Topic: Dispute With Yamaha Over Warranty Coverage of Wear Parts
RENTER |
posted 06-07-2012 05:48 PM ET (US)
[The author wants to tell us about what he says is an] interesting experience with a Yamaha water pump. I had purchased a Yamaha 50-HP two-cycle outboard engine two years ago for my wife's Sport 15 to replace a 32-year-old Johnson. Because we own three boats, usage on this Whaler is very minor. I brought it out last month to wash and check out for some boating. The heat alarm sounded as I was [operating the Yamaha 50-HP two-cycle outboard engine] on the muffs [or hose adaptor]. Shut down and took [the Yamaha 50-HP two-cycle outboard] to the local Yamaha dealer, where I bought the motor. The total time on engine was 6.1-hours. The dealer replaced the water pump. I asked why with only 6 hrs on motor. The dealer stated that it is Yamaha's policy, and Yamaha does not warranty water pumps.I wrote a letter to Yamaha to question this [representation of the warranty policy of Yamaha on wear parts]. Matt from Yamaha called me and stated the Yamaha policy is to advise owners to pull the lower unit and inspect or replace the water pump yearly. I never has this problem with our using Evinrude or Johnson motors since 1970. I told [Matt, the Yamaha representative] I had just bought another new Yamaha for one of the other boats, and, when I received the title, it stated the motor had been manufactured two years prior and yet to be in the water. Matt then stated I should pull the lower unit and probably should replace the water pump due to the age of motor. I again stated motor was new in box at time of purchase. He stated that Yamaha would not replace the pump as it was the dealer's responsibility--the dealer refused to do as they stated Yamaha never had a problem with water pumps. What a deal. Think I had better go back to Evinrude for the next one. Thought it would be nice to have a local dealer for Yamaha as the Evindude dealer is 400miles away, but [buying a Yamaha outboard engine was] a BIG mistake.
conch
posted 06-07-2012 08:13 PM ET (US)
What was defective in the pump that the dealer removed?Some Yamaha's do not like to run on muffs--especially the V6. Did you [run the outboard engine] in the water before going to the dealer?--Chuck |
RENTER
posted 06-08-2012 11:57 AM ET (US)
The dealer said according to the shop work order the impeller blades were broken off. This statement made by Matt the Yamaha Rep--did not give his last name--really shocked me: if a new motor out of the box is over one year old it is the buyer's responsibility to remove the lower unit and inspect or replace pump. What a deal. |
rong
posted 06-08-2012 08:35 PM ET (US)
One bad water pump and Yamaha is bad? Sounds like the dealer doesn't like you. |
Russ 13
posted 06-09-2012 01:59 AM ET (US)
The Yamaha 50 uses a very small waterpump impeller. Although it was only two years old, a new impeller is cheap insurance [compared to the repair of] an overheated engine. With proper care, and avoiding running the engine in sand, or running dry, you should expect [up to four] years from the impeller. Remember: it not only spins but flexes on every rotation. |
Jamber
posted 06-09-2012 02:53 AM ET (US)
Sounds like lack of use is [the cause of the dispute between Yamaha and RENTER]. After getting two years out of the previous water pump with weekly use, I had a Yamaha water pump fail that was a little over a year old. The impeller was replaced 14-months prior to the failure. The Whaler sat untouched for three months. When I started it, I did not see any water flow, and the over heat buzzer came on right away. So I changed it myself. The rubber blades of the impella were stuck and broke off the hub. The impeller pretty much dried out as it was stored outside in the direct sunlight in Florida in the heat. I was surprised, but [the failure of the water pump] makes sense. Use it or loose it! |
posted 06-09-2012 12:09 PM ET (US)
