ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: The Whaler GAM or General Area V6 E-TEC 135 H.O.
Author | Topic: V6 E-TEC 135 H.O. |
GSH |
posted 12-04-2012 10:59 AM ET (US)
The word on the web is that [Evinrude] is about to replace the 115 H.O. and the 130-HP V4 E-TEC outboards with a new 135 H.O. model. The new E-TEC 135 H.O. is basically a new version of the 150-HP model, or so it seems. According to claims on the web this change is due to EPA requirements. I for one would have liked the 130-HP V4 to be around for a bit longer. |
Tom W Clark |
posted 12-04-2012 11:09 AM ET (US)
The press release: |
andygere |
posted 12-04-2012 11:33 AM ET (US)
Are they really killing the V4 platform, or just adding a high end mill to the small block V6 line? |
george nagy |
posted 12-04-2012 11:41 AM ET (US)
Now I wonder if it will be priced less than that of the standard 150 v6 e-tec? If so this may be a new cost effective way to upgrade the power for the 18'/19' outrages and stay with v6 torque. It is curious that they don't offer the 150 HO in a 25" shaft but hey do offer the 135 HO. It would be great if they would come out with a 100 HO based on the 115 v4 which would be a good choice for repowing a montauk and still be within hp requlations. Still it is nice to se some news from BRP on the lineup anyway. |
Peter |
posted 12-04-2012 12:36 PM ET (US)
Unless there is some reasons to offer one and not the other to better conform EPA regulations, I see no reason why the 130 can't stay in the line up. Having the 130 and 135 HO is similar to having the 200 and 200 HO. Both have their places. Costs them very little (a new set of decals and a tweak to the engine map) to make a 135 HO off the V6 platform. It weighs about the same as a Suzuki 140 but with more displacement and firing 6 cylinders as a 2-stroke, it will clearly outperform the Suzuki. |
posted 12-04-2012 01:47 PM ET (US)
My understanding of the situation re this new 135-HP E-TEC is as follows: --the V4 E-TEC engines remain in production as the 115-HP models --the new 135-HP V6 replaces the prior 130-HP V4 which was some sort of high-output designated engine --the 135-HP V6 E-TEC will be the torque champion of that horsepower class --the V6 135-HP will weigh more (obviously) than the V4 130-HP --the price differential between the V6 compared to the V4 will make it attractive to buy the V6; the price increase will only be on the order of a couple hundred dollars I am told --the 135-HP V6 will be adaptable to electronic controls using ICON and also be available in counter rotation models; the V4 was available in counter rotation but did not have the option of electronic controls --the EPA emission requirements are becoming more stringent every year, and rather than calibrate and qualify the V4 at 130-HP it was probably decided at Evinrude to calibrate and qualify the V6 at 135-HP. |
prj |
posted 12-04-2012 04:18 PM ET (US)
I don't believe that there was a "130-HP V4 which was some sort of high-output designated engine". I think that a 115 V4 model was the version that carried the HO designation. I'd be completely shocked if the price differential from a 1.7L V4 to a 2.6L V6 were "on the order of a couple hundred dollars". Currently, the price differential between those platforms, in the 130 and 150 HP values, appears to be between 17% and 19%, or $1700-2200. While its certainly possible, I'd suggest that a compression of that order between the two different platforms would crush the sales of the 150 HP versions unless those prices were also dramatically decreased. I used these quick Google searched sites for price comparisons, with a 25" shaft as the standard: Finally, test data that I've seen on the current 130 HP V4 E-TEC were exhibit 1B in the [E-TEC] naming convention that a crafty contributor came up with. The performance appeared quite soft in comparison to my similarly spec'd Yamaha 130. Seldom does a company abandon a hot selling product after a relatively short production run, if in fact, they are abandoning the 130 HP version. And finally, that is a massive displacement 135 HP engine. Was the original Johnson-Evinrude 135 and 140 HP engine a V4 or V6 model? This version should certainly be one powerful horse and a good candidate for an Outrage-18 repower. |
posted 12-04-2012 05:13 PM ET (US)
