ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: The Whaler GAM or General Area Trailer: Backing Up
Author | Topic: Trailer: Backing Up |
richvi |
posted 08-10-2012 12:36 PM ET (US)
I used to look over my shoulder while backing the trailer. But I pulled a muscle in my side last summer. I had read the topics on 'backing trailers' on this web site in search of new techniques. However, the use of the rear/side mirrors did not work for me. This year I tried using another tip: a target in the boat as a centering technique. A brightly painted tennis ball attached to a pole in the center of the boat. On the very first attempt, in using only mirrors, it worked like a charm. While looking in the rear mirror, I could quickly see whenever the trailer was going off to the side. My body thanks to whomever shared that tip. |
Chuck Tribolet |
posted 08-10-2012 05:12 PM ET (US)
If your trailer is wider than the truck, using the side mirrors works just fine. You quickly learn what the trailer fender looks like in the mirror and can see if it's off by only a little.
onlyawhaler |
posted 08-10-2012 06:07 PM ET (US)
I hurt and had surgery on my neck years ago and I had to re-learn back skills. I just can't turn around anymore and my driveway where I park the Whaler is uphill and angled I learned to just sit back and watch the outer edges of my fenders. I just keep it slow, watch the angles and it has worked for me. Also while backing my Chev Tahoe to the hitch on the trailer I learned a tip from a friend. I have placed a small decal on the inside of the rear window marking the center of the vehicle which keeps me close to centering the hitch while backing up to it. Hope it helps Sterling |
contender |
posted 08-10-2012 09:09 PM ET (US)
Do not see it so much any more, however use to see a lot of hitches on the front of a trucks for launching the boat.. Another thing that is helpful is a longer tongue on the trailer... |
PeteB88 |
posted 08-11-2012 12:17 AM ET (US)
Just practice backing mirrors only without a trailer hooked up, then hook it up. One thing I learned years ago from my iron worker cousin Bob is when you have to turn the rig while backing up and once you establish your angles and path he used to say "now follow it" meaning follow the trailer with the tow vehicle and you'll be surprised that it works great. You will notice immediately that you will not oversteer or over correct if you learn how to "follow" the trailer. Once you establish your straight line back up path, hold the wheel straight (works best w/o trailer). Sometimes when backing up in long straight line, I will zig zag the steering wheel just a little bit which I have seen double bottom semi drivers do backing up big rigs. |
retired |
posted 08-11-2012 12:34 AM ET (US)
To help with steering while backing up, place your hand on the bottom of the steering wheel and turn in the direction that you want to go. i.e.(If you want the trailer to go the left turn to the left and if you want the trailer to go to the right turn to the right.) |
Jerry Townsend |
posted 08-11-2012 02:35 PM ET (US)
Experience - experience and still more experience. Hook up your boat trailer on a quite Sunday morning and practice in an empty parking lot. Been dragging and backing trailers for a long,long time - but this is what I did when my son was first learning to back a trailer. ---- Jerry/Idaho |
Chuck Tribolet |
posted 08-11-2012 03:06 PM ET (US)
And if you have a 4x4, put it in compound low. Everything happens in slow motion. Chuck |
PeteB88 |
posted 08-11-2012 03:58 PM ET (US)
Sometimes slow is good. |
Marsh |
posted 08-12-2012 10:11 PM ET (US)
I've been backing boat trailers since 1980...various tow vehicles...'76 Nova, '83 full size Dodge van, '90 GMC 3/4 ton van, dodge pick up, three different Ford pickups...anyhow, I've always found it much easier to back a truck, trailer attached or not, by using the external mirrors. Neither of my custom vans even had internal mirrors. Couldn't have seen anything with them anyhow. Yup. External mirrors for me...at least for trucks...cars might be different. Gotta admit, backing the Wave Runner is a bit tricky, no matter what mirrors are used. Short wheel base on the trailer makes it super sensitive to steering input. |
pete r |
posted 08-13-2012 03:10 AM ET (US)
Have a look at the new reversing cameras on Ebay |
kwik_wurk |
posted 08-13-2012 02:41 PM ET (US)
I just open the back door to the SUV (make sure everything is secured, less it roll off the back). But yes, the my trick is drive the trailer on the route you plan, and let the truck follow. |
gusgus |
posted 08-13-2012 02:47 PM ET (US)
I have a dually and it is nearly impossible to see the trailer behind the truck when the boat is not there. I installed a front hitch and man does that make moving the trailer and boat easier. But I plan on installing these; http://ecx.images-amazon.com/images/I/31Q2TdzVF9L._SL500_AA300_.jpg so I can see the back end of the trailer in the mirrors. |
Jefecinco |
posted 08-13-2012 06:45 PM ET (US)