When Yamaha was building its reputation for being a premium outboard engine in its early days of competing in North America, they used very high quality components in their engines for wear parts like a water pump impeller, seals, and other rubber components. A fellow Boston Whaler boat owner bought a Yamaha V6 outboard in 1992 and used it for more than ten years without servicing the water pump. That was the quality of wear parts used then.I don't know what the official policy for replacement of a wear part like a water pump impeller was back in 1992, but it was clear that you could expect many years of service from them. The boat I mention was used in fresh water on a seasonal basis in the Northern USA, and it often sat for six months in the winter in storage. It may well be that the policy of Yamaha was always that a wear part like a water pump impeller was an annual maintenance item. As for the double-speak about a new engine bought at retail from an authorized dealer needing immediate service to the water pump before use, that makes no sense. I would seek redress for lack of suitable service. When you buy a new car, you are not expected to have to replace the tires before you drive it. Why should you be expected to pay for parts and labor to repair the water pump? |
posted 06-09-2012 12:16 PM ET (US)
Now, back to your two-year-old engine with only six hours of running time: I don't think you can complain about having to replace the water pump. It appears to have previously worked when the engine was new, and now it has failed to work at an interval beyond the normal recommended service interval. It is clear that Yamaha does not offer any warranty on a wear part like the water pump. Water pumps in particular are not likely to be covered due to the variability of use and the opportunity for damage. Just turning the engine over a few revolutions without any water present in the impeller housing can cause damage. Ingesting sand or other foreign material into the pump inlet can also cause damage. There is no reasonable basis for Yamaha to offer a warranty on a wear part like a water pump. |
gusgus
posted 06-09-2012 12:38 PM ET (US)
I agree with the OP. How does Yamaha stack up against other competing brands is the criteria to me. When I buy a truck that burns out head lights at an alarming rate, I don't buy that brand again. When I buy a motorcycle that regularly and commonly leaks oil, I find a brand that doesn't. All brands seems to have issues, but when the issue endangers both the motor and the buyer, it is a perfectly acceptable reason to avoid owning a Yamaha. Frankly, I appreciate this thread. I have been watching Craigslist and reading fishing sites and Yamaha's seem to be disposable motors. |
rong
posted 06-09-2012 02:37 PM ET (US)
Again, "1" bad water pump and Yamaha is bad??Never in my life have I heard the term Yamaha is a disposable outboard. |
RENTER
posted 06-09-2012 02:54 PM ET (US)
I agree with gusgus. The Johnson motor the Yamaha replaced was over 30 years old. We keep service records on every thing we own including houses and lawn mowers, even computers and anything mechanical. Our records show that engine had three water pumps in the last nine years. They were replaced only as a preventive measure, not failure. We go by the pump water pressure gauge as to condition of pump. We also generally keep cylinder head temp gauges on the other boats. The salesman at the Yamaha store is a good friend and went to batt for us but he is restricted by Yamaha. I am just stating my opinion based on experience with 40 some years with Evinrude/Johnson compared to Yamaha. When Matt at Yamaha tells me I have to take a new motor out of the box prodced over one year prior that I have to pull the lower unit and inspect or replace water pump at my expense, I am finished. I agree Yamaha used to have a reputation for quality but I think the bottom line is the factor now. Toyota used to have the same quality reputation but what has happened the last few years? |
Russ 13
posted 06-10-2012 12:31 AM ET (US)
IF the only problem you have is: replacing a waterpump impeller every year..... I'd say that was a well built engine. (They also require repainting the trim & tilt motor, as the factory finish is not too thick on that part, if used in salt-water) * Maybe Yamaha needs to get a different supplier for their impellers, maybe the company that Johnson/Evenrude used.
