Topic: Lending Aid To Other Boater: Jump Start
padrefigure |
posted 04-25-2011 12:21 PM ET (US)
Yesterday at the boat ramp another boater asked for help. His battery was dead and he asked if I could give him a jump start. After reading all the horror stories about wiping out EMM's with sags, surge, spikes and other electrical gremlins, this made me quite nervous. At first, I politely declined. After launching the boat, my conscience got the best of me, so I grabbed the jumper cables out of the truck and idled up to the stranded boater. I turned off the motor and turned my battery selector to "OFF". Then I connected the jumper cables. A couple of minutes later, the stranded boater was up and running, I stowed the cables, and headed my way. My question is whether or not my precautions were sufficient to protect my engine electronics and what you might have done differently (other than leave another boater stranded.)
Chuck Tribolet
posted 04-25-2011 01:05 PM ET (US)
Your precautions were more than sufficient. Chuck
posted 04-25-2011 01:08 PM ET (US)
Your method of setting the primary power distribution switch to OFF was a good protection for your electronics and engine. That was good thinking.I don't like the process of making any sort of temporary connections between batteries or boat electrical systems. Since this situation was at the launching ramp, there was no real imperative that the other boater must be aided, at least not like there would be on the water if his boat was stranded at sea. I would have suggested he take the battery out of his car, bring it to the boat, and give himself a jump start from his own car battery. You could offer to watch his boat while he went to the car. Many years ago in a remote anchorage I watched another boater make extensive use of a power windlass to raise his anchor and re-set it a number of times. Then, he played music on his loudspeakers all afternoon and evening. The next morning he rowed over in his dingy to ask me to help get his engine started--his batteries were all discharged to the point where they did not have enough energy to crank over his engines. My boat had two batteries. I disconnected one and gave it to him. He rowed back to his boat and got one engine started, then the other, then switched to one of his own batteries and brought mine back. In this case the fellow was going to be stranded about 30-miles from the closest marina. He also had his family on-board, including some young children. In that situation it seemed that lending aid was called for. Years ago one might have said that boaters were a collegial sort and would gladly help each other out when needed, but today I am not so sure that still applies, particularly at a launching ramp on a weekend at a crowded access point. Again, out in the wilderness, you will get more cooperation. |
Tom W Clark
posted 04-25-2011 01:25 PM ET (US)
Chuck is correct.I would have helped that boater too, though if it was an outboard I might have helped the fellow rope start his motor because it might simply have been less effort than rigging a jump. I might also have been a good lesson for him; few people realize easy it is to rope start a large outboard with an emergency starter cord. |
Chuck Tribolet
posted 04-25-2011 01:41 PM ET (US)
My Evinrude 90 doesn't have a facility to rope start.The other thing to remember is to connect the jumper cables in the correct order: Recipient + Donor + Recipient - Donor - Removal is the reverse. Chuck
Tom W Clark
posted 04-25-2011 01:44 PM ET (US)
Not all outboards do and sterndrives and inboards cannot be manually started. |
pcrussell50
posted 04-25-2011 02:45 PM ET (US)
My v4 crossflow Evinrude 135, has a groove in the flywheel and a t-handled length of rope for emergency cranking. It is not a recoil starter. If Chuck's Evinrude 90 is also a v4 crossflow, it might have the same feature... might... but I guess maybe the newer ones might not. I think my 1993 115, (also a bubbleback v4 crossflow, does not have a rope and a grooved flywheel).Anyway, with high compression like my '75 "bubbleback" has, I would not want to try to start it that way... And I'm more or less fit and strong. -Peter |
Tom W Clark
posted 04-25-2011 02:55 PM ET (US)
Peter -- Chuck's newer Evinrude has a flywheel shroud and no notch. I consider that a real weakness in terms of safety, but I suspect by 1997 the lawyers had some say in the emergency rope start feature. Maybe new outboards no longer have this feature; all the manufacturers provided it in the old days.You should try it on your motor and see how easy it is. I've started my V-6 150s many times. |