Re prices--I have not seen any. My comment was reflective of a dealer's comment to me. I am reasonably certain the price points will be such that they're reflective of the power output, but it is already common to see some anomalies in the price of engines versus power. Let me take you to school on this, if I may: At present Evinrude has a 225-HP E-TEC. Evinrude also has an almost identical engine that it calls the 200 H.O.. There is a school of thought that thinks these engines have about the same power output. The model designated "200 H.O." sells for a significantly lower--at least significantly lower to me--price, about $600, as I recall. This is a bit on an anomaly in the price-power curve. If you pay more for the higher-priced engine will you get more power? I don't know. It would be interesting to see a careful analysis of the price of outboard engines in a particular manufacturer's product line as a function of horsepower in which there was an attempt to develop an algorithm or to fit the points to a curve. Maybe someone will take this on and write a good article about it. I would love to see a careful analysis. Re the V4 130-HP being a high-output. It was a high-output engine, that is, not a model designated "H.O." but an engine that produces a high output power for its displacement. In contrast the 135-HP V6 will be a de-tuned V6 or a low-output engine. It is quite common to see a particular engine platform used over a wide range of power outputs, and when that engine produces higher power we can say it is a high-output model; when that engine produces lower power we can say it is a low-output model. I have seen several mentions that the EPA regulations played a part in this model change, but I don't understand what inference I am supposed to draw from that statement. I really don't care how the EPA influenced the development of the new engine, because all that really matters is that the engine meets the limits needed to qualify in model year 2013 for sale in the USA. My speculation about EPA influence on the V4 engine models was also based on some comments made by a dealer, but I don't know if those thoughts were based on some more particular. ASIDE to Patrick--I see you are trying to introduce [your derogatory term for the E-TEC], again. What is your motivation for this? Are you trying to take over first-place in the category of who can spread the most fear, uncertainty, and doubt about the E-TEC this month? |
prj |
posted 12-04-2012 06:36 PM ET (US)
I'm willing to refer to the 130 HP V4 as [derogatory term] because the performance reports suggest that the engine is weak and, if your dealer source is to be believed and the engine is dropped, its sales are weak as well. It fits the criteria perfectly. When you wrote that the 130 V4 was "some sort of high-output designated engine" you meant that it was the highest horsepower in its platform? That seems particularly confusing when there actually exists a model named "HO" or high output in said platform. I'm a bit of a stickler when it comes to word selection, I guess. A quick review of the E-TEC 200 HO and 225 suggest that they are built upon the same platform, the V6 3.3L / 200 cubic inch platform. I'd expect them to be priced fairly closely with a modest increase for the 225 over the 200 perhaps, and in reviewing the links above, see that they are. A bit over 3% additional money gets you the 225. I am surprised to see that for a modest grand, or a bit under 6% increase, you can get the 3.3L 200 in lieu of the 2.6L 200. That seems like good money. I'll be interested to see if they can get the price of the new V6 135 HP somewhere in the middle of the V4 115 and the V6 150, but fear it will lean to the higher end in a big way. |
Jeff |
posted 12-04-2012 11:54 PM ET (US)
With today's technology why in gods name would you need (nor want) the weight and size of a 135hp V6? One would think BRP would / should invest in designing a new inline 4 block to handle their midrange power needs. Yamaha is building 200hp inline 4's. Which I personally think is a great option. |
posted 12-05-2012 12:59 AM ET (US)
Evinrude has had a V4 engine for a long time. The present E-TEC V4 is a 60-degree V-block. I think the engine is just more or less two-thirds of the V6 engine. I like the look of the layout of components on the BRP 60-degree engines. They are really nicely engineered. Everything seem to fit together well in a small space. I guess we could use Patrick's make-it-up-as-you-go sales theory to explain why any engine no longer in production has been dropped--weak sales. The list would be really long. We could start with almost all of the Mercury OptiMax engines that have been dropped in the past year or two. Your view of what engines are selling well depends on where you are standing when you start looking around. If you are standing at some restaurant dock between Ft. Lauderdale and Miami you will think that the most popular engine is a 250 to 300-HP four-cycle used in twin, triple, or quadruple installation on the transom of 32 to 40-foot center