conch
posted 06-10-2012 08:34 AM ET (US)
If the outboard builders would offer a fresh water cooling option I'm sure it would be very popular. A heat exchanger mounted in the boat and the ability to use an anti-freeze mix would be great. With new large motors approaching $20 thousand dollars each I think it is about time.I also wonder why a fixed metal (automotive) type impeller couldn't be used? Anyone know? Chuck |
Russ 13
posted 06-10-2012 10:42 AM ET (US)
My guess on the need for a flexable impeller, is the available housing size, restricted by the dimensions of the lower unit. An internal heat exchanger on the larger engines.....HHMM Interesting idea, it's not like adding another twenty pounds will make any difference......but where to put it? |
Whalrman
posted 06-10-2012 10:45 AM ET (US)
Water pump impellers take a "set" to the blades after time in the housing making them less effective in pumping water.It is really bad when the motor doesn't get run too often,in more ways than this but, thats another thread.Running more often is better, as it makes the blades move and thus keeps them more plyable/flexable.As the impeller turns the blades are forced to bend at the "cam" and then back to straight.Get your dealer to show you a "new" impeller and one that has been in a pump housing for a while,you'll see what i mean about the "set" the blades took on the old one. Pump impellers are like spark plugs,oil/fuel filters etc.-not covered by warranty unless the part is defective in manufacturing not by use.Your dealer should have explained all this to you in detail to make sure you understand thuroughly the warranty proccess/claims.All makes, no matter which one,do this. |
Whalrman
posted 06-10-2012 10:52 AM ET (US)
As with a heat exchanger unit,you would still need the intake pump to run cooler water thru the heat exchanger. Only in a keel cooled system would the additional water pump not be used. As for the "metal" impeller,my guess would be corrosion and electrolises eating away at the vanes of the impeller. |
contender
posted 06-10-2012 11:05 AM ET (US)
Conch: Salt water and rust? Rubber cheaper... |
martyn1075
posted 06-10-2012 11:42 AM ET (US)
Interesting you learn something new everyday. I would not be impressed either but I do like their engines. I know many fishing guides on the coast that put several hours a season like the tune of 500 and up a year and the only thing they tell me is that sometimes a few of the sensors act up where the mechanic has to clear them off to run the engine again properly. A few power head issues on the 225 older model four stroke but thats about it. I think they should have taken care of it for you its a minor part in cost compared to a tilt trim or replace lower unit repairs. I might go one step ahead and speak to a head Yamaha rep but it depends on how patient you are because it still may end up with nothing to show other than to let them know you will not be coming back. Sometimes thats all it takes. Martyn |
martyn1075
posted 06-10-2012 11:43 AM ET (US)
A good experienced dealer can really help you out at times to try to convince the warranty people from the manufacture. Thats what happened to me with a very costly tilt and trim assembly for my 07 Optimax engines. They were purchased at on the same day but one engine was a few months older. TIn result the the trim unit on the slightly older engine was not worn out YET but close and my warranty on that engine was gone by a month or so. The dealer helped me out saved almost 2k in part in repair. I guess we can give Mercury some credit this time as well. It still might be worth a phone call to Yamaha. Martyn
Mike Kub
posted 06-10-2012 04:19 PM ET (US)
Three things we should teach our kids: "Yamahas are disposable" "The silver fillings in your teeth cause brain damage" "If you play with yourself you will go blind" |
tom976
posted 06-11-2012 09:54 AM ET (US)
Just sounds like the dealer sux. For a $40.00 impleller (probably cheaper) and 30 minutes of time they lost a customer. This sort of sounds like a leftover sale since it was a year or two old but was in the box. |
17 bodega
posted 06-12-2012 01:09 AM ET (US)
Renter - How much did the water pump (impeller) change cost? So.. because the dealer gave you some sound advice and told you not to operate an outboard engine without first checking the condition of your water pump? Ok. Matt from Yamaha sounds like a low paid customer service call back representative. Give his supervisor a call about the motor in the box... I believe you have a valid grievance for a new impeller - IF IT NEEDS IT. Remember, Matt just told you to unbolt it and check it, which I repeat is always good advice. Your dealer didn't want to change it because he probably has sold hundreds of the motors out of the box (over a year sitting in the box) with zero problems. Your whaler on the other hand was sitting in your possession and the dealer policy is to change it out - probably to avoid burning up motors and getting warranty claims. If you knew how to check your impeller and run it in the water as conch suggested, you may have learned it was perfectly fine - Or not. I have a 2002 Yamaha 50 horse four stroke. I keep an extra impeller in my boat box, and I replace the part regularly. You appear to be stuck with 2 Yamahas - learn to deal with the impellers. Keep a couple of them in your boat box along with spark plugs, oil filters.