weekendwarrior
posted 04-25-2011 03:14 PM ET (US)
Out of curiosity, have you looked at the flywheel under the shroud? My Honda has a shroud but the flywheel is also notched for a rope. 3 bolts hold the shroud so you can have it off in short order. |
contender
posted 04-25-2011 03:30 PM ET (US)
Do the 4 strokes have a notch in the fly wheel?, I have started my 1985 140 Looper Evinrude but it was hot, do not know if I could do it from a cold shut down...Chuck is correct on the connections do the jump battery pos/neg. 1st then the good one pos/neg, disconnect the good battery 1st then the jumped one... |
Chuck Tribolet
posted 04-25-2011 05:10 PM ET (US)
I can have a look the next time I'm down at the dive shack (boat lives there, I only live there on the weekends). But IIRC, it doesn't have a notch. Chuck
Chuck Tribolet
posted 04-25-2011 05:12 PM ET (US)
That's not what I said. The order of connection is determined by two issues:No sparks near the recipient so you don't touch off hydrogen No sparks if you accidentally ground the + clip. That leads to what I posted. Chuck
home Aside
posted 04-25-2011 09:08 PM ET (US)
On our 2004 North Channel trip I spent the better part of a week pull starting my 1982 Evinrude 90 hp. A bolt to the starter came out & two other bolts broke off rendering the starter useless. It was a good learning experience, I disconnected the starter, taped all the leads & pull started the rest of the tripPat |
home Aside
posted 04-25-2011 09:09 PM ET (US)
posted 04-25-2011 10:21 PM ET (US)
If you have outboard engines that cannot be pull started, then your boat should have two batteries, and they should be arranged so that one is always ready as a backup for the primary engine starting battery. Anyone who drives their boat to a launch ramp with a dead battery in the boat should not expect their lack of preparation to require other boaters to donate their time to assist them. Knowing if a battery is charged or not does not require any special perception or skill. Of course, there are situational variable which might alter this thinking. |
padrefigure
posted 04-25-2011 11:31 PM ET (US)
Thanks for the replies--glad to know that I do not have to worry about my EMM for the time being. My engine is a 2010 Etec 200, so that is a pretty big deal to me. The stranded boater was in a pontoon boat with an older 50HP Yamaha. It did not have a recoil starter and the layout of the rear bulkhead(?) of the pontoon would have made rope starting the engine problematic. I generally follow the rule that if you CAN do something to help safely, you SHOULD do so. I recognize that there is risk in such benevolence. Perhaps the boating gods will send someone of similar ilk my way when I experience mechanical challenges in the future. |
andygere
posted 04-26-2011 01:04 AM ET (US)
These guys that are asking for a jump start at the boat ramp, I always wonder what their plan is. Do they just run the motor for the rest of the day, never turning it off? How do they know if it's a bad battery or a malfunctioning charging system? Do they just hope there's a guy floating by with a pair of jumper cables the next time they need to start the motor, where ever that happens to be? Had this guy asked me for a jump, I'd say "Do you need to get it started so you can load it onto the trailer and get the problem solved?". If the guy says "No, I'm going boating" I'd decline to help him. That guy is just headed for more serious trouble later in the day. |
posted 04-26-2011 01:40 AM ET (US)
Andy--You've made some very good points. |
Tom W Clark
posted 04-26-2011 09:19 AM ET (US)
I would tend to agree with Andy if not for the fact that I have myself, a few times in my life, launched at the ramp and found I did not have enough power in my battery(s) to start the motor(s).These things happen. I will also point out, that in over three decades of boating with electric start outboard motors, I have never asked anybody for a jump start. I know I can aways get my outboards going with a $2 length of cord. I think the most common thinking with dead batteries at the start of the day is that once the motor is going, the battery will be charged up in short order. This may not be true of a poorly maintained battery but it is true of a sound battery that has simply become discharged due to time or some minor but overlooked draw on the battery. I have found, when boating, as in life, that doing all you can to lend assistance when asked, will be rewarded by the offer of assistance when the need arrises. Some people call that karma. I call it common sense and decency. |
