ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: The Whaler GAM or General Area Hull ID Number
Author | Topic: Hull ID Number |
Treypescatorie |
posted 08-05-2011 03:00 PM ET (US)
I need help with my HID number, it was sanded off during refinishing. On the reggy there are a few #s DN757599 REE BYS061 10001123 Boat is a 1968 sport Thanks Paul |
Jeff |
posted 08-05-2011 03:11 PM ET (US)
DN757599 does not correspond to any Boston Whaler Stencil #. If you put in REE into the Manufactures Indentification Database it comes back with: R.E.M. BOATS INC http://www.uscgboating.org/recalls/mic1.aspx?mic=REE&sort=mic Here is a FAQ on HIN and Stencil #'s as related to Boston Whaler Boats: |
leadsled |
posted 08-05-2011 03:12 PM ET (US)
The hull # is molded into the gelcoat. Unless you sanded all the way through the gelcoat I think it should be there. It should be 6 or 8 inches below the transom under the engine on the inside of the hull. Look at some photo's of other early 13' to get an exact location. |
Jefecinco |
posted 08-05-2011 05:51 PM ET (US)
Lead, My 81 13 Sport HIN is embossed on an aluminum plate riveted to the outside of the transom on the starboard side a couple of inches below the inner/outer hull joint. Butch |