Many folks love their Johnson's ... and their Evinrudes, but Yamaha also has a fine reputation for well running motors. Talk to some owners at your local boating locations or on boating forums like this one and others. I think you will find Yamaha to be a solid product. Good luck to you. Steve |
GSH
posted 06-12-2012 03:26 AM ET (US)
I’m a bit of a Yamaha fan-boy, I had a 3-cylinder 2-storke 30 HP for one summer, and still have an old 3-cylinder 80 HP around.Even so, this thinking that it is OK to engineer something like the impeller of outboard lower unit water pump so that replacing it once a season is mandatory for everyone, no matter the hours or the usage, just makes me very unhappy, to put it mildly.
gusgus
posted 06-12-2012 05:22 AM ET (US)
To all the Yamaha owners out there, I didn't coin the term "disposable motors" It was coined by a person on a boat sale and it seems to be a valid concern, if only by the owners of these boats. I have seen 4 Craigslist boat sales in the last months with busted Yamaha's on the back. Most were newer motors and larger sizes. The last was a 225 Yamaha Saltwater series on a 2000 Outrage 22 foot selling in the Pacific Northwest. It was busted and he called it a "POS" I have owned Yamaha's before and never had trouble, but 4 sales in a month with the same kind of ending? Then this impeller issue surfaces, which I see as bad design and an incredible dealer or brand abandonment of the customers. I mean no disrespect, but I believe it to be a valid concern, if the yearly failure of the pump happens at the wrong time and you have a broken motor to sell with the boat. It makes them a risky prospect for purchase. Try to change the pump 20 miles off shore. |
posted 06-12-2012 09:48 AM ET (US)
RENTER says: "I agree with gusgus."GUSGUS says: "I agree with the [acronym for original poster, i.e. RENTER]." A band of two. |
17 bodega
posted 06-12-2012 12:59 PM ET (US)
When you see "I saw 4 Craigslist posts..." it prepares you for the wisdom that follows...Need I say more?
GSH
posted 06-13-2012 07:45 AM ET (US)
If someone really wants to regard more required maintenance as a positive trend or good boating, then that really surprices me.More likely, some folks are just trolling.
elaelap
posted 06-13-2012 10:31 AM ET (US)
While I know that generalizations derived from statistically insignificant particulars are of limited value, I can't resist sharing a couple of personal experiences with Yamaha four stroke motors:1. My first, a T50 ('High Thrust') carburetted four stroke on my first Whaler, a 16'7" Katama -- something like 700 flawless hours in a couple of years without changing the impeller. That boat/motor is now owned by my pal Steve/17 Bodega, and he has more than doubled the hours, without a problem. 90+% of the time on that motor was/is in salt water, BTW. 2. My second, an F115 EFI four stroke on 'Cetaceous', my beloved 1988 Outrage 18 (still my all time favorite Boston Whaler/motor combination for my uses) -- 760 flawless hours in just over two years, with one impeller change as part of preventative care...turned out to be unneeded; the impeller was in perfect shape. 3. My third, an F60 on a Sport 15 center console. What fun that little skiff was! Topped out at 43 mph and got around 12 mph at a comfortable 30 mph cruising speed. The rig wasn't too good for our lumpy near shore coastal waters, but great on the SF Bay, lakes & rivers. I think the motor had around 350 hours when I sold the boat; no problems whatsoever. Again, maybe this anecdotal 'evidence' only 'proves' that I was lucky with three particularly well-made Yamaha motors, but take it for what it's worth. I'd buy another one in half an instant, and my experience seems to mirror that of most Yamaha four stroke owners I've talked with or read comments from online. Tony |
GSH
posted 06-13-2012 11:44 AM ET (US)
Tony, that's a nice and strong supporting statement for Yamaha outboards!However, one question, if you don't mind: What if - when one day in the near future, you make the choise buy a new or very low hours Yamaha outboard from a dealer near where you live - they tell you that oh, by the way, on this one you'll need to have a new impeller installed for each year/season, no matter the type of use or the hours. Would you feel like that's the Yamaha outboards you know? Br, Seb
17 bodega
posted 06-13-2012 12:47 PM ET (US)
GSR,I think the speculation is getting out of hand here. Let's not forget that the dealer RECOMMENDS you CHECK your impeller annually! If you are a prudent owner of a boat and care about safety, this is a no brainer! I work at an ocean access boat ramp... have for about 10 years. Guess what most tow-ins for boaters is?? Yes sir. Water pumps that fail! This is basic boating 101 folks, Johnson, Evinrude, Yamaha, Suzuki, etc! Steve |