Hoosier
posted 04-26-2011 09:40 AM ET (US)
I carry one of those battery powered jumpstarters in my cars and my boat. It's a lot easier to carry it over to the "victum" than trying to position a vehicle/boat so jumper cables will reach.They are also a lot safer since there is only one set of connections to make and they have polarity reversal protection. |
I recall reading some time ago--in the distant past--that in a typical car one had to drive about 20-miles at highway speed in order for the battery charging circuit to produce enough energy to replace the energy used from the battery in starting the car. Of course, this is a very rough approximation and subject to many variables, but for some reason, ever since reading that, I have kept it in mind when operating my car. I don't think the 20-mile-rule is absolutely rigorous, as many car batteries survive start-and-stop driving with legs shorter than 20-miles, but the general concept is valid. If the 20-mile-rule were valid, there would be a lot of mini-vans in the suburbs that could not get started after a day of shopping.How much energy drain occurs in starting also depends on the amount of cranking needed to start. If the engine fires right away after one revolution of the crankshaft, there won't be a lot of battery drain. If you have to crank over the engine for 20-seconds to start, there will be much greater energy drain from the battery. The charging circuit is also a variable. Some engines can produce strong charging even at idle speeds, and other engines cannot. In some extreme cases, like the Mercury VERADO outboard engine with electrically boosted power steering, the engine consumes so much electrical power that its net charging current output is very marginal until the engine speed is increased above idle. When I started my GMC Suburban this Spring after it has sat unused for several month during the winter, I could tell by the cranking speed that the battery charge level was not very high. Abiding by the rule, I drove the truck more than 20-miles without shutting off and restarting. |
Buckda
posted 04-26-2011 09:50 AM ET (US)
To answer the question about "newer" motors and pull-start options; this was one of the reasons I selected E-TEC motors for my 18 when I repowered her. The 2006 E-TEC 90 HP motors came with an emergency pull-start cord under the cowlings.I haven't tried to start them by hand yet, but my 2000 Johnson 130's have a notch in the flywheel for rope starting as well. I consider this an important safety feature, as well as the ability of the engine to continue to operate without electrical input from the battery...which is why I did not purchase OptiMax motors for my repower project, as they are net USERS of electrical current at lower operating speed. |
skinnywater
posted 04-26-2011 10:00 AM ET (US)
I have the habit of starting my boat on the muffs prior to leaving for the launch ramp - I figure that gives me the opportunity to discover problems before I get to the ramp. I just like having the knowledge that the engine is going to turn over and function properly at the dock without hassle, and when I pull away I feel more secure that I can power up more efficiently i.e. no bogging down or stalling [or possible damage?] because the engine has been warmed prior to applying that first burst of WOT to get up on plane and push away.Last year the wife and I had a later evening opportunity to go out on the water on our 2007 170 Montauk - a beautiful end-of-summer evening coming on with about 2 hours of daylight left and we had only been out twice - so I hooked the boat up as she got her bathing suit on and my OCD took over when she jumped in the truck next to me - I hadn't run the engine (did the whole fluid and walk-around safety check thing but she was back out before I could hook up the muffs). I started to pull away but just had to finish my routine - luckily it turns out - my bilge switch was somehow engaged and the battery was stone dead(!) Funny thing is that I had seriously tried to convince myself to just simply keep going because I do take reasonably good care of my 'toys' and my stuff 'always' works on the first or second try - and my wife was so disappointed that I just couldn't, even this once, let it go and "let's just go and get out on the water [finally, dammit]". That disappointment, and the ultimate disappointment of not going now that we finally had the chance and were actually pulling away from the house - was easily surpassed by the relief that we didn't get all the way to the ramp and drop the boat in only to find out there that the battery had died. Beyond the frustration - I also, more so, do not want the embarrassment of being 'that guy' at the dock. Whether or not you did the "right" thing, you did a nice thing and you did it the right way, but I too wonder what the heck the plan is for the rest of the day once you do get a jump start at the dock - I think my plan would be to motor over to the nearest Marina and get a new battery installed. |
