ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: The Whaler GAM or General Area Montauk 17 Trailer
Author | Topic: Montauk 17 Trailer |
OPH |
posted 11-11-2011 12:03 PM ET (US)
I am looking at Montauk 17 that sits on a five-year-old [galvanized-steel] trailer. The boat is in good shape, but the trailer's brackets, hubs and axle are really rusted for their age. I am not a subject matter expert, so hoping for any insight and thoughts on: --generally and typically how roadworthy are these trailers after five years when showing a lot of rust like this? I am wishing now that I had spent more time really looking at the trailer. Generally I did not see any holes but rust appears to be pretty deep and way more than light surface rust. I want to pull this 150-miles each way a few times [each] year and was hoping to get a few years out of it. --if I wanted to replace [this rusted trailer] with essentially the same stock trailer, what would be a good price target? And does anyone have any recommendations on where to price or buy one? I am in North Carolina. I may consider upgrading to aluminum, but for purposes, here, really looking at how much it would be to replace the galvanized-steel Boston Whaler trailer with a new version of the same. I may want to consider factoring that into pricing discussions with seller. Thanks for any thoughts!--OPH |
jschmidt63 |
posted 11-11-2011 01:23 PM ET (US)
OPH--If the trailer components are showing rust you never know when one may fail. I purchased a [KATAMA] in 2006 from Smithfield, Virginia, with a [unclear] trailer of unknown age. On the way home--190 miles--one of the rusted bunk brackets broke. I then spent the past several years upgrading parts and new bearing buddies. I finally said "forget it" when I noticed that many bolts were rusted and frozen. I bought a E-Z-LOADER EZL 90 rated for 2,100-lbs this year form Ace Marine of Stuarts Draft, Virgina--a little more then I required but I wanted a solid trailer. Cost without guides was about $1,800. Since I trailer a minimum of one-hour one-way, the piece of mind from the new trailer is well worth [the $1,800 cost]. I believe the supplier for this shop is from eastern Virginia. Best of luck on your decision.--John |
L H G |
posted 11-11-2011 03:42 PM ET (US)
In my (not very) humble opinion, this is the best trailer you can buy for a Montauk, anywhere. It is a Continental galvanized steel tilt-frame keel-roller, model CV-7. Cost, with the Stoltz keel rollers and ss shafts, was less than $1400.
Since you are in North Carolina, you can run down to Jacksonville and pick up one of these. They are only sold in Florida. The frame is all welded channel steel, eliminating bolted connections which will always flex, squeak and rust. Lauching and retrieval are extremely easy with this trailer. These trailers come with hot-dipped galvanized bolts, but when they start to show rust, I always replace with stainless steel bolts. I have a similar 22-year-old Continental trailer under my 25 Outrage, extensively used in salt each winter, and with no rust. |
OPH |
posted 11-11-2011 03:57 PM ET (US)
L H G- Thanks on the trailer advice. I checked out the pics, that is a sweet (sweet, sweet, SWEEET) Montauk 79. WOW, you did an amazing job with that.Gotta love your tow vehicle there too.... ;-)--OPH |
L H G |
posted 11-12-2011 02:23 AM ET (US)
Thank you very much, OPH! Best of luck to you in finding a nice Montauk. |
barnacle |
posted 11-14-2011 05:22 PM ET (US)
I know we are not talking about a 17 [and wants to change TOPIC to talk about trailers for much larger Boston Whaler boats with Whaler Drives. Please start a new thread for that topic.--jimh] |
ocean31 |
posted 11-17-2011 09:00 AM ET (US)
LHG: Do you have any more specfic information on dealer for the trailer from Jacksonville? I am over in the Panhandle, Jacksonville is about a 5 hour drive for me, but I need a new trailer for my 13, and my Katama could use a better trailer. Thanks jsb |
Tohsgib |
posted 11-17-2011 11:07 AM ET (US)
Do NOT buy a Continental trailer. They were great 22 years ago, they are abxsolute junk now. My buds 2001 is going to the scrap yard next week. Buy aluminum or go home....they can't rust. |
Tohsgib |
posted 11-17-2011 12:40 PM ET (US)
PS...that does not include their aluminum trailers. |
OPH |
posted 11-18-2011 10:47 AM ET (US)
Just FYI for anyone evaluating trailer options, below is paste 'Choosing the Right Trailer For Your BW' directly from BW web site: Depending on the size of your boat and the conditions in which you launch and retrieve, there are two styles of trailers: |
Tohsgib |
posted 11-18-2011 01:53 PM ET (US)
You can tell how long ago that was written..."Locating the stop in this manner allows straight pull and provides security in a panic stop, preventing the boat from riding up and over the trunk of the car." Ther are not many cars today that can tow the smallest of Whalers. OPH...have the trailer fixed, 5 years old is not old. |
Phil T |
posted 11-18-2011 03:27 PM ET (US)
My 2003 Loadrite galvanized trailer shows rust on the U bolts and the Shurlube (like bearing buddies) fittings. I trailer to the ocean. Rust on fasteners is no big deal for a trailer that young. I would replace the tires if original and enjoy the boat. If you don't feel safe, replace the bunk, keel roller brackets and U bolts and nuts. ~ $200 in hardware is alot less that $2-3k for a new trailer. |
contender |
posted 11-18-2011 04:20 PM ET (US)
Tohsgib, Phil are correct: 5 year old trailer is nothing, get it fixed, even if you replace everything it still would be a lot cheaper than purchasing a new trailer (unless the frame is bad, bent). I also use a galvanize turnbuckle on the bow eye that is attached to the trailer at a perpendicular angle, keeps the boat tight to the bow roller and does not let it bounce. |
L H G |
posted 11-21-2011 08:29 AM ET (US)
Well, since Nick has all the answers, I guess there's no need to contribute further to this one. Take a look at my boats and decide if I know anything about Whalers and trailers needed to tow them around. |
Tohsgib |
posted 11-21-2011 02:11 PM ET (US)
Larry for the 10th time over the last many years....your trailers are older than me. That is when Continental made a good/great galv trailer. Today I think they are junk, their aluminum however are nice but I would buy Loadmaster instead. My friend is a Conti dealer, I think I know what I am talking about. He only buys the $600 small ones for his little skiffs he makes/sells. For that price they are nice. |
barnacle |
posted 11-23-2011 10:21 PM ET (US)
Thanks for the aluminum advice. [Changed TOPIC to talk about larger trailers for Boston Whaler boats with Whaler Drives. Please start a new thread for that topic.--jimh] |
Tohsgib |
posted 11-24-2011 09:30 PM ET (US)
When I had my Loadmaster done for my Montauk in 2003 I had them cut the bunks to the right angle and also make them 4" shorter so the boat sat lower and custom decals with a Whaler harpoon done instead if theirs. Call Loadmaster in Brandon. FL. |
pete r |
posted 11-25-2011 04:44 AM ET (US)
You guys have got so good with new trailers. Your aluminium trailers are great value. When you have a foam core boat you should dunk your trailer and float the your off. Fresh waters are not an issue, however if you dealing with salt water, then even an immediate hose down will not guarantee you have removed the corrosive salt from concealed welded sections of the main trailer frame. All can look good externally but there may be no more than a match stick thickness of steel supporting your pride and joy. With an aluminium trailer, corrosion of the main frame structure is eliminated. The only worry lies with the bogie. Not all bad because these parts are common with road trailers so they are less costly to replace. |
barnacle |
posted 11-25-2011 11:36 PM ET (US)
[Again wants to change the topic to talk about trailers for larger Boston Whaler boats with Whaler Drives. Please start a new thread for that topic--jimh] |