17 bodega
posted 06-13-2012 01:00 PM ET (US)
I would add that Yanmar, Volvo/Penta, Chevy 350, and every other manufacture of engine is vulnerable to water pump failure in a boating environment. Ask anyone who spends time on the sea or inland waters and they will tell you.When a marine engine takes in water from the outside environment, you can get mud, silt, debris, and other particulate matter in your cooling system. That is why we flush our engines after use. It's just like checking the air in your tires, checking the oil, and tune ups. When you buy a boat and engine you assume some adult responsibility to know some basic maintenance, or you have no business taking people out to sea. I see it every day. |
elaelap
posted 06-13-2012 01:22 PM ET (US)
If a dealer of whatever brand of outboard motor told me that I needed to change the impeller every year, I'd change the dealer instead.Now I boat in relatively clean water, and like many of us out here I religiously flush my motor after every salt water use, but tell the truth...I don't even bother to check my impeller every year, let alone change it out. No problems so far, thank Poseidon ;-) One other little anecdote, this time about our partnership Suzuki DF140. This motor has powered a series of "Strike3" banana-hulled Revenges, all of which have spent their sweet lives in a salt water slip nine months per year. After the first two hundred hours or so, we (for the first and last time) had a dealership wrench check out the motor...do a mis-named "tune-up" including an impeller change. The impeller was in perfect shape. Since that time (we now have something like 1200 hours on that motor) we've done all the maintenance ourselves (thanks to Matt/placerville's expertise). Last year, at about one thousand hours, we decided to replace the water pump as part of preventative maintenance. The impeller seemed to be good as new. Go figure. I'm convinced that the very best thing for modern outboard motors, especially four strokes, is lots of use, frequent oil changes at factory intervals (~100 hours top end, 200 hours bottom), and flush, flush, flush after every use in salt water or muddy fresh water conditions). So far so good. Tony |
elaelap
posted 06-13-2012 03:39 PM ET (US)
Ooops...meant to say that my Sport 15/Yami F60 got around twelve miles per gallon at fairly swift cruising speeds. Really. |
martyn1075
posted 06-13-2012 07:49 PM ET (US)
12 miles? unbelievable thats great! |
GSH
posted 06-14-2012 03:57 AM ET (US)
Steve, I respectfully disagree.Having to check you impeller once a year if you boat in salt water, don’t do the freshwater flushing and have other factors that together form a challenging mode of operation for the water pump, then fine, do check it or have someone check it for you. Good to keep the safety aspect in mind. However, to say this (removing the lower unit to check or replace the impeller of the water pump) is basic boating 101 while letting the reader understand that this should be true no matter the hours of use or the kind of use is being considered, that’s just not a point of view I’m prepared to support. I’ve been trying to teach my wife and kids what I consider to be “basic boating 101”. Looking at both the safety and the maintenance aspects of the type of boating we do (and most other people we know who also have boats), the impeller of the water pump is currently not on the agenda, and I very much hope I stays that way. I do agree that if it is your business to provide the service of taking people out to sea, then it is best to do more proactive maintenance than what should be required for normal recreational boating. Talking stern drives, I have little personal experience. From what I know, a lot of the stern drive units only have direct sea water cooling and use the water pump of the OEM motor to circulate the cooling water. (This would be a choice made to keep the price low.) If this is the solution, I’m not at all surprised if the failure rate in ocean salt water is high. Anyhow, we were referring to outboards here. When you buy a boat and engine you should use you best judgment to evaluate what should be considered basic maintenance (which you will later be responsible for), and challenge the sales organization to offer you products that meet your expectations, or you have little reason to later feel sorry for the time and money you need to spend to support your boating hobby. I’m sure that people who see maintenance work as a positive part of their hobby don’t mind if there’s a few extra things on the task list. I, however, would rather spend more time actually boating. To each is own, etc. ... Tony, thanks for the reply, I very much agree with your views on the benefits of high usage and flushing with fresh water. Br, Seb |
