ET (US)
I would imagine only a small minority of boaters use their kill-switch lanyards. I have an Autotether on my boat which is a fairly rudimentary, backwards compatible solution that detects when a wireless link is broken and kills the engine as if the driver had been using a normal lanyard. May not have helped in this case if they had hit the bridge, but I'm sure having the boat flying around after they fell out was not to their advantage. |
posted 04-12-2011 09:21 PM ET (US)
L H G writes: "I wonder what caused [the boat with an E-TEC engine] to go out of control?" I suspect the steering might have broken and the engine jumped to a hard-over turn setting, throwing people out of the boat. |
posted 04-12-2011 09:23 PM ET (US)
We have two threads on the same incident running concurrently. They were both started with very non-descriptive TOPIC lines which probably prevented people from knowing they were both talking about the same incident. |
florida1098 |
posted 04-13-2011 06:40 AM ET (US)
It's still an active search for the missing person, as of this morning Wed 11,13,11 |
weekendwarrior |
posted 04-13-2011 10:03 AM ET (US)
Here is the latest: http://www.tcoasttalk.com/2011/04/13/ejected-boater-still-missing-identified-as-vero-beach-man/ Sounds like a good guy, it's a shame to loose him. An unfortunate reminder to always use your lanyard. |
lizard |
posted 04-13-2011 11:40 AM ET (US)
Hard to tell yet what happened. If he truly lost an arm from a prop hit, there is no way he will be found alive. Very sad. When I moved from a Montauk to the Outrage, I gained a safety lanyard. I never leave the docks without it attached. |
nydealer |
posted 04-13-2011 02:07 PM ET (US)
They found his body: |
Eastport3338 |
posted 04-13-2011 02:57 PM ET (US)
A sad story to say the least. This accident points out one important point and that is ALWAYS wear your PFD whenever underway. From what I can tell by the news coverage is that neither passanger was wearing a PFD which in this case would have facilatated a quicker recovery of the body and quite possibly would have saved his life. He was only clad in board shorts.Was the female occupant wearing one? This also points out that when something goes wrong it all happens very quickly and there is usually no time to deal with a PFD. Sad story just the same. |
Russ 13 |
posted 04-13-2011 03:31 PM ET (US)
A SAD ending indeed. And a reminder that when thing go wrong, it is usually quickly and without warning. A safety lanyard & lifejacket would have made a BIG difference in this accident. Maybe keeping Mr. Hill shallow enough in the water to aviod being hit by the prop. SAFETY LANYRDS SHOULD ALWAYS be USED WHEN BOATING ALONE. |
martyn1075 |
posted 04-13-2011 04:17 PM ET (US)
It is very sad! I am thinking something must have pushed that engine over in the first place. Hard to say if it was a submerged dead head maybe. I would think if you were in the making of a turn then the crew would be prepared but it happened suddenly within seconds. Is there a mechanism on the ETEC or other modern engine that can override the throttle? In other words if you were to hit something that damages the lower end would the engine computer send a response to lock up the throttle? I only ask because it would seem an experienced boater such as Mr. Hill would likely pull back the throttle if something were to happen. Its sounds like a chain reaction that resulted in an out of control boat that could not be settled down using the obvious methods and there was no time to react especially if the experienced operator was sadly knocked over. If I was a family member I would insist on having that ETEC looked over with a magnifying glass to rule out any possible freak malfunction in the computer. This may not be the case but I would want to know the family deserves at least this and I am sure that insurance and rescue crews will feel the same. |
weekendwarrior |
posted 04-13-2011 05:12 PM ET (US)
Hopefully they will release more info in the coming days. Steering is not complicated, my guess is the boat hit something or the nut fell off the steering bar disconnecting it from the motor. Either is enough to throw a person on to the throttle. One news article mentioned something obviously broken on the steering but no details and I haven't seen any additional info on the topic. |
florida1098 |
posted 04-13-2011 06:23 PM ET (US)
