Topic: Running gas out of engines
Mike Kub |
posted 08-28-2011 07:38 PM ET (US)
I have 2stroke premix engines and was brought up to"run the gas out of 'em after each use". I do this. Is this the general consenses of you guys? Peace.
Peter
posted 08-28-2011 08:08 PM ET (US)
I used to do that with my 1977 Evinrude 35. Never had a carburater problem with it. |
posted 08-28-2011 08:44 PM ET (US)
There is no need to drain gasoline from the fuel system of a two-cycle engine with carburetors after each use. I had a V6 engine with six carburetors. I never drained the fuel from it after each use. It always started on the next use without the slightest problem. I went out of my way to insure that the carburetors had a full bowl of fuel when the engine was not being used. |
deepwater
posted 08-28-2011 09:00 PM ET (US)
The old school way was to run it dry,,I think the gas today it more stable and the gaskets are better |
dfmcintyre
posted 08-28-2011 09:04 PM ET (US)
Although.... with the mixing of ethanol in much our current gas, it may make sense. Especially with older, non ethanol approved engines>Thoughts? Don |
sosmerc
posted 08-28-2011 11:28 PM ET (US)
It is not necessary, and indeed may actually cause some problems if the engine sits for a long period. First of all, when you think you are running the gas out of the engine by running it until it stops.....there is still a certain small amount of gas left in the carbs. This remaining gas will eventually evaporate and often this leaves a scum or sugar-like residue. The carb's main jet is at the bottom of the carb and thus the residue can plug the jet. In most carbs the idle pickup tube also extends to the bottom of the carb and thus it too can get gummed up. The best thing you can do is be sure to run well conditioned fuel at all times and hopefully this fuel will not deteriorate during periods of non-use. |
Peter
posted 08-29-2011 07:21 AM ET (US)
V6 outboard motors were and are not equipped with quick disconnect fuel fittings so running fuel out was not easy to do. Back in the 1970s we all did this on our mooring kept saltwater boats. |
posted 08-29-2011 09:09 AM ET (US)
In some older two-cycle outboard engines, fuel will drain from the carburetors when the engine is tilted up due to the design of the carburetors. In smaller engines that are removed from the transom when not in use, fuel is also likely to drain out of the carburetors when the engine is stored. In engines of that type, it may be beneficial to let most of the fuel run out of the carburetor before tilting up the engine or removing the engine from the transom just to avoid having it drain out later. |
Binkster
posted 08-29-2011 12:54 PM ET (US)
How could it possibly be harmful to run an outboard,(any) out of fuel. I would assume that at the end of the manufacturing line, before an outboard is shipped, it is test run at the factory, at least I hope so. How then do they remove the gas that is left in the carbs or fuel injection system? Do they run them out of gas which would be simple, or do they have some way of manually removing the fuel. They also drain the crankcase on 4 strokes. The new engines could then be stored for months or years. |
Tohsgib
posted 08-29-2011 01:16 PM ET (US)
I still agree that the dry start is more harmfull than running them dry at idle. |
adlert
posted 08-29-2011 01:18 PM ET (US)
Running a conventional (non-direct oil injected) 2-stroke outboard out of fuel leaves all of the working parts dry, or very nearly so. Insufficient fuel in the engine equates to insufficient oil since the two travel together in these types of engines. Leaving bearings, journals, cylinder walls, etc. with no protection is a very bad idea and an unecessay risk. Not to mention the needless wear (albeit slight) during the last couple dozen rotations the engine goes through "dry" at the very end of the draining excercise.As sosmerc also pointed out, the running-dry procedure most often doesn't actually run all of the fuel out from the carburetor so that gumming of the lower positioned orifices and passageways often will still occur (sometimes it even encourages this problem). What does happen is the level in the float bowl simply becomes too low to be pulled up by the idle circuit with sufficient volume to maintain the necessary mixture to run - the mixture becomes way too lean to run the engine. Also way too lean to leave a good protective coating of oil on the internal parts. Fuel systems can be drained prior to intial engine shipment fairly easily. Engines can also be fogged. I don't know what each (or any particular) manufacturer does, but I imagine something proper is done to ensure protection of the internal parts. |
Jeff
posted 08-29-2011 01:22 PM ET (US)
Run an outboard dry after reach use? I have never done this on any of my 2 stroke carbureted outboards in my entire life. They seem to drain out as soon as I tilt the motor all the way up for transport anyway. |