martyn1075
posted 06-14-2012 11:37 AM ET (US)
I have not had experience with every new modern engine BUT would it not be safe to say most impeller lifespan is about three years of use without a problem or even thinking of replacing after that? I know the outboard companies say in writing on their manuals to check or replace every year but I think that is just to cover their [exposure to costs of replacements]. I don't think the replacing of a impeller yearly is something that should be required or a concern that is on your mind all the time. What a unnecessary stress knowing that the pump could prematurely fail within a year if its not replaced in time. If [yearly failure of the water pump is likely] is on these Yamahas--which I'm not quite convinced it is--it would be one of the few knocks on a very solid engine. Every engine on the planet has something, whether it is a premature tilt-trim malfunction or over-sensitive sensor. Perhaps maybe a case is to be made for the Yamaha--they're not bulletproof. This is interesting and important information that when making a purchase is something to look into at the very least. Very important to take average rather than just one or two cases which this may be. Martyn |
17 bodega
posted 06-14-2012 09:50 PM ET (US)
I think we're pretty close in the ideas we're trying to convey. No, of course I don't mean your wife and kids should know how to take down a lower unit and check an impeller, or if you are a casual user that gets out a dozen times a year - in which case you look for a good telltale stream and have a kicker on the boat that works.I make the assumption here that we on CW are hardcore boating enthusiasts and have more savvy than the average weekend warrior. We have inquiring minds, we are renaissance men and women who are not satisfied with peripheral knowledge on this subject of boating. Boating 101 was perhaps too casual a term, describing how to lower your boat from a trailer, basic navigation, safety, and an acceptable level of intuition. Boating 101 for us, or at least for me in the Pacific Ocean in Northern California raises the bar of boating 101, as does many locations that members here frequent, all with their own dangers. A disabled motor in even docile ocean conditions can be a potentially life-threatening situation. I will say that my YAMAHA outboard built in 2002 went 5 or more years without an impeller change under heavy use. In retrospect that was irresponsible of me.. and in time my powerful vigorous telltale stream became a feeble dribble...(sadly) Now...my 50 horse is a one person job and a couple of bolts to drop the lower unit and get to the entire water pump assembly. Bigger outboards are more involved and may need a jack or more tools. Anyway, as a guy who uses his boat constantly and in the ocean, with my particular motor I advise everyone to be hyper diligent about their motors. Steve |
17 bodega
posted 06-14-2012 09:57 PM ET (US)
I should have said "hyper diligent about engine maintenance.. including water pumps"And I agree with Martyn that Yamaha recommends the ANNUAL impeller check to cover themselves from warranty claims from people who blow head gaskets from overheating their engines. The water pump could very well be a weak link in the motor [but] I tend to doubt it. There a so many positives on these engines that I'm happy to live with that weakness knowing how to mitigate the problem.-- Steve |
posted 06-15-2012 07:36 AM ET (US)
"Perhaps maybe a case is to be made for the Yamaha--they're not bulletproof."I would not downgrade Yamaha to the category of "bulletproof." I'd agree--they are not "bulletproof." That term has been applied too often to engines with much inferior reliability than Yamaha engines. It would be misleading to call Yamaha "bulletproof." From what I can tell, when someone says that an engine is "bulletproof" they're really saying it needs a lot of annual maintenance to stay running. |
Mike Kub
posted 06-15-2012 11:25 AM ET (US)