Just a quick note, the area all around the bridge is a slow speed, no wake zone. This was not so about a year ago, when it was 25 mph max, and I am just wondering if Mr. hill being from Vero, about 75 miles away was not familiar with the new speed reg's. Really don't know if this would make a difference but, a change in navigation rules for whatever reason, may cause different reactions in different operators. Just a bit of info, nothing to cause a reason for accident. |
domlynch |
posted 04-14-2011 03:27 AM ET (US)
Very sad, not much to say except sympathies to his family and loved ones. This is precisely the reason why on my inherited Classic Montauk I'm getting a safety lanyard switch added - as we speak.(even before I knew about this tragedy). I'm relatively new to Whalers and whilst they may be unsinkable, the low sides to me (at first)are a little disconcerting, as in Australia we usually fish offshore (in often sloppy water which pitches the boat) with boats that have high sides - which help not only in keeping water out but perhaps more importantly the crew in (ie onboard). Yes, I know there's handrails etc etc, but falling overboard is potentially a recipe for disaster, even in calm waters. I feel one has to operate assuming one could fall in the water even in calm conditions - use your lanyard + wear a comfortable PFD (lifejacket)and don't go alone - at least that way if things go pear-shaped you have a good chance. Not to mention hypotermia from prolonged exposure - but hey you actually have to live long enough in the drink to get hypothermia.... As a survivor of a calm water capsize (13ft dinghy, 15 Yamaha tiller steer, tiller was let go at WOT by accident, flipped in an instant, jack-knifed the rig, lucky it was on an inland river, lost all gear etc etc), you can't take any chances. I feel one should operate on the assumption that "if you go in the drink you will not be coming out alive", brutal as it sounds. Here in Sydney Australia we lose a lot of rock fisherman - I've done a fair bit of it, it's very exciting but no fish is worth a life. If risk assessment is done & appropriate hazard reduction measures undertaken we can still enjoy the water in a relatively safe way. |
Peter |
posted 04-14-2011 08:14 AM ET (US)
This is truly a sad situation and clearly emphasizes the importance of using a lanyard and testing it to make sure it works. Some comments and answers to:
quote: and
quote: How do we know the boat had an E-TEC? I looked at the video and could not determine that it had an E-TEC. It had a white motor which could have been a Johnson, a Evinrude Ficht or an Evinrude E-TEC. There is no computer driven mechanism in a DFI outboard that can overide the throttle input. Once you understand how the whole system works, you should see how an unlikely computer error is not the cause. How does the DFI system work? The mechanical throttle linkage at the binacle control is connected to a cam on the motor via the cable. When the throttle is moved, the cable causes the cam to rotate about a pivot point. There is a thottle position sensor lever with a roller which follows the cam causing the TPS to rotate about another pivot point. The TPS lever is also connected to a throttle plate control rod. See images of a cam, TPS and the throttle plate control rod that is connected to the throttle plates in this thread ==> continuouswave.com/ubb/Forum4/HTML/004995.html . The rotation of the cam and TPS lever adjusts two things: 1) the opening of throttle plates and 2) the angle of the throttle position sensor (TPS). The TPS provides a voltage input to the computer which the computer interprets to determine how much fuel to inject and how to set the spark advance. The throttle plates in a modern motor regulate the amount of air flowing in. Basically, the TPS tells the computer what is going on with throttle input. If the computer became unresponsive to the throttle position sensor or the TPS became unresponsive to the actual throttle position (let's call it getting "stuck")causing the computer to continue injecting fuel at the same higher rate even when the throttle was pulled back, the throttle plates would still close off the air flow, assuming the linkage between the binacle control and the cam was not broken. The lower air flow relative to high fuel flow would likely cause the motor to stall out. It certainly would not make more power. I'm guessing that something failed with the steering system because long ago (before lanyards) I saw a very similar situation where a person was tossed out of a Whaler because the steering system broke and the boat was doing circles around the ejected driver. Fortunately, that person was able to grab hold of and yank the fuel line off the motor when the boat circled around causing the motor to run out of fuel not long after and come to a stop. This incident is a good reminder to go over the steering system and make sure that its in good working order and that the connecting nuts are fastened with the proper torque. And, of course, wear that lanyard and make sure it works! |