console boats. If you are at the boat ramp on a small northern fresh water lake, you will think the 30-year-old two-cycle 10-HP engine is the most popular. I am intrigued when people start talking about sales figures--they never have any figures. Sales figures are just not available. When someone starts to talk about outboard engine sales numbers, they are almost always just making stuff up to match their own personal opinions. The people that actually have sales figures are not going to post the figures on-line. The [derogatory term for the E-TEC] is just more fear, uncertainty, and doubt that E-TEC FUD-meisters like to spread around. People that have actually operated boats powered by E-TEC engines never say anything like that. It is just a few people who have never been on a boat with an E-TEC that make up this stuff. I think their motivation is fear. |
posted 12-05-2012 01:34 AM ET (US)
Re the older E-TEC 115 H.O. compared to the E-TEC 130: Evinrude has some history about producing certain engine models that it designates with a special model name, and from what I can tell the special model name usually is intended to mean the engine is more powerful than the normal engines and typically is tuned or rigged for high speed operation. I don't recall all the historical names Evinrude has used for this, but in their history in the past two decades they have made some special model engines that were represented as being tuned-up or tweaked to go faster. The impression I have gotten is these engines were for boat that were fast boats, not for big, heavy, slow boats. These engines often had subtle tweaks like different gear ratio and different gear case design, all intended to enhance higher speed operation. When you see a model designated as an H.O. model from Evinrude, it is probably an engine that: --has more power than you might expect based on the numerical designation, that is, for example a 200 H.O. might be producing more than 200-HP; --has taller gears, that is, lower numerical gear ratio, to work better at higher speeds; --has (often) a gear case with lower drag that helps at high speeds; the gear case might have had lower water pick-ups than the standard gearcase, too, although now the standard Evinrude gearcase (model M2) has water pick-ups on the nose of the gear case bullet, so it is what used to be considered a low water pick-up gearcase, too; and, --has special paint or special decals or special styling to differentiate it from the standard engines, although these days this has been reduced to just a different set of decals and sometimes only a very minor difference. I also have been led to believe by some comments that perhaps these special engines or H.O. engines were intentionally rated at a lower horsepower in order to meet some horsepower limit on certain boats or categories of boats in competitions. If a guy has a boat with a 200-HP limit, he might want to get the 200 H.O. to get some extra power instead of getting the 225-HP and exceeding the rated power of his hull. There is also the notion that the power curve on these special engines is weighted for best results near full throttle. That's good for people who like to run their engine at full throttle a lot of the time underway. But I don't think any of these characterizations are hard rules, and some of the H.O. models break those rules. When I was buying a new E-TEC I could have had a 200 H.O. or a 225-HP E-TEC, and the 200 H.O. was less expensive. However, I figured that the 200 H.O. was an engine tuned to go fast, and I wanted an engine that would be a good all-round engine. I paid more to get the E-TEC 225 model. Looking back, the 200 H.O. seems like the identical engine. If there is a difference it must be in the fuel mapping in the EMM or something deep inside the engine. I have read recently about different ports on the cylinders, but not particularly authoritative reports on that. I think the same situation will occur with the E-TEC 135 H.O. and the E-TEC 150-HP. The H.O. will probably be cheaper, but it will probably have 150-HP (wink-wink) or close to it. Exactly what the gear case ratio and gear case designs will be or what options will be offered are yet to be seen. And, of course, the price is not known. I do think that the E-TEC 135 H.O. will not have any problem in outperforming any in-line four-cylinder four-cycle outboard engine in the 135-HP range. |
seahorse |
posted 12-05-2012 07:17 AM ET (US)
quote:
I might be able to clear up a few of your questions. 1) Check the part numbers for a 200HO block and a 225-250 block. The different numbers mean different porting on the cylinders even though they are the same displacement. If someone ever tried to put a 225 or 250 EMM and injectors on a 200HO, it would run terribly rich due to the block differences. 2)The 20" 135 has the L2 high-performance gearcase and the regular SLE gearcase on the 25", with CCR avaiable. The price difference between a 25" 135 and a similar 150 is about $1000 retail. 3) The new 135 will out accelerate currently available 150hp 4-strokes and out performs any current engine in the 130-140 hp range. |
Peter |
posted 12-05-2012 09:23 AM ET (US)
quote: Yamaha abandoned the "hot" 130 to which you refer. There are factors other than performance that may force the abandonment of a particular model -- most notibly, compliance or optimization of compliance with EPA regulations. At the 130 to 140 HP range (25 inch shaft length specifications), the choices are:
*2-stroke displacement. 4-stroke equivalent displacement to get similar power curve to the 2-stroke would be about 3 to 3.1L (approximately 25 percent more displacement needed). If choosing a 130 to 140 HP outboard, based purely on performance, I think choosing the Evinrude 135 is a no brainer. Given that Mercury currently doesn't have anything to offer in the 130 to 140 HP segment, I'm guessing that Evinrude is anticipating that Mercury will release a 135 4-stroke built on the 3.0L inline 4-cylinder 150. While many hope for a 200 HP version in that motor platform, I think a 135 is more likely to be launched given that it is in keeping with the large displacement, low output sales pitch Mercury made when the 150 FourStroke was released. Now on the other end, Yamaha is coming out with its 200 in-line 4 so Mercury may feel the squeeze on both ends. On either end of the spectrum, Evinrude's 2.6L V6 2-stroke has Mercury covered. Also, given some of the uncertainty that comes from Suzuki's current business situation, perhaps offering a 135 V6 will entice some previously considering a Suzuki 140 to consider an Evinrude 135 instead given that they nearly weigh the same. |
posted 12-05-2012 09:57 AM ET (US)
Re the EPA qualification: I am sure there is more to meeting the EPA qualifications than we as outboard engine buyers will ever know, and the burden for the manufacturers is probably greater than we think. From the casual reading I have done about EPA regulation of outboard engines I have noticed that there is a category of emission "family" which is so far unexplained, but I interpret that to mean--this is just speculative--that if you have several engines that are very similar you can qualify them all under the testing or certification of a grouping or family. This could be as small in scope as perhaps qualifying all the models that use a particular powerhead and just have different paint colors and shaft lengths, or, perhaps it could be as broad as qualifying all the models that use the same engine block and are tuned to different horsepower ratings. If that wider scope applies, it might have been simpler to produce a new engine model for 2013 as a 135-HP variation of the V6 E-TEC that had previously qualified as a 150-HP, that is, to get the model qualified under the same family designator as the 150-HP engines. I speculate that this would be a cost savings for the manufacturer because they would not have to conduct testing and certification for a designation of model under a completely new family. I am sure that the testing and certification of the emission for EPA compliance does not come cheaply. As for what horsepower ranges exist and what engine models are needed, I don't have any clue. It seems like there is a general expectation of outboard engines in the 50-HP to 300-HP range being available at incremental power increases of about 10-HP at the lower segment and 25-HP at the upper segment of that range. The recreational outboard engine market might be seeing a reduction in the sales of outboard engines at the very high end of the range due to the general trend for boaters to move into smaller, less expensive, and more fuel efficient boats. If there is such a trend then it makes perfect sense to have an engine in the 135-HP range. I am sure that at every outboard manufacturer there is a product manager that wants his line to have an engine for every horsepower range. All manufacturers that are in the business of selling anything to the recreational boating market have just come through three years of very poor sales and very difficult times. It is nice to see that the manufacturers that survived this three-year drought have enough optimism to continue to produce new products and bring them to the marketplace. |
Commander Coo1 |
posted 12-05-2012 11:05 AM ET (US)