This,like so many other topics, has been very informative. My local Yamaha dealer said they would put a new water pump in themselves if a guy bought a new engine. He also said sitting in a box for 2 yrs. off center could distort the rubber. I live on the upper Texas coast.By far Yamahas are the most common engines.Especially newer engines.A few Suzukis & Mercs & rarely do we see Hondas or E-Tecs.There are 3 Yamaha,1 Merc & 1Suzuki dealers within 30 mins.of my house.Nearest E-Tec is in Houston. Why is that? My once powerful stream has become a feeble dribble also.Peace. |
Mike Kub
posted 06-17-2012 10:12 AM ET (US)
Correction:one of our Yamaha dealers just started handling E-Tecs. |
RENTER
posted 07-08-2012 03:06 PM ET (US)
Two boats sold. One left to sell (Montauk w/90 Yamaha w/11 hours since new) and then I am out of the Yamaha business. Have already purchased a 18 Outrage w/Evinrude, and looking for one more boat. I am sure a lot of you have had good luck w/Yamahas but in my opinion and w/my personal experience a Yamaha in no way compares w/Evinrude. |
rong
posted 07-08-2012 06:04 PM ET (US)
What a bizarre thread. Sell all your boats with Yamaha's because of a $36 dollar part. WOW |
17 bodega
posted 07-09-2012 01:46 AM ET (US)
Well, the boats [with YAMAHA engines] apparently sold quickly. The buyers didn't seem concerned. Most people around the Pacific Ocean jump at Yamaha powered boats. They have a great reputation. Last I checked the top three selling outboards are HONDA, YAMAHA, and SUZUKI in that order. My buddy put over 7000 hours on his Yamaha 70 two stroke engine! Years and years of use many miles offshore in the Pacific... Although I can appreciate the persuasion the author engages in here I doubt he has convinced anyone that Yamaha is a poor quality product.
gusgus
posted 07-09-2012 02:06 AM ET (US)
This thread is incredible, simply because of the "you hurt my feelings" people. The truth is to those on here that chose to be personally injured that it isn't about the quality of Yamaha, it is about their self image, since the OP didn't personally attack anyone. But you all sure did attack him. YOU DID TOO jimh! It is so wild that people get defensive over another person's real issue. The facts be damned in some informative threads, since it hurt their exposed yamaha feelings? I don't know whether Yamaha, Evinrude, Honda, Mercury or Johnson are the best, but I would rather hear others issues and concerns than see them treated like crap because they already have had enough of a tough time. I am with Renter though, when I see so many issues, and at the costs of todays motors, I will hold off owning one until the trend changes. |
posted 07-09-2012 09:33 AM ET (US)
Gus--I have not made any personal attacks. My comments have all been about Yamaha, the wear parts, their warranty policy, and the concurrence of your opinion with mister RENTER. I expressed my complete agreement with mister RENTER's objection to having to make a repair to a new engine because it had been sitting on the shelf for a few years prior to being sold. I don't know how you can construe that as "an attack." As for the basic premise of mister RENTER, that Yamaha outboard engines are inferior based on his experience with Yamaha's refusal to replace a wear part, I do disagree. A wear part is not covered under the same warranty as other components, and in this case the recommended maintenance interval for the wear part was exceeded. It seems to me that RENTER is asking Yamaha for two substantive changes in their policies: First, RENTER wants Yamaha to offer coverage of wear parts in their warranty. Next, RENTER wants the period of coverage to be lengthened in order that the wear part he needs to replace will be included. Since Yamaha apparently has declined to comply with RENTER, RENTER now wants to condemn all Yamaha outboards as being inferior and to be avoided. Neither you or RENTER should consider my extreme reluctance to adopt this position or to endorse this logic as being a personal attack. You should not infer that just because I do not agree with you that I am therefore launching a personal attack. You and RENTER are free to conclude whatever you like regarding Yamaha outboard engines based on the narrative given by RENTER. All other readers, including me, are similarly free to decline to agree or to withhold our endorsement of you position. |
gusgus
posted 07-10-2012 03:27 AM ET (US)