posted 04-14-2011 09:09 AM ET (US)
The notion that the engine was an E-TEC was introduced by Larry, L H G. Larry also introduced the notion that there was something that went wrong in the E-TEC that might have been causal. I don't see any other source of information about the E-TEC or its role in this accident other than Larry. |
erik selis |
posted 04-14-2011 09:26 AM ET (US)
I think that Larry may be correct. To me it also looks like an E-Tec. If you check the video at time-line at 2.05 you can see it's an E-Tec. I think it could happen to any engine brand and has nothing to do with the fact that it was an E-Tec. Erik |
erik selis |
posted 04-14-2011 09:31 AM ET (US)
I see how Larry got mislead...it is in fact a different boat with the E-Tec ! |
Tom W Clark |
posted 04-14-2011 09:58 AM ET (US)
The motor is a 150 HP Evinrude E-TEC. It is plainly visible in photos on the deceased's Facebook photo album as well as other news stories. If the steering system failed, that is not Evinrude's problem; Evinrude does not manufacture steering systems, somebody else did. I am surprise nobody has commented on the condition of the boat itself. It appears that the console grab rail has been torn loose as well as the Bimini, almost as if the boat went under something low and tore everything off. If that were the case, it is entirely possible the throttle lever was caught by a Bimini strap and pulled to a WOT position. This could easily eject the occupants. I watched this happen once to a Montauk at my local marina. Two guys came in from a morning of fishing and as they cleared the end of the breakwater and were idling to the ramp, they began to prepare the boat for loading onto the trailer. This included lowering their canvas system and while doing this a strap caught the throttle lever and pulled it. The boat instantly shot forward and turned hard to starboard propelling itself up onto the rock breakwater until almost the entire boat was out of the water with the bow pointed towards the sky. It happened in an instant. The two guys were fine, but shaken. I inspected the hull after they got it loaded onto the trailer and there were only scratches on the hull and a broken motor skeg and mangled propeller. |
towboater |
posted 04-14-2011 11:10 AM ET (US)
Glad the gal made it. Here is her statement: First he was driving and we were approaching the bridge and he went to put it into slowdown neutral because we were getting into a slow zone. And the next thing I know, I woke up and I was trying to find the top of the water.” We walk and climb up, down and around narrow decks on Tug, barges and sport boats without lanyards in all weather night and day, but, NEVER without a life jacket. NEVER. ------------- Her statement implies a mechanical malfunction and the Seatow crew said the steering arm was not connected. Im here to tell you, stainless nuts will back off by themselves. And, nylock nuts are only good one time you tighten it up. As soon as you remove a nylock nut it loses its ability to lock...it is garbage. Check your steering arms to make sure you have a new nylock or that it is double nutted TIGHT or cotter pins are in good shape or all 3. A single ss nut is a recipe for disaster. Mike |
Tom W Clark |
posted 04-14-2011 11:15 AM ET (US)
The boat collided with something: http://www.tcpalm.com/photos/galleries/2011/apr/11/ boat-accident-st-lucie-river/63772 http://www.tcpalm.com/photos/galleries/2011/apr/11/ boat-accident-st-lucie-river/63773 http://www.tcpalm.com/photos/galleries/2011/apr/11/ boat-accident-st-lucie-river/63775 |
towboater |
posted 04-14-2011 12:03 PM ET (US)