Chuck Tribolet
posted 04-26-2011 12:11 PM ET (US)
If you have outboard engines that cannot be pull started, then your boat should have two batteries,There's only so much room on a Montauk. I carry jumper cables instead. They've earned several six-packs over the years and paid for themselves. I've needed them for my boat once, recently, and I'd done everything right. The battery was only two years old, and had been on a smart trickle charger in the garage the prior week. The boat started find at the ramp. After the first dive, no start. I waited till I saw a friend come out of the harbor, hailed him on the VHF, got jumped, back to the dock, pulled the battery, off to West Marine for a warrantee replacement, reinstalled, back to diving. I'll stick with jumper cables. Chuck
andygere
posted 04-26-2011 12:25 PM ET (US)
Tom makes a good point about karma and being the good Samaritan, and I try to practice that. I have given many tows, loaned fishing gear and helped push grounded boats off of sandbars over the years. I recently took off my suit coat and tie to attempt to jump start some poor guy at a gas station in the middle of the central valley.With dead boat batteries, I base my caution on my own experiences. On my current and my former Whaler, I found that a problem with chronically discharged batteries was caused not by a problem with the batteries or by a parasitic load, but by a faulty charging system. In both cases, the primary cables were either badly spliced, seriously corroded or both. No amount of running the motor would really restore a full charge to the batteries. In both cases the former owners had neglected these systems, and eventually they reached a point of near failure. On both boats, I completely replaced the primary wiring. I suspect this sort of thing is the cause of a lot of dead boat batteries. |
Whalrman
posted 04-26-2011 12:44 PM ET (US)
It all boils down to the basics of taking the time to make sure everything is in good to excellent order before leaving the dock or trailer. If you have the time to pickup the 12 pack, then you have the time to do the maintanance. |
ConB
posted 04-26-2011 01:42 PM ET (US)
Two summers ago I witnessed an I/O with a dead battery at launch get pulled out of the water. The owner parked a long side of an other car and jump started the boat engine. Got back to the lauch ramp in a few minutes and relaunched the boat with the engine idling.I left before they left the dock but always wondered if they now had a cooling problem to go along with their dead battery. Con |
sdwhaler17
posted 04-28-2011 06:01 PM ET (US)
This post got me thinking that I have never tried to rope start my Yamaha 70hp 4 stroke. I checked the manual and it explains the following...1) Don't do this unless in an emergency (I get that but should I practice this before the emergency actually happens?) 2) Remove the cowling and fly wheel cover 3) Make sure the Key is in the ON position 4) Put the knot in the fly wheel notch and make a few rotations The other thing it points out that this can only be done if the battery is connected with at least 9 volts or more in order for the fuel pump to operate. It also points out do not try and replace either the fly wheel cover or cowling on an engine that is running. I guess you limp home at that point. |
kwik_wurk
posted 04-28-2011 06:07 PM ET (US)
Wow, start out of the water and shot-gun the launch. I think it could be done, but it forces you to act quickly and you become preoccupied with the running engine...leading to a mistake.I suppose if you have a closed cooling loop, your engine would be fine for several minutes. The same would not be true for the impeller, I would spray some lube and pray. |
contender
posted 04-28-2011 08:13 PM ET (US)
Andy: I have gone out before for a day of fishing (Ocean off Ft. Lauderdale) and there are days we never shut the engine off it will run from the dock until we return to the dock 6-7 hours later.I only carry one battery but I'm able to pull start the engine if needed. However this is the reason I do not let my batteries get older than 2 years for a boat, I change them out. |
towboater
posted 04-29-2011 03:15 PM ET (US)