pcrussell50
posted 08-29-2011 06:17 PM ET (US)
Tim, good to see you again on here, fellow crossflow buddy. -Peter |
adlert
posted 08-30-2011 09:19 AM ET (US)
Thanks Peter, still here. Ran the snot out of the old 90 this weekend yanking up large slalom skiers with a boat load of spectators to boot. Always amazed at the grunt these engines provide. Flawlessly, over and over again. Really have to be easy on the throttle with the average sized skiers or you'll rip the rope right out of their hands.And no, I did not pull the gas line to run the engine dry at the end of the day. In fact, I race the engine just slightly and push the key in to prime and flood the engine to a stop at the end of the day. I want the internals as wet as possible while they sleep. No worries with fouling plugs - the ignition systems on these old machines are extremely capable. Approaching 50,000 volts if needed. |
sosmerc
posted 08-30-2011 11:11 AM ET (US)
"I race the engine just slightly and push the key in to prime and flood the engine to a stop at the end of the day. I want the internals as wet as possible while they sleep."That is a very good idea. It also works well on small engines and even aids in starting the next time since there is already a little fuel left in the cylinders. |
BQUICK
posted 08-30-2011 02:15 PM ET (US)
Some ramblings.... Most motors really won't run all the fuel out since when the quick disconnect is removed it closes it off to air, the fuel cannot flow thru the lines so when you think it ran allthe fuel out of the carbs/lines it didn't actually.Saying that running a 2 stroke (premix) till it stops isn't harmfull is like saying so and so lived to 90 and smoked so it can't be that bad. When owners manuals say to run out of fuel they are thinking it's end of season and you are going to fog out as it's running out of fuel. Sure people do it and get by but there has to be some extra wear in addition to leaving the motor prone to rusting internally from condensation. Also, some people don't keep their motors long enough to see the effects. Back in the 70s I knew a guy that tilted his 33 Johnson up after each use WITH IT RUNNING so he could run it out of gas AND "dry out" the cooling passages!!! I asked him how long his water pumps last and he said he had the original one still after 3 years of that nonsense on his original pump. Then he sold it..... |
L H G
posted 08-30-2011 04:42 PM ET (US)
The Owner's Manual that came with my 1985 Merc "Towers" says to unplug the pre-mix fuel line and IDLE the engine out of fuel when it is anticipated that a period of non-use is ahead. That's what it says! And it is what I have done for 26 years now. 3000 hours and still going strong! I believe running an engine out of fuel affects carbs only, not lubrication of the powerhead.It says to not do this will leave varnish and jet clogging as the fuel eventually evaporated from the carb bowls. They also say to do it if you are planning to tilt the engine up to avoid spills. None of this is related to storage fogging. For oil injected engines, they say NOT to run out the fuel, as you will load up the carbs with oil. That is why most of those engines have permanent fuel lines, with no disconnects at the engine. Maybe other brands, and more recent engines, have different recommendations. |
dowdhh
posted 08-30-2011 07:44 PM ET (US)
Interesting topic.I've never owned anything but 2 strokes and I always flush with muffs on the garden hose, pull the gas line and let them stall. Why? Because thats what my grandfather did 35 years ago. The argument not to, makes allot of sense. Sorry Gramps. But I will stick with his trusted Johnson/Evinrude's. |
Tohsgib
posted 08-30-2011 08:05 PM ET (US)
I'm with LHG. |
adlert
posted 08-31-2011 12:12 PM ET (US)
Of course you can do whatever you want to regarding this issue. Many, such as LHG have run their engines "dry" always and have not seen any ill effects. He's certainly not the only testimonial I've heard regarding this topic over my last several decades of wrenching I think it fair to say though if the engine is allowed to stall due to insufficient fuel delivery, it is not just a carburetor thing as suggested, it's definitely a whole package thing. The oil is in the fuel after all. The engine stops running because sufficient fuel/oil isn't making it through the crankcase and around to the combustion chamber.Also, I remember pointing out that old Mercury run-dry recommendation once way back when to our roving factory service representative. I recall him saying then that that recommendation was being dropped or going to be dropped. I'd be interested to hear if any of you Mercury classic 2 stroke owners with slightly later model years still have this recommendation in your owners' manuals. I have a gut feeling as the 80's wore on to the early 90's we might see this recommendation disappearing. Maybe sosmerc has better first-hand knowledge of this. Personally, even the thought of a classic 2-stroke engine spinning to a stop due to insufficient fuel/air ration makes me cringe! I do my best to switch fuel tanks before running dry too. HATE it when I forget and it happens at higher rpms... |