Tom, thanks. The gal does not mention running into something. She says last she remembers is slowing down for no wake zone. Ive gotta go with that. Im not convinced the damage on the bow the photo's reveal was not caused by Seatow rescue. Ive been involved with a runaway boat cookie cutting and simply quartered the tug into the cookie..it bounced off without harming the Tug, lassoed the engine, (14 ft alum skiff was not wot). Skiff had some damage in same area as the Whaler does. Rescue boats are pretty good size, gunwales are higher than the whalers bow. Looks like tending the Whaler until it ran out of gas was an option but...hate to second guess those guys. Sounds like Seatow and BoatUS did a great job, will be interesting to hear their story. |
Tom W Clark |
posted 04-14-2011 12:51 PM ET (US)
The passenger's statement does not imply a mechanical malfunction, it does not imply anything. Obviously there is a gap in her memory like one might suffer if they hit their head and lost consciousness momentarily. Yes, the damage might have happened when they got the run away boat under control...except that it is visible while the boat is still turning doughnuts. Furthermore, the damage is in the bow as we might expect if the boat ran into something, and at a good speed. With the boat tuning tight circles, the much more likely point of impact with a rescue boat is the stern quarter. |
Tom W Clark |
posted 04-14-2011 01:03 PM ET (US)
The boat was turning circles to PORT, not STARBOARD. Unless this motor is a counter rotation model, propeller torque would cause the motor would slam to STARBOARD if the steering were suddenly disconnected. Damage is on the PORT bow. No way that happened while they corralled the boat. |
onlyawhaler |
posted 04-14-2011 01:26 PM ET (US)
A very sad story. I look at my early and late season fishing alone down at Lake Powell and I almost never wear a vest or attach a lanyard. Something like this or striking a submerged rock or a number of things could happen to any of us. Whalers dont' make us invincible. I have ordered a new lanyard and a Mustang PDF inflatable and I am going to use them from now on. Onlyawhaler |
Peter |
posted 04-14-2011 01:30 PM ET (US)
There is more to this story.... www.tcpalm.com/videos/detail/surviving-boater-reflects-tragedy/ According to this clip, if I've got it right, the Outrage 18 was NOT the deceased's boat, but belonged to the boyfriend of the woman victim and the deceased is not the woman victim's boyfriend but just a fishing buddy that she fishes with day and night. Stay tuned...... |
weekendwarrior |
posted 04-14-2011 02:46 PM ET (US)
Theory 1: I saw reference to a bridge somewhere. Maybe as he aproached the bridge the steering arm fell off causing the boat to turn port and strike a piling. The strike was not the cause but a side effect of the steering failure. If someone can proove that the boyfriend just learned about these two, then I am sure I'm not the only person thinking that maybe the steering bar nut was loosened intentionally. I have nothing to support this theory, just thinking out loud. |
Binkster |
posted 04-14-2011 04:53 PM ET (US)
Well, I wouldn't be too happy about some dude going fishing with MY girlfriend in MY Whaler. Wonder who`s fishing tackle he used anyway, hope he at least brought his own. What`s with that whole deal anyway. I also don`t buy the fact that the steering link suddenly pops off the steering arm when going under the bridge. Usually when used in salt water, you need to heat that nut to get it loose. |
lizard |
posted 04-14-2011 07:01 PM ET (US)
I am not sure speculating about the relationship between the deceased and this woman adds to what happened with this tragic accident. In fact, I watched the interview in Peter's link and found it obvious and distasteful. A man died. |
Russ 13 |
posted 04-14-2011 08:06 PM ET (US)
Usually that steering drop tie arm is stainless, and that missing nut is a stainless nylock. Could it have vibrated loose...sure, if it had been removed & reinstalled with a less than good nylock area. Brings up a good point to double check that area of the steering. And use the lanyard/kill switch. Most unfortunate that the operator died, in this case. |
towboater |
posted 04-14-2011 10:36 PM ET (US)
Tom makes a good point, a failed steering arm on a rh wheel would turn to stbd...as was the case I experianced. Some things that happen on boats cant be explained. |
martyn1075 |
posted 04-14-2011 10:58 PM ET (US)