This is just a theory of mine with absolutely no evidence to back it up but: Maybe Evinrude was forced to unexpectedly drop the 130 and 115HO due to EPA regulations and there was not enough time to revamp them to meet the new regs. So they could easily re-badge a 150 as a 135 because 135 is within 10% of the 150's rated sticker which i have read time and time again is the rule concerning sticker and actual output. Once the V4 blocks have been updated they will be offered again. This way, BRP isnt losing sales in this HP range, still being able to meet EPA regs, able to offer the 135 with minimal effort, and being able to take their time to properly upgrade the V4 block. But its just a theory! |
posted 12-05-2012 12:13 PM ET (US)
Here is an alternate theory: The high-ouput V4 engines (under whatever model name Evinrude gave them) accomplished the increase in power output by use of a tuning valve in the exhaust passage. The valve was some sort of a throttle plate valve that opened or closed an exhaust passage, changing the length of the exhaust path. This had the effect of enhancing the engine power in certain engine speed ranges. The valve was operated by an electrical actuator. The actuator was controlled by the engine management module. I know of at least one post to one website where one owner of one E-TEC V4 commented about having to get service on the exhaust valve. For the E-TEC FUD-meisters this one mention of a problem is all that is needed to proclaim that there were problems with the exhaust valve in the V4 and then to speculate that this is why they are not being produced in 2013. Now you would normally think that it would require more than one person to mention about one problem with one engine, but you have to remember that for the E-TEC FUD-meisters there is also a generally held notion that these engines were not selling well. Therefore in the small numbers that these engines sold, according to the FUD-meisters, it would only take a report of one problem with one engine to qualify as being a characteristic of the engine, since one engine must represent a sizable sample population. |
GSH |
posted 12-05-2012 12:26 PM ET (US)
So IF Evinrude has concluded that the two higher output V-4 E-TEC:s no longer are OK for whatever the EPA is demanding, why could Evinrude not keep those two models in the line-up for non-EPA markets like Scandinavia? (Just asking...) |
prj |
posted 12-05-2012 12:38 PM ET (US)
I've made perfectly clear my guess for BRP's ending of a short production run for the 130 HP V4 E-TEC. And it certainly didn't involve an exhaust valve problem found on an internet search. In dismissing my suggestion of weak sales, Jim seems to suggest that the alternate could be true, BRP ceases production of the 130 HP V4 due to strong sales! And Peter, are you really comparing the 19 year (1986-2004) production run of the Yamaha 130 HP with the apparent 4 year (2009-2012) production run of the E-TEC 130? Or are you suggesting 19 years is "relatively short"? I'm not clear on your comparison of the duration of production runs for these two engines. For the record, speculation (or insider's knowledge) of an EPA compliance requirement is certainly a viable reason for replacing the 130 V4 with the 135 V6. Matter of fact, its a much better reason than the high sales volume that has been implied. |
Peter |
posted 12-05-2012 02:02 PM ET (US)
The 130 to 140 HP range is in one of those "no-man's" lands where that WOT HP level can be supplied by either a souped up small motor or a toned down large motor. Similar to 70/75HP and 200 HP. PRJ -- My point really had nothing to do with production runs. I merely point out that there can be other reasons for discontinuation of products. If you think that the Yamaha 130 had a long production run, the 32 cubic inch OMC 2-cylinder had a 30 year production run from 1976 to 2006. As I recall, the production run for the OMC 42 cubic inch 2-cylinder looper was even longer (something like 35 years). Those motors probably would have continued for another 30 to 35 years had not the EPA stepped in to change the market dynamics. Mercury's Optimax 225 with a fairly long production run has been discontinued yet the 200 and 250 HP models which are built on the same platform have not. Mercury has no light weight offering at 225 HP for standard recreational applications. Why would any manufacturer have such an odd product line gap from a pure market perspective given that 225 HP models are popular, probably more popular than 200 and 250s? The odd gap must be caused by something else and that something else is probably emissions regulation compliance optimization. When the government gets involved in regulating a market, weird things can happen with perhaps the most obvious being the housing market. |