L H G
posted 08-31-2011 02:01 PM ET (US)
I have alwasys thought that by the time the pre-mix gets to the spark plug, it has already gone past all of the other components, and done it's lubricating job. |
Tohsgib
posted 08-31-2011 02:10 PM ET (US)
I am again with LHG. Just because it did not have "enough" gas to fire does not mean it did not already lubricate the internals. |
adlert
posted 08-31-2011 09:21 PM ET (US)
Larry you are absolutely correct. From the carbs, past the reeds, misting over all the spinning internals, and then around and up to the upper end (combustion chamber). If lubricant is being supplied in the normal quantity used to run the engine it is in the normal quantity desired to lubricate the internals under the pistons. The opposite is also true: if present in the normal quantity in the crankcase lubricating the "internals" it will then - without choice - be pushed around in sufficient quantity to fire the engine as long as it is spinning. If the engine is not firing due to insufficient fuel in the combustion chamber, you have run out of the "normal" amount of fuel and lubricant in the crankcase side of the engine.Once there is insufficient fuel in the combustion chamber to run, the engine obviously stops running and starts its coasting phase to its ultimate stopping point. With each rotation while coasting with little to no new fuel/oil, a fresh, essentially gas-free and lubricant-free volume of air is still pulled into the crankcase, swirled around the bearing surfaces and then pushed up to the top of the cylinder (combustion chamber). This lubricant-free air movement will without doubt remove at least some of the lubrication from those bearing surfaces and cylinder walls that was present when you were supplying the fuel and oil at the operating volume. Whatever. You will do as you please and 3,000 hours on Larry's Mercs is certainly excellent performance by any reasonable standard! When those old beauties eventually wear out after 6,000 hours of run time you'll just have to wonder how long they really could have lasted if you'd not run them dry each time you put them to bed. ;) |
home Aside
posted 08-31-2011 09:36 PM ET (US)
With my Old 1982 Evinrude 90 on my Montauk when the boat was not going to be used for a period of time I religiously disconnected the gas line & let the engine idle till it ran out of gas. If I'm not mistaken it said to in the engines manual.On my 1985 Yamaha 225 on my Revenge, I've never done it, don't ask me why.....but almost every time I go back to the boat, which genberally is storred with the motor up, I'm constantly cleaning up the residual gas/oil that's dripped out of the carbs, and run down into the splash well.....I think the Yamaha is trying to tell me something. Pat |
adlert
posted 08-31-2011 09:47 PM ET (US)
As a slight aside Larry, I'd bet that the owners manual recommendation to run your towers dry when done may actually have roots based on the engine air intake design and customer satisfaction. For whatever reason, Mercury chose to not equip those engines (and most of their other older ones as well) with air intake silencers that actually attached directly to the carburetor fronts. Instead they chose to simply provide sound absorbing material in front of but some distance from the carb throats. I've always thought it an odd approach given OMC was so was diligent about designing a much more closed system during that era for most of their line. Possibly Merc was more concerned with minimizing chances of air intake restrictions. Maybe they were also going for a signature (and louder) sound. Who knows.Regardless, not physically attaching an intake silencer (with drain line return to the crankcase) means guaranteed fuel spillage onto the engine pan when the fully loaded carbs leak as the motor is tilted at the end of the day. Not disconnecting the fuel line therefore guarantees an oily mess for an owner with this intake design. Of course we all know that old OMCs can be messy too when tilted. But if their (OMC) air intake gaskets are kept in good shape, and the silencer-to-crankcase drain line is too, the leakage is usually minimal to non-existant even if you don't run the carbs dry. |
Binkster
posted 08-31-2011 10:57 PM ET (US)
Larry's argument makes sense, Tohsgib agrees with him, so do I as I have been doing this for almost 60 years with no adverse effects. Some posters that say Larry is wrong but only come up with their "theories" offer no positive proof he is wrong. Where is their proof that someone ruined their outboard by running it dry. Also how many times can you do this before your engine is toast? Ten, one hundred, five thousand. Its all conjecture, means nothing. Chalk it up to heresay like your battery will run down quickly if you store it in concrete. |