Im with Jim, jumping bats in a boat ramp has more liability than I am willing to deal with. How I would you feel if you jumped the guy and he takes off...engine dies and still a dead battery but this time he is in the middle of the channel? ---- I used to moor right next to a boat ramp. Search CW boat ramp stories for a good laugh. Anyway, family of Mexicans, old skiff too small for everyone, dead battery. They slide the stern of their boat up onto the the sandy portion of the side of the ramp, drive their import car down, connect jumpers then leave it unattended. Tide is rising all the time, a ship comes by and the routine surge swamps their car and the boat floats off. |
johnhenry
posted 04-29-2011 04:05 PM ET (US)
I always try to help others, even when they seem to be boneheaded, I myself have done it, recently. Example: Bad year for boating last year. Great plans to use boat all season. Mom gets sick in Winter 09/10. I end up schlepping back and forth to Florida by plane from December to August-when she died. Was on vacation week when she passed, packed the boat up quick and it had to sit for weeks afterward(besides a rinse and a flush). Hurt my back, boat sits for a few more weeks. Becomes October, need to get out at least once before the season ends, prep the fuel system for winter. Wifey up for it. Battery, boat only 2 years old(08 170 Montauk)I had charged it early in the year after winter. Never had a problem, but also never sat for weeks without use, forgot to disconnect battery while it was sitting. Sooo, get down to Gravelly Point ramp on Potomac, back off trailer(wifey on the mooring ropes). Go to start and of course not enough juice to get it to crank over enough to start. Time to have a personal meltdown. Good Samaritans, one had jumpers, the other had dual batteries. Pain the butt to work under Montauk console, as everone knows. Got it started. Embarrased? Absolutely, but a heck of a lot better than no boating at all. I am normally very [careful] about prep, but stuff like this has most likely happened to most everyone who boats a lot. Unless they are complete idiots whom could drag you down with em, I help em. |
andygere
posted 04-29-2011 04:10 PM ET (US)
quote: ...there are days we never shut the engine off it will run from the dock until we return to the dock 6-7 hours later.
Yep, me too. But I (and you) know that our motor will start again if it should stall. The jump started guy? Who knows. |
lakeman
posted 04-29-2011 05:40 PM ET (US)
What is more surprising is that he left with out a new battery. who knows how long it will take charge up or even it will take a charge. |
anthonylisske
posted 04-29-2011 05:55 PM ET (US)
I got a pull start rope with my 2003 225 vmax. I am gonna try to pullstart it tomorrow. I never thought of it before. Lol.
Binkster
posted 04-29-2011 09:11 PM ET (US)
I don`t have an on-off battery switch on my 13 footer. I carry two batterys, one to start the 25 Merc 4 stroke and one to run my electric trolling motor. When the boat is not in use I disconnect the ground wire on both batterys, in case of a voltage leak. It can sit like this for months, and will fire when started, but I always charge both batterys if they have been sitting for a month. Doesn't take long to top them off. Actually the trolling motor will push the boat about 4 miles an hour for 4-5 hours off each battery, if the outboard can`t be rope started, or ran out of gas. That would be 32 miles, but I haven't tested this out. I don`t have tow service. I would give someone a jumpstart. I would just disconnect my pos. and neg. wires from my battery before I connected the jumpers. What could happen? |
contender
posted 04-29-2011 09:20 PM ET (US)
Andy: just today, Friday, in my friend's boat with 225 Johnson [we started the engine in the morning and left it running continuously without re-start during the trip]. At the dock at 5:30 a.m., started the engine, fished, caught 10 dolphin 4 small tunas, bunch of bonita, back to the dock 12:00 p.m., shut down the engine. |
posted 04-30-2011 10:48 AM ET (US)
I always do my best to help a fellow boater in need. I have a few rules. Before towing someone a long distance to the ramp or marina I want to be sure a jump start or simple action won't work. Towing is done using my tow line which I know is not going to part. The tow line is tied to the towed vessels winch cable eye.I once came upon a sailboat under bare poles with the owner unable to start his outboard engine. He was worn out from pulling the start rope for quite a while. Being a big believer in checking the easy stuff first I asked if the ignition was turned on. He somewhat grumpily responded that of course it was. I then asked if the fuel supply valve was "on". He angrily picked up the fuel line to show me the valve. Turned out it was closed. Butch |