weekendwarrior...could be right but if the boat starts to turn would you not just pull back the throttle? Some will say there is no time but we don't know what happened. A good captain always has one hand on the throttle while underway if something happens you can always pull back. Thats why still think a freak computer glitch with the engine that links the control might have locked into high gear. Something sounds wrong and I think it may start with the female friend. Perhaps she was driving? lost control. Its hard to say when her story is so vague. If another boat was involved how could she not see anything. Considering there was no lifejackets, if she was unconscious and blanked out she would have likely drowned. Its a weird one and sad as we all have mentioned for the deceased. |
weekendwarrior |
posted 04-15-2011 06:36 AM ET (US)
If you've ever been in a boat that has suddenly changed direction at speed, there is no holding on. I mean if he had one hand on the throttle and one on the wheel and the boat suddenly changed direction such as a full turn port or starboard, despite his best intentions he may not have been able to pull the throttle back at that point. He may not have been able to hold on at all, the sudden force is just too much. Something funny definitely happened. Properly installed steering rods don't just fall off, so if that's what happened then there's more to the story. Hopefully they'll publish more info soon. |
posted 04-15-2011 08:52 AM ET (US)
What is different about this propeller strike accident than prior ones which has caused so much speculation about the use of electronics to control the fuel flow in the engine? In the most famous incident of an outboard engine propeller strike, the Spreitsma accident, I do not recall L H G suggesting that there was anything about the Mercury engine that might be causal or that the Mercury engine should be closely investigated. Here we have L H G spreading his usual fear, uncertainly, and doubt about E-TEC engines. I don't think it is really appropriate to take a tragic death of a boater and try to leverage it for use in the all-out FUD campaign against E-TEC engines. http://www.publichealthlaw.net/Reader/docs/MercuryMarine.pdf |
Tom W Clark |
posted 04-15-2011 10:49 AM ET (US)
I agree that the personal lives of those involved in this accident should not be discussed here. The technical cause of the accident is relevant to Whaler owners and boaters in general. Let's take what lessons we can from this tragedy. If the operator has a hand on the throttle and the boat hit something, as I suspect it did, the operator's body would be thrown forward and this includes the arm holding the throttle. It does not take much imagination to see that the throttle would be "firewalled" in an instant. The passenger's description of her last pre-accident memory is of holding the console and the operator's arm. Photos of the boat show there was no windscreen on the console nor the normal grab rail, though there were some custom made very low-profile grab bars on the top of the console. If he boat were to hit something and suddenly decelerate and/or change course, there is damn little to keep both parties from going overboard. The gunwales are low, the gunwale grab bars are behind the helm position and neither one of them probably had a good grip on the boat. I've very nearly had this happen to myself. Years ago, in my second Montauk I was cruising along with two passengers, all three of us standing at the console. The motor's gearcase snagged a large sponge or piece of foam rubber floating just below the surface and wrapped it self around the gearcase causing instantaneous and massive ventilation. I made the mistake of removing my hand from the wheel to chop the throttle and in an instant the boat tuned to starboard and we were all thrown to port. I was standing to port and my body went over the Montauk's side rails and the only thing that keep me from going in the water was that I was able to grab the side rail behind my back with my fingers, the rail resting under my lower spine. My two passengers were piled up against my legs. It was a close call. |
martyn1075 |
posted 04-15-2011 11:24 AM ET (US)
Tom I think you are right if there was impact while underway the force could likely push the body weight forward makes logical sense. I hope the investigators make some sense out of this. |
Tom W Clark |
posted 04-15-2011 03:35 PM ET (US)
The E-TEC 150 is a counter-rotating model. That explains why the boat was spinning to PORT. |
Binkster |
posted 04-15-2011 05:39 PM ET (US)
Getting ejected from a boat is easier than you might think. |
weekendwarrior |
posted 04-15-2011 08:39 PM ET (US)
Here's another example of why you should wear a lanyard, even on a big boat: http://www.youtube.com/watch?v=ZSxK9bhMNj8 |