Binkster
posted 08-31-2011 11:45 PM ET (US)
if you store it in concreteStore it ON concrete. |
macfam
posted 09-01-2011 07:35 AM ET (US)
We have the 2hp Honda 4-stroke for our inflatable. It's only 30 pounds, so it is very easy to deal with.After every use (end of day), I shut off the fuel, and let it run completely out. Firmly close the vent cap on the internal tank and store. It is frequently transported on it's side (per manual) and when it is set on the transon, fuel open, vent open and choked, it starts on first or second pull. For winter storage, the manual suggests to open the fuel drain screw, and completely drain fuel from the internal tank. I did it the first year, but have not done it in recent years. With treated fuel, there has been no problem. The main reason I run it out of fuel after each use is that I want 0 fuel dripping anywhere/anytime. It works great. In additon, I have a dedicated 1 gallon plastic tank with the new EPA valve that seals off upon release. These portable tanks are good for filling the Honda tank with no spillage, even when bobbing up and down in the water. We can carry that portable tank in the inflatable and spend hours on the inflatable. I think a gallon of gasoline will run that 2hp Honda around the world at the equator about six times. :>) The 30 E-TEC on our 13' has a "closed" fuel system that I have never disengaged for 2+ years. There is never any gas smell or drippage, even when tilted up after use. No need to run fuel out on this motor. Just use fresh, treated fuel and it's always good to go. |
pcrussell50
posted 09-01-2011 02:13 PM ET (US)
Tim and sosmerc's rationale for NOT running an engine dry makes eminent sense (to me). Everybody else's argument FOR running dry has been some variation of, "well, that's what my grampa did, my dad did it too, and I've been doing it too for the last 60 years, and I've never had a problem". I went into this thread with a mind towards running dry. So far, I have changed my mind. But then again, being only three years into boating, I have no sacred cows or long held beliefs that I am unwilling to re-evaluate. -Peter |
Tohsgib
posted 09-01-2011 02:42 PM ET (US)
Honestly...I have never run an engine with more than 1 carb out of fuel on a regualr basis. I can see the problem with a 225 with 6 carbs. 2 are dry and 4 are still making the engine run so 2 cyls are starting to heat up, etc. I think the notion was when we had 32 or 50:1 twin cyl outboards with one carb it was no big deal. Now some probably do it with a V4 with 2 carbs but I don't think I would be doing it with 6 carbs. Again my 3cyl EFI I run til it "starts" to sputter because I don't want fuel to sit and mess up my $500 fuel pump but I also do not want to run the injectors dry. Being a 4 stroke running them dry can't hurt but this is about premix 2 strokes. |
BQUICK
posted 09-01-2011 02:58 PM ET (US)
Throwing a wrench into the argument.....during the boating season if you attempt to run the fuel out each time, I doubt that the bowls will be empty so the gas that remains evaporates faster and then leaves deposits behind as well as drying out gaskets. If I leave the bowls full the carbs won't dry out completely which based on the crap I'm finding left over in carbs these days that have dried out, I'd say during the season don't run out of gas. |
dowdhh
posted 09-01-2011 07:39 PM ET (US)
Pcrussell50, I brought up my "grandpa" as a reason why I ran ( past tense) my motor out of fuel. If you read my post carefully you will see I'm in agreement with the school of thought not to. I will continue to run out the fuel for long term down time, but not if I'm going out again the next day. You put me on the wrong side of the issue. I am also willing to re evaluate. |
posted 09-01-2011 08:21 PM ET (US)
There is a conflict here. When preparing the boat for non-use, the same folks say to run the carburetors dry but keep the fuel tank full. |
Tohsgib
posted 09-01-2011 09:06 PM ET (US)
Hello...carb gaskets are now O-Rings, not cork. |
pcrussell50
posted 09-01-2011 09:59 PM ET (US)
dowdhh, I wasn't picking you out specifically. I was intending to paint a "composite" word picture, a generalization if you will. I was most assuredly not singling you out. -Peter |
Tohsgib
posted 09-02-2011 11:55 AM ET (US)
Quick question to ponder...In order to shut off a diesel engine you either need to stop the fuel flow(turn off pump to injectors) or make a break in the vacuum system(emergency method). So in order for a common diesel to be turned off which happens EVERY time you run it, you starve it of fuel. No biggie but what about 2 stroke diesels that are in thousands of boats, etc? I don't think they suffer from scoring, lack of lube on crank, etc EVERY time they are shut down. |
adlert
posted 09-02-2011 01:13 PM ET (US)