contender
posted 04-30-2011 11:04 AM ET (US)
Jefecinco: heard one time That anytime you tow a boat you are suppose to use Their Line, protects you from possible law suits, Do not know if it true or not, but two things why take the chance, and if someone is in a boat with out rope/good line maybe there is a reason for it... |
posted 04-30-2011 06:00 PM ET (US)
Contender,Thanks for the observation. I've also been advised to use the other fellow's line for liability reasons. But, I know my line is safe and in excellent condition. It is nylon with a good bit of stretch built in to moderate any sudden loads. This stretch factor lessens the likelihood of pulling his winch cable eye out of his hull and making it into a dangerous missile headed my way. My concern with using the other boat's tow line is that it may not be good line. As in the example above if his line parts under high load I don't want it to pop back and hurt him or his crew nor to pop forward and hurt me or mine. Bottom line is that I'll risk a little liability for safety's sake. Butch |
domlynch
posted 04-30-2011 09:22 PM ET (US)
Buckda, Re your points about not choosing an Optimax..I agree ...I've got an inherited (I shouldn't complain!) 2008 90 Optimax ...with only 35 hours....and have had some dramas with starting + have concerns (perceptions/doubts at least)in my mind re operating my boat with this motor.... I would feel more secure with a motor that: (1) Can be pull started in need, (not nice to have to do this but at least you have a chance to start), my motor does not have this, I checked under the flywheel cover Hence the need for 2 batteries - I have bought 2 new ones - mounted in the Montauk's console, which is a real pain to work in there - having issues with wiring/isolator switch in there - have to get in there and sort it out... Also, with an Opti I feel I have to charge the batteries more frequently...a bit of a headache as my boat is parked in the street - have to either put the rig inside my property (apartment) or remove + reinstall batteries....not good to disturb wiring/connections etc.. (2)Once started does not necessarily rely on a battery/ies to keep going eg. for fuel pumps or electronics.. (3) Puts out a reasonable net charge at idle (or at least does not continue to discharge batteries at idle), I plan to use my boat for some trolling at idle. Not knowing charging output at idle means I have doubts, knowing RPM vs charging output for this motor would make me feel better... (3) Does not have a compressor belt, potentially one more thing to go wrong(although belts are usually quite good if inspected & replaced if needed as part of service) (4) was lighter, so I could more comfortably use a kicker. I like the KISS principle...the simpler the better...less electronics, less moving parts etc... I really don't want to ignite a brand debate, but the Opti would not have been my choice for repower. Enough of my ramblings, we still need to keep our batteries charged ! Dom |
deepwater
posted 04-30-2011 09:54 PM ET (US)
To jump start someone or not at the ramp congers up many thoughts and feelings about weather that person is ready to go out on the water and if I start their motor am I contributing to them not coming home..I was once approached by someone with a new boat wanting to follow me out to the light houses in the De bay,,It was late and getting darkish and I asked if they had an anchor as the channels get fast later and he said NO he did not,,I asked if he had a chart of the bay,,NO he did not,, do you have a compass,,NOPE,,I told him ,,YOUR not following me any where,,Go get a chart a compass and an anchor first and take a safe boaters course,,this was a guy with a $25K boat and 3 friends at night in the Delaware bay and no idea he was in danger |
domlynch
posted 04-30-2011 10:47 PM ET (US)
I think I'll bring another (3rd!) battery (easily charged externally, & not connected), to use with jumper leads if needed. This will give me more confidence with the Optimax! I am sure once she is running she will be ok...Interesting points about the liability implications of helping others, I have in the past helped jump start others + towed others (+ been towed once following a capsize in a aluminium dinghy (it was righted but motor would not start.) What goes around comes around.... Dom |
domlynch
posted 04-30-2011 10:50 PM ET (US)