hauptjm |
posted 12-05-2012 02:16 PM ET (US)
Where, exactly, did y'all read that Evinrude is eliminating the 115hp or 130hp 4 cylinder platforms? The press release in the National Professional Angler Association website didn't mention it - an article from Sport Fishing Magazine doesn't mention anything about dropping the 115/130 (they claim the 135 H.O. is a de-tuned 150hp) - the Evinrude website doesn't mention any of this. |
posted 12-05-2012 06:46 PM ET (US)
I think the present market situation is the EPA is picking winners in outboard engine design. |
seahorse |
posted 12-05-2012 07:22 PM ET (US)
Don't get confused. The 115 is still alive and well. Only the 115HO and the 130 will be discontinuing production and will be replaced by the 135. |
masbama |
posted 12-05-2012 07:32 PM ET (US)
Interesting video on the 130hp e-tec and its exhaust. http://youtu.be/uwcu9Y-eRxM |
Peter |
posted 12-05-2012 07:47 PM ET (US)
The fact that Yamaha has NEVER filled the 130 HP gap it has had in its product line ever since it discontinued selling the "hot" 130 2-stroke and the fact that Mercury has discontinued offering 135s (overweight models or otherwise) suggests to me that the market for the 130 to 140 HP motors must not be large enough for either of the large outboard makers to care enough to serve it. They've essentially conceded 130 to 140 HP market segment to Suzuki, Honda and Evinrude. |
posted 12-05-2012 11:44 PM ET (US)
There is no value in judging the Brunswick situation re their lack of a 135-HP engine. Brunswick engines (sold under the Mercury brand) for the most part only are sold on the transom of Brunswick boats (under various brands). If Brunswick does not have a 135-HP engine that is of little concern; Brunswick will just use some engine they do have on the transom of their boats. It is not like there is some sort of free-market operating here with regard to Brunswick engines. Brunswick is a little oligarchy in the marine business and they will make whatever sort of engine they need for their boats. On the other hand and the complete opposite of Brunswick, Evinrude has to sell its engines in a free market, so it needs to make engines across all horsepower ranges. Evinrude cannot just tell its potential boat builder customers to change their hull ratings to suit the engines that Evinrude has available. Brunswick can do that; we have seen it with Boston Whaler boats. |
prj |
posted 12-06-2012 09:47 AM ET (US)
[Introduced sidebar on whether or not Mercury sold engines to other operating units of Brunswick in a significant number. This is not really in dispute by anyone familiar with Brunswick. I have deleted the sidebar, which went on for dozens of comments until an elegant analysis of publicly available sales data showed that about 40-percent of Brunswick outboard sales were to itself. This clearly meets the criterion of being significant.--jimh] |
Tohsgib |
posted 12-07-2012 01:06 PM ET (US)
They "should" make a 100hp out of the v4 as well as mentioned above. It would be a torquier engine and satisfy some who want more than 3 cyls on the 90 but can't use 115. The 135 would be great on a 18/19 outrage or a banana hull as the top speed between the 135 and 150 would be about nill due to hull design but the torque and $1000 savings would be a plus when repowering. |
Peter |
posted 12-07-2012 07:17 PM ET (US)
Leaving the Mercury captive market dynamics aside, as I mentioned before the other big player -- Yamaha-- does not participate in the 130 to 140 HP segment but it participates in every other segment. In fact Yamaha has a largest gap in the segment, 115 to 150. With only 1.7 L of 4-stroke displacement, the Yanaha 115 block is too small to make a motor in the 130 to 140 range and their 150 at something close to 490 lbs in a 25 inch length is just too porky fo anything less than 150 horses. They are stuck without competitive product in this segment and I suspect it is too small to spend money developing something. From a performance perspective, the new 135 should be a killer product for the segment. |
Freddy |
posted 12-10-2012 11:49 AM ET (US)
Would the new Evinrude E-TEC 135 HP in twin configuration be a good candidate for a 25 foot Outrage? |
Peter |
posted 12-10-2012 01:12 PM ET (US)
I think so. I run a pair of 150 V6s on a boat with a 24 foot, seven inch length (same as the Outrage 25) and wouldn't have it any other way. |
pcrussell50 |
posted 12-10-2012 07:28 PM ET (US)
[Long article about Evinrude engines, similarities between models, seat of the pants estimates of horsepower output, and other topics deleted. Please let's stay on focus: the new V6 135-HP E-TEC is the topic. Thanks--jimh] |