A valid point Nick. It's an unavoidable situation with the diesel 2-stroke. Still: it doesn't necessarily make it a preferable situation; diesel engines stop rotatng quicker due to their higher compression; and diesel fuel (actually "fuel oil") is a decent lubricant in and of itself so traces of it left behind during the process also help out. Not so much with the traces of gasoline being left behind when we run our 2-stroke outboards dry. To run dry or not to run dry is a simple matter of choice that in the end, may or may not have easily quantifiable consequences for any given operator. If carb leakage when tilted is a significant problem and annoyance for a given user, then running dry might have value to them. For me, since there is absolutely nothing to be gained by the running-dry practice (no leakage problems), the choice is obvious. Leaving more oil (and fuel) coating the lower and upper end of the engine CAN'T possibly do harm to the engine between runs. Certainly it can't be more detrimental (or less helpful ?) than running it as low on lubricant as possible. Without a doubt, running an engine out of gas can actually accelerate carb gumming problems. Years in the outboard repair industry have taught me this. Specific to your EFI Suzuki Nick... I would never run that engine low on fuel. Not because the internals will suffer - you obviously know that is not the case since it is a 4-stroke with an independent oil supply - but because you never want to allow your electric fuel pump to run in anything but a solidly fuel environment. Sounds like your technique bumps up against that. You also want to keep the fuel rail air free of course. Certainly no good reason not too. Your fuel pump relies on the fuel for its mechanical health. Gas isn't a great lubricant, but it still can function as one quite well in properly designed devices carrying minimal loads and with a constant (relatively cool) fuel supply. That is the relationship fuel has with your EFI fuel pump. Leaving your pump surrounded with nothing but fuel and no air is the way to go and the way it was designed to operate. I would be extremely surprised (and humbled) if your Suzuki manual recommended the practice you are following of nearly running that engine dry (sputtering). Keep the air out of an EFI system and gumming will essentially never occur. That is probably the primary reason FI systems are so wonderfully reliable and stable even after extended lay-ups with no treatment. Except for vapor separation devices, they are essentially air-free from the pump to the injectors. A darned good thing and a darned good thing to maintain. |
Binkster
posted 09-02-2011 01:35 PM ET (US)
Seems like I'm beating a dead horse with some posters, but here is another thing. As member of AOMCI I like to mess with old outboards mostly semi modern ones from the 60;s and 70's. Many of these motors have been stored for 25-30years. If you find one that was stored dry, (run out of gas), fogging was not around then, generally they are easy to restart. Sometimes squirting some fuel mix in the cylinders, removing the plugs and turning the over several times to distribute the fuel mix, fresh plugs, and they will start right up. If you find one that was put away with fuel in the carb(s), generally the engine is stuck,there is varnish everywhere, and the carb(s) will have to be rebuilt. Peter seems to base his opinions on others assumptions, not from others experience. As far as the oldtimers opinions my dad never ran his outboards dry, and bought new ones ever 3-4 years. Engines were stored during the winter, hard to start in the spring. |
Tohsgib
posted 09-02-2011 01:58 PM ET (US)
Adlert I agree but I disagree in that I have seen MANY an EFI fuel pump go bad from stale gas. These pumps cost $500 or so. I don't run my 13 but every few months and after 3 years it has worked so far. I mainly don't even wait for it to sputter but I let it run for a long while. These 4 strokes take like 15 minutes to run dry...time most don't want to waste every outing. |
pcrussell50
posted 09-02-2011 02:12 PM ET (US)
Binks, my assumption going into this thread was to run my motors dry. In fact, I did that last week. Interesting experiences you relay about winterizing, but what are you doing winterizing motors in Florida? Tim is already implying that there are pro's and cons to both methods. My take now is that, especially amongst the Whalers owners on this forum, most boaters do not keep a motor anywhere NEARLY as long as the motor is capable of running. Therefore, the slow accelerated wear you would get from running it dry may never affect the typical Whaler owner, who will have long since replaced his old motor. Tim ribbed Larry to that effect, where he jabbed that Larrys old towers might only last 3000 hours instead of 6000 because he runs them dry. There may be a whole lot more truth to that jab than we give credit for. I'm the type to keep a motor for the long haul... as long as it is the type of motor that can be fixed by the average mechanic, with average tools. -Peter |