Deepwater - I couldn't agree more. |
jtms
posted 05-02-2011 10:42 AM ET (US)
What is everyone's feeling about tow service memberships? I have towed people numerous times, and I am at the point that I do not tow people any more unless their is an emergency or kids are on board. A tow service membership in my opinion is the equivalent to having life vests - just have to do it. It irritates me that people spend all the money that they do no boats and don't spend $150 a year for a tow service. Am I being too harsh? |
posted 05-02-2011 07:21 PM ET (US)
jtms,Remember there are waters where tow coverage is sparse and others where response times are quite long. Full coverage and quick response times seem to be widely available where a lot of boats operate. Of course, these are areas where a free tow is also most readily available from a passing boater. I have never seen a commercial tow service's tow vessel in the waters in which I spend most of my boating and fishing time. In these waters folks seem very ready to lend assistance such as a tow, a jump start, or even a cold beverage or first aid. We've been known to share bait and even part of our catches, too. The attitudes seem to reflect those seen in small towns versus big cities. In small towns neighbors seem much more willing to help their neighbors. Butch |
jtms
posted 05-03-2011 09:57 AM ET (US)
Interesting and thanks for clarification. Where I live it is rare to have a day where you don't see Sea Tow or one of the other companies cruising around. I live on the water close to the harbor and a couple of my friends joke that they don't pay for the tow service because they have me. Kind of rubs me the wrong way but maybe one day I will be busy when they call for a tow :). |
Sebash4
posted 05-03-2011 10:21 AM ET (US)
I recently used a pull rope on an older 115 Johnson and the only way I could pull it was to remove one of the spark plugs, switch on the ignition and pull it a couple of times. By removing the plug it lowered the compression on the engine allowing it to start on 3 cylinders. It made a heck of a lot of noise when it fired up but after letting it run for a couple of minutes it built the battery up to the point it would crank when I replaced the plug. Probably not the best way to start an engine but at the time it was the only way. |
Tom W Clark
posted 05-03-2011 10:59 AM ET (US)
Remember, when emergency rope starting an outboard, you are not starting a lawn mower; you need only pull through ONE COMPRESSION STROKE, that is all.The normal procedure is to rotate the flywheel by hand until resistance is felt from one cylinder's compression. You then wrap the cord around the flywheel perhaps only 180-270 degrees. You pull the flywheel through that one cylinder's compression stroke using bot arms. It should be easy for any adult to do. If it is not possible for you to pull the motor through that one compression stroke, it is best to try it now and find out so you know not to bother trying it on open water. If, on the other hand, you can successfully start your motor with the emergency starter cord at the dock or in the driveway while practicing the technique, you will have given yourself another skill that may come in handy someday and get you, or somebody else, out of a tight spot. |
WhalerAce
posted 05-03-2011 12:38 PM ET (US)
If my lawn mower does not start on the first pull, I clean the carburetor or look into why it DIDN'T start on the first pull -- there is no reason it shouldn't.My outboards, on the other hand, only start on one pull IF they have been used already that day and are still warm. I do realize that if I could use them every day, they would start quicker, but I also follow the routine of starting them up a home before heading to the ramp. --- WhalerAce |
posted 05-03-2011 08:40 PM ET (US)
This winter I was aboard a Whale-watching boat down in Mexico. It had twin Yamaha outboards. I think they were V4's and were the ENDURO models with pull starting. During the four-hour trip and while maneuvering to see a Humpback Whale, one of the engines stalled. One of the crew reached over and gave the pull-cord a yank, and the Yamaha engine came right back running. I think the guys running the boat like to keep things simple, and being able to pull-start is a nice way to avoid trouble if you have problems with the cranking battery. |
contender
posted 05-04-2011 04:20 PM ET (US)
These are the things that make me mad about trade, We should be able to get those same Yamaha's in the US, there are so many items out there that should be allowed in the states and they are not...go figure |