Jimh; It isn't so much the personal attack aspect of this threads value, it is the inability to even consider the question (demand) that Yamaha change their policy. A policy that does taint their image. The charlie brown contingent on here, turned into a urinating contest, rather than the fact we all should stand side by side and say BS, This is not right. My money is my vote and as silly as it may sound, I will avoid Yamaha, no matter how good they are. They could be the best, but it is MY MONEY! It is MY BOAT, and it is my vote. It is not an incorrect question to ask any manufacturer to correct a stupid policy, which Yamaha has seemingly refused. Lastly, the dolt that suggested I am somehow deficient because i use craigslist, made a personal attack about facts stated, how is grouping Renter and I as one, not jumping on the slam those anti yamaha guys, Jim? Jim that was an attack because of the rest of the thread. It was bad form and frankly crappy treatment because of a real issue that some could maybe grow a thicker skin and try to help the situation? Rather than become ford and chevy styled haters. |
posted 07-10-2012 08:57 AM ET (US)
In any interaction between outboard owner, outboard authorized dealer, and outboard manufacturer regarding a dispute about warranty coverage there are typically two levels of support. There is the support provided by the written warranty statement which is required to be provided to the purchaser under the terms and conditions specified. Then there is the extended support that is often provided which exceeds the conditions and terms of the written warranty.For some customers, in some situations, with some dealers, all that will be provided is the support under the terms and conditions of the written warranty. For other customers, in other situations, with other dealers, there may be more support provided. Many factor influence these results. If the customer is a valued customer, perhaps one that has a long relationship with the dealer, and if the customer bought the engine from the dealer, the dealer may be inclined to go beyond the terms and condition of the written warranty. If the dealer is a strong dealer for the outboard engine manufacturer, with a long history with that brand, and if the dealer has a well-trained and expert maintenance and service department, and if the dealer is a high ranking dealer in the manufacturer's service rankings, then perhaps the manufacturer will give that dealer more discretion regarding coverage of repairs under the extended warranty. I am confident that there have been a few water pump impellers replaced at no charge for a few customers by a few dealers for a few manufacturers. But the notion that one customer went to one dealer with one problem and did not get support that exceed the terms and conditions of the manufacturer's warranty does not compel me to condemn that manufacturer as being sub-standard in their customer support. Whether or not Craigslist is a valuable tool for obtaining statistical data about engine reliability is the subject for another discussion. I would consider Craigslist to be anecdotal data. As I have mentioned before, I do not know of any source of accurate and reliable data about the frequency of repair rate for various outboard engine brands, models, model years, and usage patterms. I am not inclined to draw an inference from a second hand report about casual observations of anecdotal data from a source like Craigslist. I will offer that anyone who presents anecdotal data from a source like Craigslist should not take offense if there is reluctance for others to adopt it as gospel. |
wezie
posted 07-10-2012 09:18 AM ET (US)
Well said Jim.With only one side of this saga on which to base any discussion, this one seems like a slow news day headline. "Mayor Clips Toe Nails." We know nothing about the contract, written and verbal. Or any discussions at the time. Or attitude of either party. Or as usual, the intent of either. Craigs list says thar 68 percent of Internet forum space is taken by strings like this. A friend also reminded that 55 percent of quoted statistics are made up on the spot. Good Luck. |
17 bodega
posted 07-10-2012 09:48 AM ET (US)
No personal attack was intended on you, Gus. Sorry if you felt that way. I did want to call attention to the "4 Craigslist ads" as very weak example to use...Steve |
gusgus
posted 07-10-2012 03:52 PM ET (US)
I have not been offended, however it became a dogpile of attacking the messenger, ignoring the message. The strength of any forum is the ability to share a message. If it becomes one where messages are jumped on as if someone's panties are all bunched up, the message is (example) lost in minutia. The second victim will be the lack of messages, where good old boys talk about cooking and their tight fitting undies. A forum lifeline I have watched before. Be careful what you wish for, you may just get it. I missed the questions that asked for better information, other sources, guarantee descriptions or to show the Craigslist adds? |