gnr
posted 09-02-2011 03:23 PM ET (US)
I've done both with all my stuff. I used to run my engines out of fuel for storage. Then I read of many people who did not with good results so I gave that a try.My experience with 20ish years of running motors out of fuel and 7ish years of leaving the carb bowls filled with treated fuel is that I have far less problems getting stuff running after extended storage when I do not run the fuel system dry. Two stoke or four everything starts right up in the spring/winter. This is especially evident on the garden tiller which is used twice a year. I can rebuild that carb in five minutes with my eyes closed because I've done it so many times. It was actually seeing the residue left in the bowl and on the jets in the tiller that really caused me to change my methods. Add some seafoam to your fuel and run it through the carbs and you are good to go. I would think if running a two stoke out of fuel would damage the motor this would manifest itself to a great degree in air cooled high rpm applications like chainsaws and weed whackers which are commonly run out of fuel. Both of these are typically at WOT when they run out of fuel. |
pcrussell50
posted 09-02-2011 03:50 PM ET (US)
Just a small nit, gnr, regarding running chainsaws and such out of fuel... they are (usually) single-cylinder motors that cannot suffer from one cylinder run out of fuel first, while the other one continues running, dragging along the one that ran out first. -Peter |
adlert
posted 09-02-2011 04:25 PM ET (US)
Actually Peter I was meaning to joke with Larry that we'd be wondering how long his engines would last after being retired at the 6,000 hour mark if he hadn't been running dry. The way Larry cares for his equipment... who knows? I love hearing of these neat old engines running up so many hours as his have. One of the points I was trying to make was that there is little hard evidence that running dry is doing anyone any terrible diservice. It's just that given the choice, why store with less lubricant on the internals? Ease of starting after a season of storage is another matter entirely. Proper fuel treatment will handily take care of that.That's interesting Nick regarding your experience with stale gas causing electric fuel pumps to go bad. I've been working as a mechanic off and on now for decades and I don't think I've ever come across a bad electric fuel pump that anyone (me, other mechanics, or any service reps) could or have attributed to stale gas. I've certainly replaced loads of bad electric pumps. Soooooo many iterations of them for Mercruiser engines! Essentially all internal electrical failures with the motors (which have remained properly sealed from the pump). Many failures do to overheating (lack of fuel). I suppose stale gas is a possible cause but without air in the system it would take an extremely long time for the gas to deteriorate to the point of varnishing or getting gummy enough to bind a pump or its associated valves and/or passageways. How do you boaters in FL wind up with stale gas anyway? Winter never holds you guys back :) |
Binkster
posted 09-02-2011 11:22 PM ET (US)
Adlert omments; How do you boaters in FL wind up with stale gas anyway? Winter never holds you guys back :) Here is how the climate works in Central Florida. From December thru Feb. it is damn cold, anywhere between 20 to 50 degrees, on these days only snowbirds take their boats out. In March the wind blows constantly about 25+ mph everyday, but the temperature is about 70 degrees. Only snowbirds and tourists take their boats out, some never return, remember the pro football players that drowned, 3/01/10. April and May the boating weather is pretty good around here. June thru Sept. the weather is pretty hot, about 95 degrees out on the gulf and nary a breeze to cool you off. And every afternoon the thunderstorms move in about 3pm. Don't want to around them for sure. Only the tourists take their boats out and bake in the sun all day and then the thunderstorms hit, and some never return. The fish are non existent in the hot weather. Oct. and November are the best months, and the fish wake up. So we have 4 months of decent boating. No wonder my '08 Merc has only 40 hours. I think that Snowbirds and tourists don't have much sense. (Or else they would live here full time like us locals.) Now South and Southwest Florida its a different story. (Paradise) Never figured out why the tourists and snowbirds don`t keep driving until they reach Ft. Lauderdale/Miami or Ft. Myers/Naples.
adlert
posted 09-04-2011 12:46 PM ET (US)
Hey Binkster, Lived on the panhandle for 6 great years. Boated constantly though I wouldn't have considered myself a snowbird or tourist by any means. Yes, sometimes it was cold. Sometimes it was hot. Guess I don't have much sense - I boat year around here in TN too. |