Basshole |
posted 04-17-2011 02:41 AM ET (US)
Very tragic story. I lost two friends in San Francisco bay in a Montauk in 1995 because of the same reason. One of them was an incredible fisherman and a great guy. He would still be here had he been wearing his lanyard. And Larry, it happened while breaking in a brand new Mercury. It can happen with any brand of motor if the necessary precautions are not taken. |
weekendwarrior |
posted 04-17-2011 11:49 AM ET (US)
Does anyone have updates for this story? I haven't seen any new info in the news and I'm very curious to know what the investigators think happened. |
towboater |
posted 04-17-2011 12:50 PM ET (US)
Counter rotating engine. Im back to mechanical malfunction, possibly the steering arm let go. If you havent read my first ramble, I think the nut on the elbow dropped out, nothing else makes sense to me. The damage shown on the bow does not convince me they collided with something...but, lets assume they did. If it was another boat, where is the other boat? If it was the bridge pier, where is a mark on the pier or a reference to it? Damage is slightly to stbd bow and the boat was circling to port. How could you hit a bridge pier on the stbd bow, eject and end up circling to port wot? Push against a dock, bow first, idle. THat is a wide angle video and photo, no bridge in sight. mkj |
florida1098 |
posted 04-20-2011 03:50 PM ET (US)
The only update in the news is the female survivor admitted to drinking all night with the male deceased, but claimed at the time of the incident they were not drunk |
Tom W Clark |
posted 04-20-2011 10:47 PM ET (US)
Mike -- The bridge is not in sight because most of the videos/photos were shot *from* the bridge. I am almost certain the boat was driven into a piling, and at a good clip at that. The passenger was rescued and the rescuers said they found her clinging to "one of the pilings." Broader photographs of the bridge show a line of sign-bearing pilings before it. TowBoatUS captain Woody Woodruf, who helped with the rescue, said he thought the passenger had hit her head on the boat. One news account had her initially unable to recollect the name of the boat's operator. This video shows both the counter-rotating propeller and the steering arm of the motor, which does not appear to be connected to anything. Sea-Tow captain Ryan Pratt said the "steering arm was clearly broken" yet the video shows this is not the case. It is merely disconnected. Pay close attention (in full screen) starting at at 1:13 |
towboater |
posted 04-21-2011 02:06 AM ET (US)
http://www.wpbf.com/video/27511820/detail.html http://www.wpbf.com/video/27511820/detail.html There is a bridge and a couple of blind pilings in the area. Also sounds like there is some current in the St Lucie river, along with a bit of wind the boat would slowly spiral downstream after a collision with a piling that ejected passengers and broke the steering arm. Also appears the yellow ridgid Seatow was the primary rescue boat and wouldnt crack the whaler in the bow that bad. Thing that gets me, I know you know wheels like I know pilings, pretty damn smart for a Married guy in Puget Sound to figure out that was a counter rotating engine so quickly. I owe you a beer. mike
Whalrman |
posted 04-21-2011 03:49 PM ET (US)
Yes, there is a good tidal flow in the St. Lucie river. That section of the river does get windy, although not as bad as the next inbound leg does. |
FISHNFF |
posted 04-21-2011 05:09 PM ET (US)
Hey Scott. shoot me a line. Dave was my best friend, and I knew Mike as well. I was working that day. Otherwise I would have been with him. Dave's boat, which I acquired afterwards, was found hard to port. He/we had the older Teleflex steering before the NFB, and the boat would turn port when let go. We used a bungie to keep a steady course. Replaced steering immediately afterwards. A very tragic story. As for lassoing the boat. If you lay enough rope in its path, you would eventually wrap the prop and kill the motor. FISHNFF |
weekendwarrior |
posted 04-21-2011 05:41 PM ET (US)
I'm sorry for what happened to your friend. If you had a chance to look at the boat, can you tell if the steering rod fell off from a loose bolt or something, or if it was damaged due to the crash somehow? |
TommyWhaler |
posted 04-21-2011 05:56 PM ET (US)
The video posted by Peter in which the female victim is being interviewed points out just how much news people are bottom feeders. |