I find it extremely useful to open the tailgate on my pickup when at the launch ramp and when backing on the driveway at home. I first learned backing with a trailer while a very new trooper in the Army Engineers. As a heavy equipment repairman I needed to be able to move the equipment around our work sites. An old timer gave me lessons for about 15 minutes then turned me loose with a 5 ton tractor and a lowboy trailer so I could practice. I spent just about the whole day playing "truck driver" and building confidence. At the end of the day I could do almost anything with that tractor trailer combination. Butch |
ToeCutter66 |
posted 08-13-2012 07:57 PM ET (US)
I have a front hitch on my truck, but I have never needed to use it. |
pete r |
posted 08-13-2012 08:02 PM ET (US)
I aways drop the tail gate. It's amazing the assistance you get from noises from the rear as you reverse |
Nauti Tauk |
posted 08-13-2012 08:56 PM ET (US)
When backing down a ramp I put the truk in neutral at the beginning of the ramp incline and let the boat/trailer pull the truck down the ramp. This seems to just about eliminate the weaving I use to do with the short wheel base on my 170Monatuk trailer. |
padrefigure |
posted 08-14-2012 07:47 AM ET (US)
One other trick you can use to keep the trailer on line--as you start to back up, pick a target spot 10 feet or so behind the trailer tire. Then as you back up, watch the course of the tire and adjust it to keep it on the line. The concept is to break the back up distance down into manageble segments. Complete all the segments and you should be right on target. |
Landlocked |
posted 08-16-2012 04:57 PM ET (US)
I always use just the side mirrors. Just watch the trailer tire. with practice - it really is the easiest way. |
davej14 |
posted 08-17-2012 02:28 PM ET (US)
Guide-On posts on the trailer serve a useful dual purpose. When the trailer is empty they make the position of the trailer easily seen when backing down the ramp. |
posted 08-17-2012 03:12 PM ET (US)
Tall white guide posts are excellent in helping to back up the trailer without the boat. I also mark the proper water line on the guides so I know how deeply to immerse the trailer for proper loading. I always back in until the water line on the guide post reaches my mark. |
gusgus |
posted 08-17-2012 05:57 PM ET (US)
The guide posts and the marks are both great ideas. How do you adjust your depth and use the marks in different pitched ramps. Or do you primarily use one ramp? |
posted 08-18-2012 08:30 AM ET (US)
I don't have a scientific method to compensate for ramp slope and immersion. I play it by ear. The mark represents the normal waterline of the hull when the boat is on the trailer. When launching I usually back in to the point where the mark is just below water. The boat usually comes right off the trailer at that point. When loading, I usually back in to the mark. As the boat is winched onto the trailer the stern will tend to settle gently on the bunks. If the trailer is too deep when loading you often see the boat remain floating until you start to pull out, at which point the boat may settle onto the the trailer with a list. By starting with the mark at the water line, the stern tends to be bearing onto the bunks and tends to center itself. Once the boat is mainly on the bunks and not afloat, I will back in further to make the load on the winch reduced by adding some buoyancy. The guides also help keep the boat centered and prevent loading with a list, although in situations with a strong cross wind a Whaler will tend to lean into the wind. Ramp slope can cause problems in launching and loading for some boats and trailers. I recall one ramp I used where I could not get the boat onto the trailer properly. It was a long ramp. I drove up the ramp, turned around, and drove down the ramp with the truck first. This put the boat on the trailer on a downward slope. With the bunks wet and the downward slope I was then able to winch the boat the last few inches onto the trailer. I got a few strange looks from other ramp users. If the boat does load on the trailer with a slight list, I have found that by the time I drive 500-miles on the highway back to home the boat will have nicely corrected itself and be almost perfectly centered. |
swist |
posted 08-19-2012 08:45 AM ET (US)
I am so lame at this it's pitiful, although I have a small excuse in that my Montauk sits on a mooring all season so I only get to do it twice a year. I do use the hand on the bottom of the steering wheel trick so that I mostly turn the wheel the way I should. But what usually happens is when the trailer starts to go a little off course I start correcting very very slowly but it never seems to have any affect until suddenly I've overcorrected - half the time I wind up in a jacknifed position and have to go forward to straighten out. I'm going to carefully re-read every reply to this topic and see if I can pick up any hints. |
posted 08-19-2012 10:27 AM ET (US)
Part of the problem for swist in backing the trailer for his MONTAUK may be the short distance between the hitch and the trailer axle on a trailer for a 17-foot boat. The shorter the distance between the hitch ball and the trailer axle, the faster the trailer will react to changes in direction. Backing up a larger trailer where the trailer axle is probably twice as far from the hitch as on swist's trailer will literally be twice as easy. |
swist |
posted 08-19-2012 11:10 AM ET (US)
Thanks Jim, will keep that in mind. At least I feel less like an idiot. |
